Cant find hesitation source help!!!
Old Aug 16, 2011 | 12:19 AM
blacksc4's Avatar
blacksc4
Default Cant find hesitation source help!!!
got my car a year ago and i cnt figure out why it hesitates so much! it will run fine on start up but when i come to a red light the idle will be ok for about a minute then start dropping low and my dash will dim and brighten as it hesitates
CEL-none got a code 25 week ago "lean" so i changed the cooalnt temp sensor in hope, reset the ecu, no more CEl
ECU-Changed
spark plugs-New-gonna change again after seafoam
maf-Changed
air filter-New
fuel filter-New
12v mod-Done
check ground- ran new ground points
sea foam-gonna happen next week after i get paid so i can run it in a full tank of gas, whts the best method?
coolant temp sensor- New
oil change- (not for hesitation i guess lol) done
Old Aug 16, 2011 | 06:56 AM
cmh's Avatar
cmh
theres a thread on here that i cnt find right now but, the guy had similar issues to urs and said it was the coil pack on the drivers side i believe... i would just change both to be safe. he did a bunch of things before comming to this realization.
Old Aug 16, 2011 | 08:14 AM
leonsup's Avatar
leonsup
ethanol & reformulated gas will sometimes cause hesitation
Old Aug 16, 2011 | 08:34 AM
xxtoobsxx's Avatar
xxtoobsxx
25 will need you to replace your main heated O2 Sensors. Hesitation could also me a vac leak and idle problem could be combo of the 2, maf or iac! However there is a lengthy thread on this. Search sc400 hesitation.
Old Aug 16, 2011 | 09:35 AM
blacksc4's Avatar
blacksc4
thanks for the advice
gas im running right now- speedway 93 octane
vac leaks-checked and recked it all lol it was my first thing to do
i followed the ultimate sc hesitation post but everything i checked has checked out so far, coil pack was not on there, so ill do that and was planning on o2 sensors this week, whats your guys take on bosch universal o2 from auto zone? its 55 bucks
im running a 92 sc400
Old Aug 16, 2011 | 11:11 PM
xxtoobsxx's Avatar
xxtoobsxx
NOOOOO just pay extra for oem denso plug n play on amazon! i paid like 130 for both!
Old Aug 17, 2011 | 12:44 AM
619Rider's Avatar
619Rider
Afm check ?????????????
Old Aug 17, 2011 | 11:41 AM
blacksc4's Avatar
blacksc4
afm???????
Old Aug 17, 2011 | 06:52 PM
vangb2's Avatar
vangb2
It almost sounds like it's a charging issue if it's hesitating during idle. You can have it load test to see if your charging system is any good.
Old Aug 17, 2011 | 11:35 PM
xwingzero2's Avatar
xwingzero2
a new battery? idk man just naming things
Old Aug 18, 2011 | 08:54 AM
blacksc4's Avatar
blacksc4
got the alt checked at advanced autoparts and it checked out fine
ill give that a shot too,prolly upgrade to an optima or kintec
Tayler
Sep 21, 2018 07:26 PM
MuGGzyx
Apr 20, 2014 10:08 PM
exao
RX - 1st Gen (1999-2003)
May 20, 2011 06:50 AM
Codfish
Mar 4, 2010 10:22 AM
JDMmuscle
May 29, 2008 04:52 PM
