Push pin clips for instrument cluster
Can anyone tell me the push pin clip part number or size for the two under the dash that holds the instrument cluster trim on? I just noticed that mine were missing (probably were not installed when they did my air bag recall a few years ago). Trying to find the part number but can’t seem to find it!!
thanks in advance.
thanks in advance.
Just went to the dealer. Would not give me a size. Says both clips are $5...say whaaaaaat?....they're plastic push pin clips...lol
Tech Info Resource
This is what is in my car. Part number is 90467-05158. MSRP is $1.51 each. Online Lexus is $1.09. Clips n' Fasteners does not carry this part number, nor does Italfasteners.com. They are my typical go to for clips. The top photo isn't exactly clear - there is a cross point driver in the clip so you can unscrew it to remove. It pushes in on the assembly line.
Whoa! Thanks Lobux!
So I just placed these in yesterday and they don't seem to fasten that tightly. It gets to a point where the screw just spins in place...maybe i didn't need it after all.
Thanks again anyway Lobux.
Tech Info Resource
You just push the screw in. You only use a screwdriver to remove them. They're designed to work that way to make installation on the assembly line quick.
