sc300 95
Overheating: Water pump, leaking radiator, radiator cap, leaking upper/lower hoses or heater hoses. Check for circulation.
Battery dies: Bad battery, bad alt (both can be tested at your local parts store, for free), a short in the system (check for continuity between ground and power).
Powersteering: Leaks in the system will cause it to run low and ruin the pump pretty quickly due to overheating.
Ian
Ian
Studiogeek
Nov 24, 2013 03:15 PM
