PDA
View Full Version : Performance & Maintenance
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87
  1. Poor Performance
  2. 1JZ-GTE Bad turbos?? Please help
  3. strong fumes inside of car
  4. Dyno s366, aristo stock ecu,sc300, 12 psi
  5. Battery Light Is still On... WTF
  6. Need help, electrical nightmares, headlights cutting off tranny acting up
  7. 92 SC400 MAF Issues
  8. Oil leak near, driver sid enear cyl 1 and 2
  9. SC4 plugs and gasket questions
  10. Should i upgrade my alternator?
  11. 1997 automatic ? swap or turbo kit?
  12. new 1uzfe engine soon
  13. 94 SC400 trans replacement
  14. Help with idle!
  15. Which 2jz-gte engine is it?
  16. 1UZ gurus please help.
  17. temp gauge issue
  18. my sc 300 turns off while driving...
  19. 1jzgte, Single turbo, vaccum issue
  20. No heat...help
  21. Replaced Cam+ Crank seals and still leaking
  22. 93 lexus sc400 Rumbling sound from the transmission or engine
  23. Anybody know how to setup FIC1100 injectors for the AEM V1?!?!
  24. Help needed
  25. Completely stock 1JZ twin turbo OR stock 1JZ VVT against 200k W58?
  26. Radiator Question
  27. Tensioner possibly dying?
  28. Building FFIM. Need measurements
  29. Rear Cam seal replacement
  30. Compatible Differentials
  31. 1jz cam sensors
  32. Hollowing out cats
  33. HELP: 1JZ VVTI Swap A/C & P/S Issues
  34. Need help with gated shifter conversion
  35. Manually raise and hold idle rpm (for diagnostic purposes)?
  36. jzz30 wiring diagrams
  37. Powerwashed my sc300 and it isn't running right !
  38. Oil Pan gasket replacement.
  39. 400 running cool
  40. First tuneup for Me and My Sc400. Spinning Tires Now! ;-)
  41. Warm weather= low rough idle??
  42. performance
  43. please help have a problem sc400 starts and shut off
  44. A "how my clutch feels" question
  45. Gauge cluster bulbs?
  46. Progressive power steering delete....is it possible?
  47. M2 performance muffler test dummy
  48. External Shifting R154 is apart - in search of some guidance
  49. 92 SC 400 rough idle, need help
  50. Need help.. harmonic balancer
  51. Aristo 2JZGTE running lean
  52. vvt-i ecu chaser - soarer
  53. intake and exhaust
  54. running very very poorly
  55. Will I have a problem clearing my 6766 on this manifold?
  56. Differential bushing removal?
  57. Power steering leak, potential source?
  58. 1996 sc300 p0401 code help please!
  59. low idle problem
  60. Help!!! No spark 92 sc400
  61. O2 sensor wires cut
  62. Q:50mm wastegate on 44mm flange/tube
  63. Aftermarket power steering reservoirs?
  64. making steel braided fuel lines for sc400
  65. How hard is it to install Rack/Pinion and Tie End Rods?
  66. Checking Engine Codes - CEL Burnt Out
  67. 1jz-gte into my sc300 fuse box?
  68. R12 a/c pressures
  69. 98 sc400 2jzgte swap? manual transmission
  70. A/C Compressor seized up / smoking. I want to delete it.
  71. SC300 Aristo Swap Rear Thoughts
  72. 1JZ GTE VVTI Swap Code 78 Question
  73. 2jzgte breaking up above 14psi
  74. SC300 stalls/hesitates.
  75. Replacing PS fluid and fan fluid with synthetic?
  76. transmission fluid help
  77. traction control
  78. Code 14 - ok what...?
  79. Question on door trim
  80. SC 400 starter
  81. Window switch died...quick question
  82. Aftermarket ECU to replace master key in 98-03
  83. Is this radiator corrosion an immediate problem?
  84. New sc400 driver. need help..
  85. Obd1 motor with obd2 ecu?
  86. Picked up a 93 SC400 - Have a few questions
  87. quick question about ehxaust
  88. mechanical oil pressure...
