View Full Version : IS F (2008-2014)
- Sagging Rear End (Suspension)
- Lexus IS F $125 Raffle Car Transformed for the Track
- ISF brembo brakes !!
- What after the isf
- Static vs Air
- Winter tire/wheel setup for the F
- Failed smog w/ CEL P0102 - next steps?
- Anyone recommend where to get tpms for is f
- Losing brake fluid but NOT leaking externally
- Cast vs forged wheels, cheap vs expensive
- Trunk lip paint?
- Anyone with RR-Racing quad exhaust with carbon fiber tips
- Anyone here use NGK Ruthenium spark plugs?
- Outstanding customer service!
- Recommended exhaust leak fix
- Trouble Codes C1201 and P0986
- O2 sensor
- start up warning beeps/ sounds
- Engine Idles Rough/Low and Stalls On Occasion
- Thoughts on white interior?
- Any ISF, RCF , GSF Owners interested in this Car meet (Michigan) ?
- ISF spark plug blow out
- Should I buy this 2008 is-f look for 20k?
- Isf overheat on track
- Repair cracked wheel spoke or replace wheel?
- Just got my ISF and IS300 in the same week earlier this year
- P0012 & P0022 intake cam motor replacement and spin test video.
- Need Help installing LED steering wheel
- Search for 2012+ IS F: where are they?
- Seibon quality?
- Differential plug torque
- Check System Light on
- Current Street Name?
- Just wrecked
- 2011 Lexus IS Navigation headunit Pinouts
- Remanufactured AC Compressor!!
- Would u send this part back if the box showed up as this? From discountpartsmonster.c
- TOM'S rep diffuser...(rep problems lol)
- Buying used 2008 Lexus ISF, but VIN shows no service history
- OBD2 data on nav screen?
- Seriously need help fellas
- More IS-F rumors
- I'm looking at a 2008 Lexus ISF with 100k miles for $19900
- RR Racing ISF vs ZR1 and M4 GTS
- Is this overpriced?
- Control Arm Bushing Figs or RR Racing
- Denso ebay coils..
- Shift light indicator
- Hard Brake pedal
- Just found out RPF1s come in 19s?!
- Knocking noise in suspension
- RRRacing USRS installed now my front end rattles (poor installation maybe)
- Thinking about selling my 2011 isf supercharged
- RR Racing R&T Coilover noise
- Has anyone installed figs engine mounts?
- A low mileage 2013.... on Carvana?
- ISF/GSF/RCF car meet (July) - Calgary, Alberta (former/non F car owners welcome)
- Fellas with 20" wheels: what is your suspension set up?? set up??
- Custom alignment with Swift lowering springs?
- Little help gentlemen
- AFS fuse question
- Help needed with after market front bumper mod
- with great sadness im listing my isf for sale! Socal
- Need help finding Canadian vendor that sell Project mu brake pads
- Installing Borla Catback tonight! Much excite!
- Drive Shaft vibration
- BC BR coils only offering extreme drop now? Need help with spring rates...
- RR Racing new “basic” supercharger kit
- Spark Plug with no gap? Potential issue??
- CL Members Thoughts ISF Purchase
- Petition to stop owners from selling cars
- Radiator & coolant leak at the track but normal temp
- Engine tear down info, anyone doing a build, have the intake off?
- I too am moving on
- Good yellow H11 LED bulbs for OEM foglights?
- How many 2014’s are on the road does anyone know?
- Guess, I'm Movin' On!
- Headlight Low Beam Replacement
- Sliding Causing Transmission Problem?
- RR Racing Chassis Brace
- Latest Lexus reprogramming recall for tuned intake?
- Redye of white leather
- Suggestions please on coilovers
- Trans downshifting is slow
- IS-F oil changes at home...
- exhaust + flex pipe
- Upgraded Transmission Cooler Relocation and duct work...
- On ISF Factory Spring Rates
- Test Drive Difficulties
- Cell Code Issue – All Opinions Welcome!
- DIY: 08-14 ISF Valley Plate/Heat Exchanger
- Techstream unlock all door with handle sensor
- Air con condenser
- Aftermarket extended exhaust melting replica diffusers?
- Rant: Keep modding the F at 100k or sell/upgrade?
- Legit ISF axleback exhaust without cutting OEM?
- Lexus ISF door latch
- "Wheel of Fortune" rattle when decelerating\coasting from ~35mph
- 2008- Radiator Cracked- add me to the list
- OEM style spoiler painted or carbon fiber
- Push pin clips for instrument cluster
- SRS, question.. does anyone know
- Lexus ISF CCSP on Best Motoring
- PDF for service manual?
- Rev Limit Discussion
- Data Logging VIA Bluetooth OBDII Reader and App
- 2008 Lexus ISF - C1246 Code
- Changing out ISF headlights
- Nengun Performance Wald (copy) Diffuser
- Front Bumper Cover Alignment
- Lexus meet in Richmond, VA this Saturday June 1st.
- Weird squeaking noise when going to reverse
- Yokohama ADVAN Sport v105 on sallllle
- RR racing Power Package and Joe Z Exhaust
- F Car's Meet & Greet Mooresville, NC June, 22, 2019
- Pictures of my ISF after professionally detailed
- Cracked manifold repair
- From the ISF to RCF first track day.
- Seat brand advice
- Metal shaving in rear differential
- Dynapack vs Dynojet
- JoeZ Quad Tips with Wald Diffuser
- airbag notice
- X Force quad tips?
