- SC300 2jzgte swap???
- Who has a 1jz mated to SC400 tranny?
- Transmission feed/return
- LSX swap in progress.....
- Guys, do you think this would work on the '97 SC?
- Heater Control Valve
- torque converter lock up questions..
- Anyone know about fuel gauge ohms in our cars? and aftermarket fuel gauges
- Labor cost for transmission swap.
- Transmission hard shifting and doesn't downshift
- Who has the upgraded alternator?
- I need a link for manual shift boot/plate purchase
- JZZ30 soarer 1JZ VVTI motor swap on ebay
- Apexi Panel filter
- 1uz questions, swaps, and opinions
- Is it good to put a Intake on Sc300
- Coolant leak, Bucking/jerking, low idle, Intake gasket leak? Help?
- same side intercooler pipping?
- gte & ge interchageabilities
- TRD Strut bar for MKIV fits SC300 / SC400 / Soarer?
- New Black Carpet for less than $100? Elbow Grease Needed...
- Vibrations When 5spd swap w58 help.
- 1jzgte headgasket
- 2jz tt mounts on 1j sc...question
- idle issue and car not accelerating
- someone in Mi that can a do engine swap
- Exhaust flow
- Just swapped and having electrical issues(Help!)
- 95 lexus sc300 auto
- TT Break Lines questions..
- SC300 Tech Help needed - Alternator Plug routing
- How can I tell which transmission is with my 1jz?"
- How Do I adjust Idle sc400?
- Serpentine belt noise
- Sc400 Auto To Manual help?
- help
- Symptoms of failed timing belt?
- Code 12 on a 93 SC400??
- The holy bible
- FM Intercooler size for 97+ front bumper
- She stunk, smoked, then died....
- Using a VVTi ECU on a nonVVTi motor
- Need help with rack&pinion actuator/solenoid
- I replaced my ECU today, now my torque/acceleration is drastically slower, wtf??
- Quick question!!
- How to remove O2 Sensor
- Vibrations when 5spd swap Help plz
- Removing lower oil pan on VVT-i SC300? Any tips?
- spdrcr771's 98 SC430 1.3UZFE
- xspower or driftmotion turbo kit?
- Driveshaft installed - now won't Shift gears (1jz/R154)
- Greddy Emanage Ultimate on VVT-i
- Info on m/t pcm
- Turbo Compressor Chipping?
- First trip to the strip, ran some 10s :)
- Alternator replacement/Help please
- Engine Dies on Startup
- Na-T
- T4 housing for a t3 sc61 instead of t3/t4 adaptor?
- Catalytic converter question
- 1jz after market coil packs
- Diesel oil in a non-diesel engine, anything i should know?
- Look what the Boost Stork left at my door
- interested in turbos
- T67 auto?
- Help me identify these sensors? 99 SC300 VVTi
- Tranny and Clutch q's
- HELP : my SC300 start fine but dies after 10mins
- rear diff replaced and still sounds bad
- Free spinning/whistling sound when at slow speed?
- Noob questions about going turbo
- soarer 1jzgte goal 300rwhp
- soarer 1jzgte trans
- SC400 general performance mods
- Shift Solenoid
- W58 noise.. PPL chime in..
- Patriot Exhaust SC300 Headers?
- heat shield vs. turbo blanket
- Need Some Advice
- Transmission light flashes... Searched and want opinion
- Tutorial: Front Wheel Bearing Replacement
- Help needed!!!
- Bogging under Acceleration when warm
- jdm supra 6speed swaps
- To anyone with an LSD
- Big brake kit?
- Vacuum and emanage problem?
- Turbo Exhaust Quietest one?
- Diff Swap!
- Questioning of general rule about weight reduction
- Power Steering Pump
- Looking for Pics of Rear of 1jz
- Calling people with 2jzgte BPU mods... need help..
- Now what ???
- 1JZ Air Conditioning, quick question
- 2JZ-GTE swap questions
- Tach stopped working
- SC300 Spark Plug Info (long)
- Cel 12 & 14
- 92 SC400 wont start
- Smoke or steam through ac vents & emerg flashers...
- Part number request
- What do you guys think? Bad Gas?
- Wtf!!!
- Engine Misfire
- Part Numbers for Exhaust Gaskets on '92 SC400
- Climate control just blows air, not cold, not hot.
- Looking to do a r154 or w58 manual swap? look in here, dont make a thread.
- where can I buy a crankshaft pulley?
- official 1jz vvti parts thread
- 1jz o2 sensor help!!!
- Please help piggyback my specific setup
- VVTI Head Swap
- my sc400 is running RICH and would LIKE some help please
- 93 sc400 maf sensor the same as 93 sc300?
- Codes 21, 31, and 28
- Routing dual fuel lines for dual Bosche??
- Tune up
- Car is acting up after Tune up..