  89. 93 SC300 No Cold start/Struggle to start
  90. sc400 fluctuations in rpm
  91. car smoking underhood cant find where though
  92. sc300 noob - need confirmation for mkiv supra gte swap.
  93. My Sump Dilemma
  94. 1jzgte vvti parts source
  95. Starter Changing Woes
  96. Tips for OBD2 AEM EMS V2 Na-t
  97. Sc400 R154 5 speed swap ...Clutch ?
  98. performance for the 93 sc400
  99. How many o2 sensors on sc300
  100. Thoughts on intercooler height
  101. buying shift solenoids
  102. Blue Smoke.....Help Needed!
  103. w58 speed sensor
  104. 1UZ non VVTI with W58...which diff ratio?
  105. New Engine and Transmission Computer designed for 1UZ & A340
  106. Sc300 Backfiring On Idle Rough Idle NO CEL!
  107. Cant get CEL codes
  108. Fuel pressure regulator VSV???
  109. no power to aem Help!
  110. Remote Start issues
  111. quick question about upgrading valve springs
  112. Fuel pressure regulator ge fuel rail
  113. blocking the stock bov
  114. Solid rack bushings, sub frame spacers, etc. questions
  115. 1jz timing issue
  116. 1993 obd1 cel
  117. Help Needed narrowing possible causes for my idle problem
  118. 1995 SC400 timing belt
  119. 1jz no start no fuel
  120. NA-T oil feed
  121. Custom SC400 Engine Mounts
  122. sc400 exhaust rattle - is cat delete worth it?
  123. Fuel management NA-T
  124. 26 mpg in my 97sc400!
  125. Tire Pressure for Aftermarket Wheels
  126. Valve stem remover
  127. NA-T gas mileage? What are you guys getting?
  128. What is the least attractive SC300 Body kit?
  129. Is an inexpensive ebay Timing Belt/W Pump kit OK?
  130. which engine mounts?
  131. HELP. my tire is wearing unevenly
  132. 97 SC300 Gated Shifter Wiring
  133. 1993 sc300 smog/ seafoam help ?!
  134. price range for auto to manual tranny swap
  135. Fair price for custom FMIC piping and install
  136. Where does this vacuum line goes to?
  137. R154 3rd gear and gear fork
  138. Fair price for 1UZFE Tune Up? (street mechanic)
  139. Power Steering help
  140. Oil Pressure Light on Startup
  141. My SC4 doesn't like rain...
  142. TRD GEN II STYLE SUPRA SUPER EXHAUST (Motoria Exhaust/ Xs Power)
  143. Lost a quart of oil in two days...
  144. Rough Idle, Could Be O2 Sensor?
  145. Electronic boost controller questions
  146. Another Sound From Engine Bay
  147. Can i supercharge my 92 sc?
  148. Prosport Gauges ... to good to be true ..?
  149. looking for info on twin turbo setups for 1JZ
  150. What oil you guys running?
  151. drive belt snapped now pulley arm wont move
  152. SC300 AC Lines, HIGH LOW?
  153. Heater takes a long time to turn on
  154. What 1JZ do I have???
  155. Aftermarket wastegate on stock 1JZGTE?
  156. SC400 Overheating after conversion to 2JZ-GE
  157. Sc400 tranny issue
  158. Any recommendations for a budget digital boost controller?
  159. Question about wastegate sizing
  160. 95 sc300 waterpump replacement
  161. I've always had a fetish for cool whip.
  162. sc300 1jzgte problem help
  163. speedo doesnt work, can i wire vss straight to ecm so it sees speed?
  164. Strange start and idle sc400
  165. Engine block coolant drain plug
  166. Link to Sc400 tune up DIY?
  167. Weird noise on start up???? Added a video
  168. Question regarding Leak Down Test
  169. Tomei Arms vs 20g build factory turbo
  170. Anyone using a TWM weighted shift knobs
  171. Bad hks wastegate?
  172. electrical ground issue? perhaps starter?
