Custom alignment with Swift lowering springs?
Besides, you can only adjust toe easily. Everything else requires aftermarket parts to make changes. If you want to significantly reduce wear, get a better lower control arm rear bushing for the front end.
Thanks bro, took it to Pep Boys they said I should take it to Lexus because they don't have the proper equipment to do the alignment, something about adjusting the camber he told me.
I have aftermarket upper control arms with camber adjustment to get it back into specifications after lowering it
panda327
Jun 16, 2009 12:06 AM
