bay area oakland 92 sc300 5speed e brake
Hello clublexus quick question when I lift the e brake feels like theres no more pad left anybody know DIY info?
Thinking about going to pick n pull n give it a try on some used sc's
But anything will help
Anybody in the bay or oakland area got sc300/400 drop some photos n how do you upload picks I would like to show off mine
take the wheel off, and turn the rotor so that one of the holes that you can see through on the passenger side is at about 5 o clock, and the driver side at 7 o clock, if you look through the hole you'll be able to see a little gear, spin it with a flat head screwdriver or something to tighten the hand brake boots. it should be extremely close to the brake disc, adjust it so it touches the brake disc and you can barely turn the disc, then turn it once turn back. it's a bit of a trial and error
sc300
Thank you I figured something out as I went to pick n pull to play around with a sc400
Pretty much the same
I will do it tomorrow I was wondering how to put up picks as I will show step for step
A DIY
92 sc300 5speed magnaflow exhaust
A DIY
