- Stereo cutting out passenger side
- LOVE/Hate this Website!?
- 1UZFE Cam Regrind
- 91 Ls400 won't start
- w58 swap info needed
- Where to buy front clear markers? 95 LS400
- 93 ls400 hids not lighting up
- clean 1991 LS400 at local jy
- 1999 LS400 Upper Loud Clunk
- For discussion - Gear position indicator
- No heat and heater control valve not functioning
- UCF10 Rocker Panel Repair/Replace?
- Sunroof Play
- Starting to hate my lex. Clinate cotrol issue and engine bucking
- engine vibration at 1000, 1400 and 2200?
- Woot finally installed momo steering wheel ls400 1990 pics included!
- Need Tire Suggestions for Stock 94 LS400 Wheels!
- Humming/Whirring Sound upon acceleration
- 1995 Lexus LS400 shortlived :/
- Help! no heat.
- Wiring Harness for 1997 LS 400
- Lower Radiator Sensor?
- 97' LS Tranny issue
- What is a fair price for a 1999 LS400?
- 1998 Where do knock sensor wires connect at ECU
- intro and new ucf20 beater
- i need your help
- Timing Belt off, is it okay to rotate Cam?
- Jordanf's UCF10
- 93 LS400 Traction Control Issues
- stock 2000 LS 400 toe alignment specs?
- Picked up a UCF10
- 1999 ls400
- Other Lexus steering wheels that fit LS400
- LS400 Exhaust
- SAFC installed, questions...
- I just purchased a 1996 LS400 with 218XXX Miles. Maintenance Advice? I have a list!
- Water in the trunk
- Steering wheel swap with radio controls?
- It should be #2 at least...............
- Transmission pan gasket and stuff?
- Rear Bumper replace or repair
- Oil drip coming from rear of Diffrential 94 LS400
- Upper Control Arms Great Deal Currently (1/27/14)
- Recent 1st time owner '93 LS400
- Just ordered a Mechman 320A alternator...
- Can someone explain to me what is the point of an RCA kit?
- Brake Dust Shields?
- 93 LS400 Tensioner Idler Pulley fit a 96 ?
- Might need a new trans...
- ls 400 idle issues
- First Time Lexus Owner 92 LS400
- LS won't start but plays a tune?
- what can I get for my 95 LS400
- 1997 LS 400 Will not start
- 1995 Ls400 tire size
- Sparks from Battery! Help?
- really bad oil smoke at cold start
- 2000 ls400..strange pcv valve.
- LS400 piggyback/standalone
- Fuse blown
- Difference between 1ls and 2ls transmission mount
- abs computer, ls/gs same?
- 99 LS400 navigation screen problem at cold start ...
- ayuda lexus ls 400 1992
- Thinking of selling 2000 LS 400 Millennium
- Black Floor Mats for 1999 LS400
- DIY ipod drawer retrofit for 1 DIN HU
- 1994 ls 400
- How many independent ECUs in LS400?
- Used LS400 question
- 1uz missing
- Is It Possible To Switch Headlamps From Halogen To Xenon?
- LS400 90 water temp sensor problem
- Steering Purr
- Factory Air suspension to factory springs and visa versa
- Ls400 please help - starter?
- Is this a good WATER PUMP/TIMING BELT KIT
- Bought New LS 400, Have Some Questions.
- A little advise on popping dome lens
- Drivers Seat Fixxed!!!
- Wheel Specs
- vsc. Abs no radio no keyless no dome light randonly
- San Diego wheel service, what shop?
- 1997 LS400 Timing belt possibly skipped teeth
- Polished or all black? (Wheels)
- Ripple Test Results / Symptoms
- LS 400 total production figures
- intermitent violent surge
- Profiled again?
- Rear seats...so small!
- ls400 uca replacement :(
- How to get rid of red warning light, low washer fluid
- 96 LS400 Power Steering Fluid Leak
- Help! My 1998 ucf21 is possessed!
- Passenger Air vent problems!
- Where do you buy your parts?
- New Toyota Oil Cahnge Interval - 10K miles
- Just bought a 1997 LS400 with 111,000 miles any maintenance advise to start?
- 1994 LS400 Climate Control LCD Question
- Do I have air in the coolant system?
- Mk4 Supra seat in my UCF10
- seat back/map pocket reinstall
- Keyfob replacement 1994 LS 400
- 1993 Lexus can I use any ecu with cali emissions?
- Headlight Issues
- KYB GR-2S--How long do they last?
- LS400 Engine Cover
- 98 LS400 good buy?
- 1994 ls 400 ect
- New Strut Rod Bushings on my Black 99
- 1996 LS400 leaking oil - PS reservoir O-ring to vane pump
- '00 ls400, turns over, no start, battery issues
- '99 LS400 Catalytic converter
- No more tape adaptor!
- Transmission Pan
- 1st Gen Key Remote
- Anyone seen Ls400 with ccw replica
- New member, Lots of issues.
- master window switch will roll down but not up passenger window help!
- white smoke on startup!
- 1991 antenna function?
