Well The car starts, runs and drives! There was a heavy oil leak that i was unable to trace, or from what i thought. Currently the car is not running and is sitting in my driveway until I have the money for the parts i need. Since last time i posted i decided to go single. The turbo i have chosen is a gt3076r nice instant spool since the turbo is usually on 4 cylinders.
What i still need to get:
-Oil Return Line
-Oil Feed Lines
-Water Banjos
-Oil Return Line
-Oil Feed Lines
-Water Banjos
I see where your going
WOW
* Ball bearing
* Oil & Water-cooled bearing system
* Upgrade turbocharger for GT3071R non-wastegated ball-bearing turbocharger; turbine housing flanges are outline interchangeable
* T3 turbine inlet flange
* Ideal for medium displacement engines making up to 525 hp
* Turbine housing kit options available
lol, it's not really that big of a turbo, just that i didn't want to get with a gt4202r since that means i would probably have to spend a ridiculous amount of money just get get it spooled a little. I kinda like how this one is on our motors anyways... http://www.youtube.com/watch?v=6bB9kYH5pMQ
Thanks, it is the GTE swap in the next couple of days, ill be re ripping my engine bay apart and styling it after a dragster. All engine bay wiring hidden, battery relocated, abs delete, power steering reservoir relocation, fuse box relocation,trac delete, remove unneeded wires/fuses/electronics, strip wiring harness, run dual relays and wires for dual fuel pump setup.
