Sputtering!!! Help!!!
Old Nov 14, 2008 | 08:10 AM
czaredd's Avatar
czaredd
Default Sputtering!!! Help!!!
Got in my 92' SC4 this morning and the engine was hesitant and sputtering when pressing the gas...jerking and stuff. I managed to drive in to work, but I would like to know what could possibly be causing this before we go to the shop. Could this be water in the fuel, spark plugs, O2 sensor or what? Has anyone else experienced this? Thanks for the help.
Old Nov 14, 2008 | 10:43 AM
kyoso23's Avatar
kyoso23
Last time that happened to me I found a frayed coil wire.
Old Nov 14, 2008 | 10:50 AM
czaredd's Avatar
czaredd
Is this a DIY job? Thanks for the info!
Old Nov 14, 2008 | 10:58 AM
qksl2's Avatar
qksl2
Pull a plug first and check what is going on.
I'd also pull out the MAF and see if it is clean... if not you can clean it very carefully.
Other things that greatly effect cold start would be the coolant temperature sensor.
Ian
Old Nov 15, 2008 | 07:17 AM
sccd's Avatar
sccd
Make sure you check the correct procedure for cleaning MAF. There are different types. You dont want to ruin a good one. Im not saying the MAF is your problem, just a heads up, if you decide to clean it. I would check wires, distributor first.
Old Nov 15, 2008 | 08:31 PM
KORUPT8D's Avatar
KORUPT8D
If your car sputters only at low speeds it could be one of your vacuum hoses leaking fuel, check the hose from the fuel control valve . Its located to the left of the Lexus badge on the left fuel rail.
toy4life86
Apr 18, 2012 11:36 AM
DMPesso
Maintenance
Aug 26, 2011 01:49 PM
soulific
CL of Southern California
13
May 10, 2010 03:46 PM
Conceptvip
Mar 23, 2006 01:08 PM