- removing rear phone antenna? 94'
- Best aftermarket radiator for 97 LS 400
- '93 ride height query
- 1997 LS400, Annoying Noise form engine/transmission
- List of repairs that go well together:
- Front Upper Control Arm Bushing
- Help!
- Rattle Fight front fender
- Better alignment than Lexus suggests
- Power Window Programming
- Will Poly Sway Bar Bushing, Reduce Sway?
- 1st Gen Interior Lighting
- Adding oem drl relay
- Door Ajar Switches
- 1992 LS400 DUAL Climate LCD
- steering wheel movement 1994 ls400
- Please help me out Guys- car shuts off
- Hello!
- Thank you all!
- 1990 ls400 160+k
- New Ls400 Silver EyeBrows
- 430/400 seatbelts interchangeable
- 1997 LS400 170K miles, Coolant Leaks, alternator not charging, ...
- new here, whistling noise, HELP
- Code 13, and yes I have searched the forums. THIS MAKES NO SENSE!!!
- Am I looking at ECU related issue, fluke, or something else?
- Starting Issue Click and then dead
- 1998 LS400 rpm (engine speed) at 60 & 70 mph
- Fuga de agua ,
- i just bought a 1994 LexusLS400.....i need advice/input!
- Partial outage
- ls400 ac not blowing at all
- Blown 80A fuse now issues
- Ignition key does not turn
- Are Toyota Steering wheels interchangable?
- Timing Belt Done - Is my car knocking?
- Thinking about purchasing a '94 LS400
- DYNO my Stock 1994 LS400
- Rear spring & damper removal
- reset immobiliser
- new member from South Carolina... HELP
- Can this be fixed?
- Can someone confirm this site?
- New member from Canada
- 2000 LS400 problem with steering wheel adjust
- Anyone had a climate control go bad? NOT the typical LCD bleedout
- recommend me a replacement for PB Blaster
- 94-97 fit1st gen
- jdm vs american seatbelts
- contectores del sensor radiador
- RCR tail lights on a UCF10
- Recently acquired LS400 ~ some questions
- Sensor on radiator
- Replacing Cam Seals, please help?
- UCF20 - Rear Suspension Typical bushings etc???
- Idler pulley and Tensioner Pulley for 1996 LS400
- Audio Service Mode revisited
- Lexus / Toyota - shared parts
- another offset help thread
- 99 ls400 wiring harness
- l990 Ls400 throttle problems
- 96 vs 99 Timing belt change
- Buying a donor car for my LS400
- 94 LS400 Suroof Assembly Removal
- Fitting UCF20/2LS rear adjustable absorbers to UCF10/1LS
- Cooling fan bracket
- electrical problem
- A few problems- steering, memory and lights
- The Night before Christmas
- simple abs bypass?
- Ayuda ubicacion caja fusibles ls 400 1992 electroventiladores
- Rear seat removal
- Coil Conversion Process - Post Swap ABS & TRAC LIGHTS
- Water in car during heavy rain, 1995 LS400
- Check engine light and Trac light flashing
- 97 LS w/nakamichi - no sound - how do I troubleshoot amp?
- Loose steering
- Rear speakers not working after new head unit install
- 1997 LS400 256k miles and heat takes a long time to get working?
- How does your car idle?
- electro ventiladores
- 97 LS400: Under-dash fuel-door release broken
- Power Steering Replaced
- Can anyone identify this?
- Time to retire the LS?
- A few suspension (and brakes) questions (first gen ls400):
- What happened to OEM list left here by LScowboy?
- Megan parts
- Transmission cooling hoses
- 98 LS400 Niggles
- What would I be getting myself into...?
- '92 LS 400 Knock Sensor
- front wheel bearing replacement
- Fitment Help
- fixed smoking and powersteering leak.
- How to Remove Console PRNDL Bulb
- Valve cover gasket tips! (especially for DIY)
- Need help.. Hessitation under hard acceleration
- OEM rain visors
- Need a part # and advice
- I thought this was an interesting find....
- Introduction
- PLEASE HELP 90 LS400 stalling
- 1993 LS400 Problems. Please HELP!
- Weir Oil leak Hoping to Find source Pics attached
- Life of a Fan Clutch
- Help! — Locked out of trunk
- tilt steering noise fixed
- 1995 ls400 trac off light is blinking slowly
- Stripped fan clutch nut
- 95 ls400 with 3rd gear light on in drive
- Planning 1000 mile trip. Advice needed
- New Noise after Timing Belt Change - Ideas?
- 98-00 ls400 ocv filter change
- TRAC Code 43
- Driver Seat Sensor Switch
- TRAC Light Code Look up
- Leather re-upholstery question
- Need part #s and links.
- Help with speedo and trans issues
- Neutral saftey switch bypass?
- Possible upgrade.
- 1st Lexus
- 99 LS Throttle Body question...?
- EXample of what clean looks like - 95 with 112k
- 98-00 mirrors on a 95-97...
- Audio slightly upgraded - happy ending
- 90-94 Aftermarket Suspension Arms
