Error code 29 NEED HELP!!!
Old Nov 17, 2008 | 08:02 PM
plant87's Avatar
plant87
Default Error code 29 NEED HELP!!!
okay i got the codes out and its giving me code 29 i replace the sensor already and am still getting the same code( and i did clear the code by taking off the EFI fuse and also disconnecting the negative on the battery ) am getting really bad MPG and i need help
Thanks
plant87
Old Nov 17, 2008 | 09:14 PM
TheMole's Avatar
TheMole
What year is your sc300 or sc400?
Code 29 is the sub o2 sensor, so you replaced the one on the cat right? The 2 on the exhaust manifold are the main ones.
Old Nov 17, 2008 | 11:58 PM
plant87's Avatar
plant87
its a 93 sc400 stock
Old Nov 18, 2008 | 11:01 AM
TheMole's Avatar
TheMole
I believe the sc400 has 2 sub o2 sensors. Did you replace both of them?
Old Nov 18, 2008 | 07:26 PM
plant87's Avatar
plant87
no just the one on the right side. do you i have to replace the one on the left to??
Old Nov 18, 2008 | 07:54 PM
TheMole's Avatar
TheMole
Maybe the other side was bad or both. Can't tell unless you test them.
Old Nov 18, 2008 | 08:48 PM
plant87's Avatar
plant87
how do i test them do i use a tester or a auto meter??
DeanWeen
GS - 1st Gen (1993-1997)
Oct 9, 2018 04:08 PM
Deegee
Mar 4, 2018 01:56 PM
STORMINORM
Aug 17, 2014 12:19 PM
corleone
Apr 29, 2011 02:52 PM
