Who has done the vvti to non conversion???
Ok guys, I need some info please. I have a JDM aristo gte-VVTI motor that I am currently prepping for install into my SC. I will be running everything off a Motec-M84. I will be going single turbo (BW s300 or s400). I would like to convert to non-VVTI. Who on here has done this and can offer some FACTS on how to properly do this. Ive found multiple threads with some info but nothing seems to be a cut and dry "this is what you need" explanation. For those who are about to say "why not just keep VVTI?" I would like to make between 6-700whp. If someone can show me with facts that this can be done reliably (i'm using that term loosely here lol) than I'm all ears. But please give me facts if possible. I want to thank everyone in advance for any and all info given! I know there is a ton of knowledge on this forum and always appreciate the help given!
gte & na-t
If you are running Motec then why would you wanna delete the VVTi?
Sorry i just reliase that M84 doesn't control VVTi, M400 controls VVti not M84
So just unplung it solenoid and it should take care of that for you.
If i were you , since you live in AZ i would get the Proefi since headquater is in AZ. I would even rock the 48. But if you can afford the Motec then why not LOL .
Nice let us know how it goes!
gte & na-t
You can actually get VVTi Camshafts now. I am not sure what you are looking for but check my sig i don't have cams on my car yet! i have seen 970whp on jdm cams , so it's all about what you gonna use the car for and how much power you really looking for.
If you can keep the VVTi since you already bought the Engine . Its a though call bro.
It comes down to what ecu you wanna run .
I've already got the M-84 so that's the ECU the car will be using.
I know Titan sells a set of VVTI cams for 1100 bucks but I haven't heard too much about them neg or positive. If I can get away with keeping the stock JDM VVTI cams in there and still making between 6-700whp I'll be plenty happy.....for now
gte & na-t
Well it looks like M84 doesn't control variable valve timing so you have to delete the VVTi if you wanna use the M84 ecu or run the M84 as a piggy back .
or Get a non VVTi engine.
gte & na-t
I had deleted the VVTi on my old setup that was 3years ago. I have done it but i can't remember everything off the top of my head.
talk to JeffTsai he is on the GS section he maybe able to help you.
gte & na-t
No lol it's that that easy my friend , it doesn't work like that. the main issue is the intake cam it's different, it's longer. the new intake cam you will install will need to cut , welded then machine to fit the Head.
I have mine machined by MO at SRT racing , since all he does it na-t IS300.
omar , i was being funny .. if i was op i would ditch that motec for a unit that controls vvti .. once its synced itworks so damm good .. the is na-t that i recently built has full vvti , alpha synced it with the aem and it really does wonders for off boost driving and spoolup