  173. Is this the sound of a faulty pulley? Video inside.
  174. Fuel line question.
  175. aristo center bearing for driveshaft on a sc
  176. 1 JZGTE swap JDM Auto vs Manual ECU Questions?
  177. Borg Warner s366 oil 90 deg adapter thread size
  178. 3 cylinders dead
  179. Fog lights
  180. Oil on spark plugs
  181. CEL Code P1120 (APPS) - Acceleration Pedal Positioning Sensor Question
  182. 1995 Lexus SC400 help
  183. Help!!! Calfiornia my SC300 did not pass smog test???
  184. Performance, Aftermarket or OEM for Motor/Tranny Mounts?
  185. 1992 lexus sc 400 will not crank over. HELP.
  186. NA-T installed, car is not idlling :(
  187. Can I access the engine coolant temp sensor without removing pass side sp plug cover?
  188. Throttle stuck wide open at 14psi
  189. Corroded Brake Line!
  190. 93 sc300 1JZ 3k up stutter issue.... HELP!
  191. oh great i cant pass smog test!
  192. Single exit exhaust options?
  193. R154 clutch/tranny problem
  194. NA-T intake ideas
  195. Should my shifter sit like this? (soarer r154)
  196. Power steering grinding noise? (Video)
  197. helllp, p0300, p0301, p0306. random misfire,1 and 6. runs fine
  198. Help with belt squeal.
  199. Help ASAP car wont start
  200. 1jz swap into SC300 fuel feed line leaking and wont stop!
  201. Clutch pedal install SC300
  202. Ok I HAVE to finally get around to fixing this idle issue
  203. IJZ VVTI SC400 Motor Mount Part#
  204. Long Road Trips, Maintenace Suggestions
  205. rebuild engine help!!
  206. SC 300 + 2JZ GTE VVT-i + Aeromotive 11142 + Controller FPSC Aeromotive -16306
  207. Best place to get a 2JZGTE?
  208. Need help! Supra tt auto LSD
  209. 1JZ 101 for dummies
  210. Max hp on factory fuel lines?
  211. Q45 beech tps adapter help
  212. GE NA-T correct MAF placement?
  213. OEM Ignition coils for 3.63$~ can this be real? Will these work on my Sc400?
  214. Hesitation above 5K RPMs?
  215. Anyone Heard of Phoenix Power?
  216. SC4 and GS4 tranny mount the same?
  217. Electrical Issues with my 97 SC300! Won't start.
  218. Where Are You Buying 1UZFE Tune-Up Parts? What are you using?
  219. 2jzge MAF blow through?
  220. Help! Braking/Dash problem, car feels weird!
  221. Sticky Clutch Problem after replacing
  222. w59 transmission on sc300?
  223. 1000cc injectors
  224. time to re do my exhaust...HELP!!!
  225. soarer r154 leak
  226. PLEASE help! gotta get my sc running ASAP!
  227. Fuel leak
  228. Need help with car
  229. A/C Light blinking
  230. sc4 power steering removal
  231. Hard shifts from park to drive
  232. will it work?
  233. How to tighten and lock Metal cable ties?
  234. Tuning /maintenance help?!?
  235. Take a look at my frayed timing belt.
  236. Distributor screws - do not remove
  237. Need help quickly!!!
  238. HELP Code 78 Sc300
  239. ??Broken exhaust thread questions??
  240. Turbo coolant fitting blew
  241. 1jzgte Soarer Swap into 1992 SC300 Wiring issues...
  242. sc300 rear diff ?lsd
  243. Drive shaft questions
  244. injecter not getting signal no fire
  245. Aluminum Radiator
  246. Gas tank pressure
  247. Universal Intercooler and piping for 1jzgte in sc300 HELP PLEASE!
  248. W58 Transmission Filll Bolt
  249. drivetrain vibration solved...well i hope so anyways, video inside.
  250. Project going down hill :( help
