View Full Version : Suspension and Brakes
- Tanabe coilovers
- just installed my trd sways WOW
- A few strut bars
- Question????????????
- Best rear drilled rotors for GS?
- Help with steering ECU
- B&g Springs
- Any good deals on Brake Master Cylinder?
- Yes
- Tein Flex Noise Question
- Rubbing: Lowering with 20's
- Thoughts on Used Tein CS Coilovers
- vogtland springs
- help with suspension please!
- TT supra brakes rear
- Clear Front Side Maker
- pics of daizen springs drop
- Alignment with new wheels?
- My observations: 20" Rim ride quality
- H&R Springs
- 10 mm spacers: where to buy
- Help with alignment- Eibach Pro Kit
- should i cut my springs???
- which year has suspension problem?
- The stock GS brakes suck? or just mine?
- 1998 GS shock / spring suggestions
- You like glowing red brakes on a GS400?
- Lowering advice
- Softest suspension: CS or L-Tuned?
- gs300 brake pads
- Is it possible to resurface slotted rotors?
- Where to buy spacers?
- Spacer Q: Grinding 10mm spacers to 7.5 mm
- teins flex
- Bilstien PSS or Apexi WS Coilovers?
- springs
- Supra TT brake question
- best springs
- THUD noise after installing HKS LS+ coilovers
- Airbags? Experiences anyone?
- Camber Kit...ETA!??
- Does it take longer to install coilovers than S/S on GS430?
- My first suspension mod.
- Will any big brake kit fit me?
- Anyone heard of D2 coilovers for Lexus?
- How low without camber kit?
- alignment w/l-tuned
- L-tuned Spring/Shocks Problem
- Front suspension change procedure
- Have had the car 3 weeks, NOT enjoying the car already.....
- L tune steering ECU
- How much drop with L-tuned?
- tein CS
- Aftermarket Struts with L-Tuned Springs
- Cheapest place for L-tuned
- TOMS Front Lower Chassis Brace Installed
- HKS LS+ coilovers and Defi boost gauge installed....
- Bilstein PSS Coil-Over Kit
- Installing Tein Flex
- sway bars
- Tein S-tech spiings help!!!
- Rotora Steel brake lines....are these good?
- BIG BRAKE questions
- A friend of mine is selling his IS OEM rims...
- TEIN CS, Daizen sways installed!!!
- question on Tien Springs..
- E brake, VSC on/off, and ABS indicators ON!!!!! Help
- Where to install the EDFC controller
- JIC coilover review
- done........rims and brakes......56k warning
- Question about Tein Ha's (turn clockwise or counter clockwise to change stiffness??)
- What gap did you set between your tire and fender with Tein Flex setup?
- mounting EDFC
- help: Post before and after pics of your suspension drop
- Happy Thanksgiving!! Do I have to raise the car to install the TRD STB..Help please..
- question about dropping...
- Pic Request: L-Tuned sus on 19"/20"
- what are some good suspension products out there?
- VOGTLAND springs
- how I spent my Saturday...pics included
- Installing the OEM front 2-pot calipers in the back?
- supra brake question
- L-Tuned ECU Installed
- Warranty Issue with aftermarket part installed
- TRD front strut tower bar?
- eibach or ltuned springs
- Supra Tt Rear
- For those with the Tein Flex, can you still have the TRD stb on the shock towers?
- Would adding Daizen sways void the warranty..if yes woudl it be susp warranty only
- supra brakes and stock rims
- GS400(slow) is no slow dog..A bit surprised today
- PIC: SUPRA BRAKES and TEIN FLEX/EDFC
- OK..Just been told that I can have new TRD shocks and struts..My budget is very tight
- bilstein and eibach
- Are Axxis Pads good for our car?
- what do u think of trd brake upgrades?
- So L-tuned discontinued..Can I get eibach instead..can I change just springs for now?
- GS4 Newbie..been searching forums every night..got some ?s
- Best price for Tein Flex?
- Should I do wheels or big brakes first?
- UGO Front STB Arrived, Installed, Tested
- Tein S-tech Springs Fit Gs300?
- tools needed for brake job
- Bilstein PSS backordered
- New Rotora Brake Rotor setup
- is this a bad rack and pinion????
- question about stock Front brakes....
- Suggestions on caliper painting
- L-Tuned Steering ECU-Discontinued?
- who has a lowered GS?
- Are the TRD sway bars and strut braces worth it?
- Is L-Tuned the Same as KYB?
- Lower Control Brace Question?
- Opinion..25mm spacers on the rear
- Supra TT Brakes Installed- Pictures
- supra brake upgrade
- ? about lowering
- UGO Front STB on Stock Suspension
- supra upgrade pad spacers
- 2003 GS300 Sport Design Suspension Setup
- L-tuned struts?
