need some maintenance help
Old Aug 25, 2011 | 10:38 PM
2jznosht's Avatar
2jznosht
Default need some maintenance help
So Tuesday I purchased a 93 sc300 ran fine, but with high mileage I decided a refresh would be beneficial. As of now I have it pulled apart to replace the distributor o ring, dist cap /rotor, as well as the plugs and wires and thermostat. The starter is also on its way out so I will be replacing that also.
My questions are; where is the thermostat housing. I assume it should be easy to get to with the intake out. Second question, where is the starter exactly. Do I have to pull off the whole intake manifold to get to it? If so can someone give me a walkthrough on how to do it?
Old Aug 26, 2011 | 06:22 AM
cheez's Avatar
cheez
I believe if u take off the mud flap on the bottom of the car u will see the starter
Old Aug 26, 2011 | 07:00 AM
Nova's Avatar
Nova
the thermostat is on the back side of the water pump held on with 2 nuts. underneath the distributor
the starter is underneath the manifold on the drivers side. best way to get to it seems to be from underneath the car
Old Aug 26, 2011 | 07:24 AM
2jznosht's Avatar
2jznosht
Awesome thank you sir
Old Aug 26, 2011 | 07:33 AM
Nova's Avatar
Nova
No problem good luck
SCLexxxy
Dec 13, 2009 11:39 PM
92lexus
Maintenance
Jul 23, 2008 01:23 PM
Deftones84
Oct 10, 2005 01:05 PM
jersey1
Dec 1, 2003 05:16 PM
