Help with supra control arm install...
okay so here's my problem..
I am trying to install my new front lower ca's. I bought two new 96 supra ca's for my 92 sc400. After getting my old ones off, I held my the supra arms up to mount on and it seemed just a little off.. It does not slide in as smoothe I was expecting it to be. Did anyone else have this problem? I need some advice. I tried grease and banging it with a rubber mallot. No luck. I am starting to think it's not gonna work.
Good luck. PM with other questions.
If you can post a pic that might help but it should be the right ones ytou have.
yes that is correct the rubber bushing was different.
What I did was put the "extending" arm in the bracket. The one I am talking about is the part that comes out of the solid piece with the ball joint. then I a little grease in there and put the jack underneath it. I lined it up the best I could with my hand and then jacked it up. It slid right in. The other side moved the car a little and then popped right in.
I tried with a hammer and a mallet and a sledge and a pry bar and my youngest child. I could not beat it in place any other way. However with the jack it was quick and easy. A little frustrating after pounding away with no luck...
The large rubber donut shaped bushing that you must transfer over to your new LCA's is referred to in the Lexus Factory Repair Manual (Volume 1) as the "Lower suspension Arm Bushing Stopper". Just pop off the old LCA's and pop on to the new ones, and make sure they are facing the correct way. BTW, I just saw on Ebay a GREAT price on the Lexus SC Factory Repair Manuals Vol1,2,3 for like around $30, that's a steal!!!!! These Lexus factory repair manuals are darn near the best repair manuals of ANY make of auto made. Fabulous manuals for DIY!
The repair manuals you state are likely CD's for that price...I have those they are ok but I was mislead thought they were hard copies.
Yeah I believe you are right about the factory manuals most likely being CD's, pretty sneaky listing. As for the the large rubber donut shaped bushing that you must transfer over to your new LCA's it is referred to in the Lexus Factory Repair Manual (Volume 1) as the "Lower suspension Arm Bushing STOPPER" This part does ABSOLUTELY need to be transfered from/off of the old LCA's and put on the new LCA's. There is one per LCA and you can get by using the old one or Lexus sells new ones at $20 each. These just slide over one of the metal bushing inserts, one per LCA side. They come right off with your hand. They look like a smashed rubber donut. I have done three sets of LCA on three SC's, I know what I am talking about here, trust me. The part is pictured on page SA-39 of Volume One of the Lexus SC repair manual.
