Cooling fan bracket
With reference to by post https://www.clublexus.com/forums/8296409-post12.html I came across Aisin FBT-001.
What are the chances that Aisin FBT-001 cooling fan bracket could be OEM bracket?
http://aisin.mycarparts.net/products..._id=2511870759
If that is Aisin == OEM, then it should be good.
Be careful, it seems that many aftermarket versions of this part are not quite right. See
https://www.clublexus.com/forums/6310086-post17.html
Me in 2011, for my '91 LS400 with ~170k miles:
"I replaced my fan bracket last week (search for details) and had similar problems with the Dorman 300-804 fan bracket I bought.
(Great price there, BTW - $89 with free shipping; I paid $126 at local Kragen)
Differences I noticed between my original and the Dorman 300-804 are:
- Dorman was missing one tapped screw hole, but I did not notice missing that when it was reassembled. (it was not needed)
- The lug with the tapped hole coming in at around 7:00 in the picture (for the lower AC screw) was ~1/8" too long. Not too hard to jig-saw it off, and it worked fine after that, but I thought it was ridiculous that they could not copy the part accurately.
- The flange at around 4:00 in the picture was in the wrong place by about 1/4", making it impossible to seat the timing belt cover properly. After wrestling with it for a while and confirming the problem, I used a Dremel tool to cut down the t-belt cover to fit. Again, ridiculous that it was not an accurate copy."
I was in a bind at the time (I noticed this problem right before I was to leave on a 500 mile trip in the car, so needed to fix it ASAP with whatever I could get immediately). If you've got time, be careful on getting the right part. That Dorman 300-804 was supposed to be an exact copy, but apparently it was not.
