- E-Brake Help
- Subwoofer grille rattling!
- Is anyone interested in a tutorial?
- Coolant Flush Help!
- Which one should I get? Ls or GS
- Long crank before start
- Daytime running lights?
- well i just purchased a ucf10
- Egr delete mod...
- brembo front rotors
- UFC20 rear strut rod bushings
- 97 Nak changer dead..options?
- Question about 1999 LS400 ignition coils
- O2 sensor
- New mods: UCF20 $65 Chrome Trunk Garnish & Woodgrain Beatsonic faceplate with Pioneer
- ls 400 cam
- I broke my strut rod!!!
- Will LS 460 Rims work for 96 LS 400
- Smog test goes wrong!
- Looking for floor carpet for my 92 LS400
- Strut rod bolt seized?
- New battery died after about 30 miles
- seeks steering damper, struts recommendation
- 1991 Airbag Layout
- Transmission mount OEM vs other brand
- 1991 LS400 Radio Problem...
- ABS issue ..
- need help with the pvc valve
- 92 LS 400 with 29000 miles
- DIY: Fan Clutch repair
- LS400 gurus ... your wisdom is needed ...
- Dealer charge to replace motor mounts?
- Weird problems
- light vibration feel in motor when accelerating
- just got vossen wheels on my 99 LS
- Strut bar Bushing or cushion?
- A/C temp at vents
- Lowering my 91' LS400
- trying to define what model lexus ls400...
- 1990 LS400 Traction Control Issue
- Oxygen Sensor Diagnosing
- Wheel Size Question for 1995 LS400... please help
- 1996 ls400
- Aftermarket Subwoffer and Amp
- Replaced Knock Sensors MIL still on
- guess where the hoses go!!
- 1990 Lexus LS...had it shipped and now it's not running..
- Vibration when braking, bushings?
- 98 ls Random increase in RPM
- New LS400 owner... yes i tryed search... :P
- 96 ls400 convert to 03 ls430 steering wheels ?
- 95 LS400 HID problem
- please help me (CEL, engine shaking)
- Camry rotors on LS?
- Parts for homemade stainless steel exhaust
- Whining sound from front of engine??
- Sudden acceleration problem 98/2000 ls
- Missing Under load/no power, NEED HELP
- Serious problem, need help.
- My new ls :-D
- proformance parts
- door switch
- Running Rich
- transmission gasket
- Transmission fluid leak - 91 ls400
- 4th gear problem
- 1996 LS400 AFM / MAF Connector
- m3 style trunk spoiler
- LS 400 security light
- Lexus = ripoff artists
- sunroof leaking
- Delima shimmy and bad vibration while breaking
- metal headgaskets for the 1uz
- Phew...never seen that before.
- HVAC vents and circulation
- bumper question
- Thinking about buying an LS
- Water Pump R&R - 97 LS400
- Drive and reverse light indicator on.
- Seat Compatiblity
- Air Conditioner compressor not engaging in 50 deg weather - normal?
- Please use the classifieds for FS and WTB posts.
- Acceleration = light flutter feel on 98 LS400
- slight Thump/Clunk while backing up
- 1998 ls400 new beginnings
- transmission jerks in revers
- Help choosing rims
- Proud new owner of a 99 ls400
- Can I update GPS on 1998 LS400??
- Upperclassmen LS400
- Chrome bumper trim
- EGR troubleshooting
- 1992 LS - Mystery sounds (problem?)
- White smoke in engine compartant and exhaust followed with hissing sound
- Running wire through firewall
- Japan earthquake
- interstate battery warranty
- exhaust manifold outlet size
- Help!! huge problem.
- it this natural? (fan comes on when turn key to the on position and stays on)
- Loss of Power Steering
- 1996 LS400 Questions
- 91 Ls400 LeBra.?
- Rear Upper Control Arms
- Coilover help
- Steering Wheel Vibration
- OEM Navigation 98 LS400
- 1992 LS400 won't start
- Bad shifting
- intermitten chirping... how long does idler, bearings last?
- will 93's 16" center cap fit 90's 15" center cap?
- harmonic ballancer removal
- 1991 Subwoofer Amp or Speaker?
- Sport ECT
- Water Leak. Water Pump?
- well, i need to find an ls with a bad motor for cheap
- gas adjustable kyy
- thread headings specificity
- car slightly steers loose on freeway... what could it be?
- How to remove rear seat on 2000 Ls400
- Newbie With Power Steering Pump Leak
- Help. Power steering pump seal kit
- Help! Ls 400 Gas Pedal
- burning oil and bad mileage
- 1998-2000 LS 400 safety features
- How to seafoam ?!
- Wood Steering wheel swap?????