- ISF Electrical - Blowing 10 amp Dome Fuse
- 2010/2011 ISF rims on a 2015 GS350 F-sport?
- Found my seat in the lower reclined position
- New suspension parts
- ISF system codes- need fresh eyes on this
- Flashback Friday: CL Forum Members Show Off Their IS Fs
- Will the RC-F overhead lights fit in the IS-F?
- RR Racing Performance Upgrade Package
- Neiman Marcus wheels value?
- Hey Guys Quick Question!!
- Imprint left behind on wheel after alignment? (Need some advice)
- The ISF is soo UNIQUE I LOVE it
- Cusco vs OS giken LSD
- Anyone have Center Driveshaft Bearing issues?
- 08 isf goodies!
- brake fluid recommendation for daily driver
- Dealer radiator replacement cost?
- Slow vibration in manual mode
- Sold ISF for Supra but got tired of waiting llol
- Part Help
- My Lexus ISF Exhaust Sound (Full Bolt-On)
- gsf or rcf
- PowerStop Z26 Brake Pads
- Need Help With Strut Mount Nut Size
- Bc coilovers (er versions) -
- Own a 2010 ISF. Considering Upgrading to a 2011+... is it worth it?
- New to forum
- ISF KWv3 -- what spring rates do the ship with?
- ISF 2011 does not work ( Engine code )
- RR Racing R&T Coilovers or Kw V3?
- Both rear door mids not working
- Dead zone on gas pedal
- Wtb: PTS joez true dual catback exhaust
- Service / Repair Manual with full diagrams & parts catalog
- How much hp gain with only headers and tune (keep stock exhaust)
- Does anyone drive their isf in manual all the time ??
- Windshield Wiper Smear
- Isf suspensions
- RR racing o2 conditioner
- Brake Replacement Recommendation
- Looking to buy an IS F in the near future.
- Door and other interior rattles
- AC pulley wobbly, shredding belts, replaceable?
- Repaint or Wrap the car
- Steering wheel re-wrap service
- Paddle Shifters Caused Serpentine belt to snap?
- Is my 2010 differential LSD?
- Isf upgrades
- extended warranty
- FBO IS-F vs Dodge Viper
- Ppe o2 simulator how to
- How to remove/replace the IS F upper grille [pictorial]
- Engine brake down a hill
- Checking the time on my ISF
- Installing Figs rear diff bushings... have some questions
- How bad is this rust?
- Performance Opinion
- Anyone have an ISF for sale?
- I want more power, but I don't want more noise
- Not starting
- Safest Way To Remove Tail Light Tint WITHOUT Damaging the plastic?
- Size of our speakers??
- Where is our vacuum line located??
- ISF stalled out
- New ISF!! Should I get a PPI?
- Buying advise 2008
- 2010 ISF Valley Plate Fix
- Its been an amazing journey goodbye my love.
- 2014 f
- Another high mile ISF found, 275k!
- 2012 Twin Turbo IS F is Just Fine in Black
- Need Advice - Body Shop
- 2010 Lexus ISF - bluetooth streaming does not work. Using iOS11. Any fix for this?
- Engine Cover Delete
- F-Sport rear sway end links
- Need a help to identify a part
- Headers
- Engine clicking sounds
- Pics of 19x9.5+45 square Rays Gram Lights 57CR
- location
- Valley plate coolant leak
- Backup Monitor Guide-Lines
- KW coilover V3 issues
- 50 / 70° F ambient temp, how long for engine oil temp to....
- Downshift paddle not working - 08 ISF
- People with a custom exhaust please chime in!
- Killer IS-F Steering Angle
- Fog Light Issue
- This weekend
- Where to buy black CF center console kit
- X force Exhaust Tips
- Startup - cd spin noise - isf 2013
- Esprit Japan front bumper, anyone does this yet?
- Atlanta F Meet & Mountain Cruise
- Loss of Acceleration - Code C1201
- Gt500 rotors on lexus is f brakes
- 2 Many Fs
- VSC and low beam headlight issue - could Relay block 2 be connected?
- Needle in the Haystack 08 ISF - What Do You Think It's Worth?
- New front's 235's/40/19's + FIGS Toe in Bushings (80)
- ISF Front Wheel Hub Replacement
- Duralast gold pads question
- Pulling trigger on coilovers, pls look over my choice
- Removing bumpers and bumper tabs
- Weight of Stock ISF driveshaft?
- ISF posted up at Cars and Coffee Palm Beach!
- 530hp/ 500tq Nitrous ISF 10.70 1/4 @ 132mph run in Puerto Rico with slips
- i don't think it'll buff out
- Most miles before valley coolant leak?
- Having a problem that's hard to describe
- JOE Z Exhaust Gasket
- Some of my Fav ISF videos, post up your fav videos
- RR tuning tune/air intake install
- What’s needed to install iPod interface kit?
- Should I buy this 2011 ISF?
- Should I get this 2011 ISF?
- P0420 code
- Cracked Radiator 2008 IS-F
- FYI RRRACING S/C IS250 makes 410 crank Hp 360whp
- Vibration when Idling - Radiator Fans?
- ISF Transmission Pull / RMS leaking
- Squeeking/creaking seat.
- Keep your rubbers lubed!
- Staggered 18s question
- 2008 Lowering springs question
- Lexus ISF or Infiniti Q50 RS400
