Thanks for the info. Also, I'm kinda hesitant on painting my rotor hub section and calipers as I have never done this before. Is there a thread regarding step by step procedures to do this?
You can also remove the rust easily with a Dremel or similar hand tool. Use the rotary brush attachment. I did it on mine recently. Took 5 mins per rotor.
I used the Stainless Steel Brush (530) and it worked fine. However, Dremel recommends the Carbon Steel Brushed for removing rust and polishing metal (Eg: 428) .
I've also used a brush attachment for a standard drill to remove rust from a muffler in th epast. I don't see why you couldn't use it in this case as well. The advantage of a Dremel would be being able to get into the nooks, crannies and polishing.
