ISF 2011 does not work ( Engine code )
Old Apr 29, 2019 | 09:57 AM
Majid1000's Avatar
Majid1000
Default does not work
Old Apr 29, 2019 | 10:16 AM
Wh0pp3r's Avatar
Wh0pp3r
is it all the codes or just the p0087 that you are worried about?
Old Apr 29, 2019 | 10:36 AM
Majid1000's Avatar
Majid1000
my problem with P0087 and p062D
because system too lean code does not affect
Old Apr 29, 2019 | 11:22 AM
Wh0pp3r's Avatar
Wh0pp3r
P062D-
Fuel Injector Driver Circuit Performance (Bank 1) - Manual and Automatic Transmission
Possible CausesSetting Conditions
  • Fuel injector for driver injector assembly has failed
  • Engine room No. 2 fuse in Junction Block has failed
  • ECM has failed
Engine cranking; system voltage more than 8.50v and the ECM did not detect any Bank 1 INJ1 or INJ2 signals for 10 engine revolutions. The D-4S system has two fuel injection methods. One is the in-cylinder direct injection method that directly injects pressurized fuel into the combustion chamber. The other is the intake port injection method. The ECM determines which fuel injection method to use in accordance with the engine conditions. For the in-cylinder direction injection method, the 2 injector drivers (EDU) in the engine room operate the fuel injectors (for direction injection) at high speeds.
Malfunction Indicator Lamp (Manual and Automatic Transmission)Malfunction Indicator Lamp
The Malfunction Indicator Lamp (MIL) alerts the driver that the Engine Control Module (ECM) or Powertrain Control Module (PCM) has detected an OBD II emission-related component or system fault. When this type of malfunction occurs, an OBD II Diagnostic Trouble Code (DTC) will be set by the PCM. The MIL is located on the instrument cluster and is labeled CHECK ENGINE, SERVICE ENGINE SOON, or is identified with an ISO standard engine symbol (i.e., a picture of an engine).
Bulb Test
Each time the ignition switch is turned to the "on" position, the MIL indicator is illuminated for about 3 seconds (which is a function of the PCM)
MIL Lamp-On Message
Each time the PCM detects an Emissions related fault, the MIL is illuminated to inform the driver that the vehicle needs to be taken in for service.P0087 Fuel Rail / System Pressure Too Low - Manual and Automatic Transmission
P0087 Possible Causes
  • Fuel pressure regulator has failed
  • Fuel pump has failed
  • Fuel pipe problem (high pressure side fuel pump injector)
  • Fuel pipe problem (fuel tank - high pressure side fuel pump)
  • Fuel pressure sensor has failed
  • High pressure side fuel pump has failed
  • Fuel injector has failed
  • Fuel pressure sensor connector is damaged (check pins for damage, moisture)
  • Fuel relief valve has failed
  • ECM has failed
Engine running; then after the ECM commanded the High Pressure Fuel Pump to open the spill valve, the ECM detected the difference in the actual and target fuel pressure was less than -5 MPa. The cylinder fuel injection method high-pressure fuel system consists of the spill control valve, pump plunger and check valve. The spill control valve adjusts the discharge amount of the high-pressure fuel. The pump plunger operated by the camshaft, pressurizes fuel and the check valve mechanically opens and closes the line to the fuel delivery pipe. The fuel pump (high pressure) is located) in the Bank 1 cylinder head cover. It is driven by the cam located at the rear end of the intake camshaft. When the plunger moves up and down by the camshaft rotations, it pressurizes the fuel.
Bulb Test
MIL Lamp-On Message
Stingraygt
IS F (2008-2014)
Jan 16, 2018 02:10 PM
TriniLex
Feb 18, 2017 07:42 AM
Max Power
Aug 24, 2009 04:06 PM
Herm
Oct 31, 2007 06:00 AM