- Strange Leak
- grrrr...1jz tach issue...
- 1992 SC 400 Stalls When Put into Gear
- High Idle after new spark plugs?
- 1jz y pipe
- 780cc Map-ecu anyone?
- SC300 Exhaust
- sc300 dead? need help
- Intermittent Starting
- What is this hose? (1jz)
- knocking sound when trying to start the car
- Differential EPIC Fail!!!!
- Turbos Back
- GS400 rear end...
- 1.5J opinions/owners
- First Mod
- Differential Grinding and Binding
- High idle when cold, but normal when warm
- help.... my sc will not stop JERKING
- rebuild or swap?
- Alternators
- HELP! JZZ30 Soarer differential side bearings
- A/C Question...
- Axle Back Install Question (Stock muffler Removal)
- code 31
- Head pullers chime in....
- 2jz vs 1jz?????sc project
- Fuel filter on SC400
- 2jz-gte bottom end with 2jzge head???
- diagnostic help !!!
- New Car Help
- SC300, burning or leaking oil
- Tt ffim
- I pulled the codes 21,24,28 and 31
- Head pattern..
- Affordable engine mods?
- Diffs
- Swapping to supra trans can i get better MPG with a 5 speed instead of a 4 ?
- Help gas tank problem
- Hesitation / Stuttering Issue
- Power Steering hoses, where do they go?
- Clutch noise w/ video
- 1jzgte VS 2jzgte (jdm) turbo
- Axle-back Exhaust Question
- hard to start on map ecu 2
- TRanny Probs Hard shift into drive
- 92 SC400 Dead Speedometer & Intermitent Tach
- Overheating problem
- water pump?
- SC400 transmission problems
- 02 Censor - Does it matter which one?
- help,how to take piolot bearing out
- Sludge Help!
- Soarer R154 Shifter Parts (Tri-pod Style)
- Slight delay in throttle response.. what could it be?
- Name that plug time
- Which tranny mount for R154 and 2jzgte?
- Any ideas what a 400hp crank sc400 pulls..
- Anyone heard about this one?
- Can someone point me in the right direction - GTE ecu on GE motor
- Please help me diagnose engine stuttering
- sc400 valve cover gasket
- after altenator install
- Help. Jerking while driving around 2k
- Quick Exhaust Help. Using no muffler?
- OBDII swap possible?
- TPS Adjustment.
- Diff swapability question..........
- 1.5JZ-GTE Car Breaking Up - Need Help
- 97 1JZ starting issue...
- no ignition problem
- Engine rebuild suggestions please
- Q: ac / pulley/ alternator belt
- 450-500hp 1j. what clutch?
- SC400 A/C fan control busted
- SAFC2 Help
- cheap powersteering fix!
- Couple of pics at the track last Saturday
- Advice on Lowering Fuel Pressure (Big Injectors/Turbo)
- wow... fastest stock twins 1jz...
- Royally Ripped off by Toyota
- HELP head gasket
- 95 Cluster Help
- Exhaust Help
- what brand of turbo would you recommend?
- Smallest turbo possible for 360hp?
- Power seats arent working, HELP!!!
- Are my brakes malfunctioning? HELP?
- SC 300 change spark plugs
- something blew
- what to do?
- Lexus es 300 2002
- sc400 burning too much gas, oil light like goes on them back off
- neeed to know which one
- something wrong when i startup engine make more vibration
- SC300 USDM GTE/TT Built Auto. Transmission mount/crossmember???
- Alternator Wire Path
- DIY. Alternator Fuse.
- injector resistor box wiring...
- o2 sensor compatibility range
- 1jz "2 oil pans" question
- 2JZ-GE belt without P/S?
- I just got a 1992 sc400 is it a inteference or non interference engine
- Help! 1jzgte issue (daily driver)
- nitrous experts i need some advice...
- $250 to repair exhaust, does that seem right?
- Na-t she woke up this morning
- side skirts legit n fitment these??
- wood grain rattle ???
- 97 SC300 cluster into 92 SC400 - Fuel gauge problems
- trouble with removing w58 manual trans
- sc400 questions
- "help please" sc300 is reading low air voltage
- Spark Plug Dilemma
- 1jz start up problems
- Is anyone using the auto. tranny from a 1J?
- A/C always on - even when no green light
- 1j which throttle body?
- AEM wideband problems
- Repair workshop cd
- WTF??? I tuned up my 400 and it runs like crap. HELP!!!
- Hid retrofit housing question
- EMS Decisions 99 Na-T
- Component weights from our racecar
- DIY: GM th350 swap and Hurst Pistol-Grip Shifter Install
- hi-comp na-t build thread?.....well so far thats the plan.
- First Thread NEED HELP
- Airsto Swap o2 sensor
- P1633 ecm malfunction! Limp mode!
- car won't start
- T-IV ATF for Power steering?