- Finally, L-tuned struts w/ eibach springs getting mounted on Wed.
- Another Supra Brake Upgrade Thread w/ PIC
- bleeding of brakes
- Porterfield R4S Pads?
- brakes (how much brake fluid do I need?)
- Tein CS and TEIN EDFC Combo
- supra upgrade
- traction in rain with new sways
- Tein S-tech pics?
- Got da socks on!
- If I want my TEIN CS Coilovers to ride like stock...
- Random Brake Noise
- Daizen Sways, TRD Sways, OR Toms Sways :Which is Recommended?
- The definitive Weight Reduction list..........
- Warped Rotors
- Anybody here with LS 430 brakes?
- New GS3 w/ front end vibration
- Strut Bar
- How many GS owners have uneven rear tire wear?...
- Is a brake upgrade really required with upsized wheels?
- Will my GS300 suspension look funny with 19" rims?
- Bouncing around like a rabbit in heat.
- My new DSR Monoblock big brakes!
- Coilovers
- Has anyone else tried the L-tuned struts w/ Eibach Lowering Springs?
- Problem - Groove in brake rotors
- Super suspension
- Adjusting Tein Coilovers
- Best deal on Bilsteins????
- Supra TT brake upgrade ?
- TRD brake system?
- cross drilled and slotted
- How doI remove some rust on my brakes?
- Need advice on ECU for steering
- does anyone has outside wear on front tires
- L-Sportline Suspension: anyone had it before?
- suspension suggestions
- Brake Pads
- comparing springs
- Track test Sway Bars Results
- Tein HA , English installation manual !!! where do i get it!! help!
- tein springs
- What do you guys think of these springs?
- front STB on '03 430
- Specs needed for proper alignment. Purchased L-tuned Struts & Eibach Springs
- Difference between Pro and ISD ceramic brakes
- how miles do you have on your L-tuned suspension
- Whats the life expectancy of the L-tuned struts
- STRUT BAR Suggestions
- Shocks Question
- Need Help Guys (rattling from rear after brake job)
- coilover upkeep
- Sportdesign suspension question
- How Low is Everyone
- will eibach spring & kyb shock from MKIV TT work?
- Tein's Stuck--
- "LEXUS" machined brake calipers
- EBC Green stuff V4 Brake pads
- help gs400 owners (steering feels loose and wheel trembles)
- TRD Sways...is there 2 different kinds?
- Axxis part #'s
- Camber Kit???????
- Increased tire wear
- wheel offsets
- TRD Sportivo Sways
- Brake Pedal Ratling
- Cannot remove one of my wheels!!
- sways
- Baer EradiSpeed+1 Rotors
- Pics After Daizen Springs & Sways
- question on 19in
- What big brake kit do you have?
- Big brake upgrades
- Why Big Brakes?
- Groaning noise from Driver side front suspension
- Will Low profile tire Strain the …!!?
- Good steering fluid ??
- Should I spend the extra $$ for coilovers?
- Alignment issues?
- Wheel spacers AND front caliper clearance?
- 2000GS4 Ride Question
- brake comparison
- ? about going bigger rims
- SUSPENSION: I'm confused.
- can gs4 be lower with 20's
- L-tunes or Bilsteins
- Eibach L Tuned Suspension...from Rod Millen...will this damage my car?
- SC430 BigBrake kit does it fit on GS?
- ** TRD Suspension Bushings **
- Lowering my GS300
- semi-metallic vs. ceramic brake pads
- Those with painted OEM calipers
- Tom's Racing Lower arm strengthening plate / upper arm support bracket
- flashgordon's #004 TTGS
- supra brake uprade offset
- Best Handling GS On Clublexus?
- Question about brake fluid.
- Axxis Metal Master brake pads + OEM rotors
- differences between TEIN models
- serious problem..
- Teaser Shots!!!
- brakes
- GS400 front end rattle
- L-Tuned & KYB
- How to install the TRD STB
- brakes
- tein reliability?
- L-Tuned Shock leaking oil
- center of gravity??
- springs and shocks
- Why does my car shake while breaking?
- average price
- upgrading rotors and pads...any advice?
- Brakes Scraping
- The Race is On
- PART# for TRD swaybars ?
- Finally changed my Teins...
- Quick lowering question..
- 94 GS300 -- about to lower but need advice!!!
- stock 16" rims...........99.....widest tire?
- Camber kits for GS4 and 3...in sept.
- **Brake rotors choice?**
- front strut bar for 1st gen gs3
- Recommendations for Camber
- Front Seats
- tire wobbles at 60mph??
- upgraded steering
- is alignment needed?
