Just got a 99 SC300
Old Aug 20, 2011 | 08:32 PM
tenshu2k's Avatar
tenshu2k
Default Just got a 99 SC300
Just bought a 99 SC300, 93k on the clock.
Not bad so far, but got a few qs/issues:
1. Throttle seems a to vibrate a bit, sometimes at idle. What could be causing this, and is this normal?
2. The AC Screen lighting is off for half of the screen. How can I fix this?
3. How heavy is the steering supposed to be, in comparison to a GS or ES? It seems heavy right now, I will check the PS fluid.
4. Ride quality: Suspension wise it was stiffer than I was expecting (I have an ES and a GS430). Is this expected, or should I check the shocks?
All in all though, happy to have a reliable commuter now.
Old Aug 20, 2011 | 08:37 PM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
Welcome to the SC community.
The backlighting is a burnt out bulb.
The throttle could be a number of things.
Check the power steering and report back with results. Maybe the rack and pinion bushings or the rack itself going out. Should turn quite easy. Maybe need a flush.
Let us know..
Old Aug 20, 2011 | 09:21 PM
Klaus's Avatar
Klaus
Steering is VERY light on this car
Old Aug 20, 2011 | 09:30 PM
xspsi6's Avatar
xspsi6
Mine is a bit heavy as well and so was my 95 sc300 so I thought it was normal?
Old Aug 20, 2011 | 10:49 PM
tenshu2k's Avatar
tenshu2k
Yeah, I've had a few lexuses, so I felt a little odd on the steering.
I have a 3G GS430, steering is pretty light in comparison, so something seems up.
What could the throttle thing be? My googling suggests transmission mounts or TPS.
And, pics to come soon. I hope to have a 2din navi in a week as soon as I decide on one and get the metra kit.
Old Aug 21, 2011 | 07:56 AM
iridebmx's Avatar
iridebmx
does the car have different wheels that stock? are they wide? when i got my wheels the car drove a tad different but it was a good different
Old Aug 21, 2011 | 11:01 AM
1J0Z SC's Avatar
1J0Z SC
Welcome! post some pictures!
Old Aug 21, 2011 | 12:05 PM
tenshu2k's Avatar
tenshu2k
wheels are stock. gonna take it in tomorrow to get checked out. may replace the tranny mounts.
Old Aug 21, 2011 | 12:09 PM
blacksc4's Avatar
blacksc4
welcome in! deff post some pics, as for just getting it, id do a tune up and flush fluids that way you know its all good and go from there, parts get expensive good luck
Old Aug 21, 2011 | 12:38 PM
97-SC300's Avatar
97-SC300
Yes the ride on a stock SC is stiffer than a stock ES300 (im assuming) and stiffer than a GS430 for sure.
Old Aug 21, 2011 | 04:01 PM
blacksc4's Avatar
blacksc4
btw if your in need of a TPS i have one for a sc400, idk if itll fit the sc300, its from a 94 sc400 if it matches u can get at it
Old Aug 21, 2011 | 11:13 PM
tenshu2k's Avatar
tenshu2k
Brakes seem really soft too after a bit more driving today.
Previous owner said the pads were were changed around 70k, I wonder whats up with them.
Old Aug 22, 2011 | 08:51 AM
Vampire222's Avatar
Vampire222
Man why'd u buy it with these problems, or did it come at a good price?
Old Aug 22, 2011 | 12:09 PM
tenshu2k's Avatar
tenshu2k
Price was decent, I'm also pretty nitpicky. It's not even something I noticed after test driving.
If theres the smallest thing wrong with my car I want it working. It will annoy the hell out of me if its not.
Old Aug 22, 2011 | 02:36 PM
Vampire222's Avatar
Vampire222
Well i'd check what suspension it has and if thats ok, mine has KYB shocks under it i found that out later, you might have a bit firmer upgraded / replaced suspension from a previous owner. And the PS pump is a common problem to die. If it's leaking check the seals or better yet rebuild / get a rebuild one.
The LCD sadly means either getting a replacement or getting it repaired by an electronics guy (unless ofcourse you can do it yourself) cause the internal stuff needs to be replaced.
The idle problem sounds like the TPS.
Hope you're having a good time with it apart from these small things.
Tommy2JZ
May 11, 2012 10:14 PM
Dai Kaiju
Apr 28, 2011 02:05 PM
SC_Edgar
Dec 22, 2009 05:24 PM
tritron
Jun 12, 2008 08:43 PM