- Control Computer? (no power, dying etc)
- Maintenance schedule for 1999 LS 400?
- Another Idle problem thread. 1997 LS400 Idles too low when warm and in gear
- anyone got 15" chrome wheel cap?
- 96 LS400 EGR Tube location
- 95 LS400 low beam just quit
- gas economi
- Gas Gauge or Miles Left... What's Right?
- Battery drain Passenger door
- Vsc And Check Engine Light 1998 Ls 400
- Will the doors off a 91 fit my 95 LS400?
- Transmission fluid level check
- Why use the BeatSonic adapter....?
- Dirty LS400 Engine
- 96 LS400 heater/ac not working
- why 2 ohm in front and 4 ohm in rear?
- transmission ecu question
- '98 Nakamichi headunit replacement
- Interchangable Transmission Mounts?
- Advice on Buying 98 LS400
- just checking in
- speedometer not working
- 1992 LS400 - Oil Level Sending Unit
- Brake job -- Rotors/pads 94-LS400
- which sensor is this?
- Vibration after 19" aftermarket rims & tires
- 97' LS4 - Changing the front blinker
- bad catalytic converter advice please?
- Tweeters cracked
- Engine problem!
- 96 LS400 loud engine
- Need a Fuse Box Diagram...
- Crankshaft seal replacement
- 95 SC seats in a 95 LS (I have searched)
- water pump replacement
- Tune up gone bad!! HELP REALLY NEEDED BAD!
- plug wires specification(please help)
- newbie looking for parts
- here is why you dont send your ecu to ATE to be repaired.
- Lighting issues (sort of) please help anyone.
- the best price for parts
- dealer = good deal on timing belt job
- wind noise
- 1995 ls 400
- First Lexus
- 1996 ls400 PLEASE HELP
- 92 ls400 seats
- motor mounts
- 1991 LS 400 Subwoffer
- Power Window Auto Down
- Bumper color code 96 ls400
- 93 LS400 Check Engine Light
- 98-00 LS400 w/out Navi: which wiring harness do I need for audio?
- first gen rain handling improvement
- 1st gen vs 2nd gen LCA bushings
- spark plug wire
- Price Check 2000 LS 400
- I have fixed my no heat in the car for a 8 hour ride to Buffalo, thanks to this forum
- Help have this hesitation on the gas pedal
- Wheels and offsets
- Looking for headers for 95 celsior
- how to get cup holders in front to come out of the armrest.
- Leaking Coolant
- 1999 LS400 rear suspension
- slight engine miss,shaking and rpm drop
- what can make a ecm go bad?
- Something loose in steering
- Sooo tired of stock steering wheel
- 2000 LS 400 Rims
- LS400 won't start - dinosaur bite??
- LS400 wheels
- 93 LS400 acceleration problems?!? help!!
- 96 LS400 fuel filter location
- Door Glass Replacement - Need Help
- Trouble code 28 and trac code 47
- 96 Ls400 Will Not Start
- Heating inside the car.
- 1997 LS400 - Hard to change CV Boots?
- Help! having multiple codes and car sounding bad
- Mechanical help for 97 LS400 oil leak
- How to test Tilt Motor
- Cruise Control Inoperable
- TRD strut bar and UCF10
- My brake tail light is out
- 99 LS 400 Hit in Driveway :( w/ Pics
- 1995 LS400 - Perfect to No Start in 5 seconds flat.
- just installed NOTTO LED lights
- Heating and Cooling
- stalling on deaccelaration
- Worth Keeping 1994 LS 400
- 1994 LS 400 worth keeping
- Looking for JDM power folding mirrors
- 92 shifter bulb light
- ls400 engine code 14/no start
- Really Odd Noise when on the freeway??
- 1999 LS 400 - Replace Timing Belt and Water Pump?
- Where did you put your foglight hid ballasts? ucf10
- Bad torque converter or input shaft bearings?
- 97 LS400 distributor cap
- '97...dies after idling and won't restart
- Floor Mats
- 1990-1996 body question
- 1990 LS400 Brake upgrade
- Sc400 axleback?
- 2000 ls 400
- AFM out of spec
- Need Help, dropping my LS
- Steering issue
- Bad Times for LS400 1996 #NEED HELP#
- UCF20 Engine cover on a UCF10?
- Cam Cover (Left)- coolant leak
- fitment ?
- New member wants to say Thanks to Club Lexus!
- '93 LS400 Code 25
- Why does the engine speed drop...
- my 90 ls400
- diy home depot replacement carpet for less than 50 bucks
- Converting air suspension to regular. Help needed
- 92 wheel bearings
- 1990 ls400 shifter?
- Coilover Question
- Air suspension part#s?
- Some observations about my "new" 90 LS...
