gte swap and camry throttle cable ??
Old Aug 15, 2011 | 07:43 PM
xspsi6's Avatar
xspsi6
Default gte swap and camry throttle cable ??
92-96 camry Is it a 4cyl or a v6?
Is an es300 one interchangeable?
I have read 4cyl but some are saying 6cyl works as well
Old Aug 15, 2011 | 07:53 PM
xspsi6's Avatar
xspsi6
Even better does anybody have a pic of one?
Old Aug 15, 2011 | 07:59 PM
sebasc300's Avatar
sebasc300
Here is one I have laying around, from a 4 cyl. Not the best pic but I hope it helps.
Old Aug 15, 2011 | 08:13 PM
cmh's Avatar
cmh
im pretty sure the camry came with both engines that yeAr range. just sayin
Old Aug 15, 2011 | 08:49 PM
xspsi6's Avatar
xspsi6
Yup that helps as mine looks just like that I just wanted to make sure I had the right one as it looks like I do so with that being said I can't see a difference between the 4 and 6 cyl cables.
Old Aug 15, 2011 | 10:00 PM
account2x's Avatar
account2x
do yourself a favor, buy the supra cable, camry cable can fit but the fitment leaves something to be desired.
Old Aug 15, 2011 | 10:04 PM
xspsi6's Avatar
xspsi6
How much does that run?
Old Aug 15, 2011 | 10:17 PM
account2x's Avatar
account2x
About $70.
Your SC400 cable may fit If you cut the rubber insulator at the end.
The issue with the camry cable is three-fold. 1st it's far too long. 2nd the length of wire between the bracket and the throttle is too short. 3rd it has less threading at the bracket meaning almost no slack adjustment.
Just so I'm clear. Because the cable doesn't have enough wire between the bracket and the tb you need to unbolt the bracket and move it. In a nutshell it doesn't even bolt-up correctly.
Old Aug 15, 2011 | 11:32 PM
soarer13oy's Avatar
soarer13oy
+1 mine looks pretty ugly. Its too long, but it works if you dont care.
Old Dec 28, 2011 | 02:55 AM
JeffTsai's Avatar
JeffTsai
Hey if any of you have this(camry 4cyl cable) out of the car. Can you measure how long it is for me? I just made a custom intake manifold and now the stupid supra throttle cable isn't long enough lol.
LexIS007
Jul 28, 2017 08:05 PM
nigel20b
IS - 1st Gen (2001-2005)
Dec 8, 2015 08:34 AM
ISjunky300
Jul 25, 2014 10:03 PM
WICKED 1
Oct 8, 2007 11:27 AM
yelloa3gti
Mar 29, 2007 07:18 PM
