Changing oil pan gasket.
Old Nov 23, 2008 | 11:38 AM
forcefed86's Avatar
forcefed86
Default Changing oil pan gasket.
Does the engine have to be raised to do this? I'd like to change mine but I don't think there's enough clearance....
Thanks...
Old Nov 23, 2008 | 02:06 PM
TheMole's Avatar
TheMole
You are referring to the upper oil pan correct? Seems like a tedious job. Here are some basic steps that I found:
-Remove and separate engine and transmission as described under Engine.
-Install engine on engine stand, then remove timing belt and crankshaft timing pulley as described under Timing Belt.
-Remove oil level sensor and oil dipstick and guide.
-Remove No. 2 oil pan and oil strainer, Fig. 40.
-Remove oil pan baffle plate and No. 1 oil pan.
-Reverse procedure to install, refer to Specifications for torque values.
Old Nov 23, 2008 | 05:22 PM
Supra Dr's Avatar
Supra Dr
Moving SC Threads
Can also be done by supporting the engine from above & removing
the front subframe. 6 of 1 - 1/2 dozen of the other. For me the
subframe is easier. (have a lift & engine support brace)
Old Nov 23, 2008 | 07:26 PM
5sp_jzz30's Avatar
5sp_jzz30
support the engine from the top with the type of hoist that can be placed in the engine bay. the pan doesnt have a gasket. you use RTV or toyota FIPIG for both upper and lower pans. if the car is on jack stands you can support the front k-member with a floor jack and lower it a bit to get more room.
Alokat007
Dec 10, 2017 08:46 AM
rlx101
12
Jun 6, 2009 08:00 AM
jgreezy
Maintenance
Apr 2, 2009 07:55 AM
Flipsonic
Sep 21, 2008 09:04 PM
Verge
GS - 1st Gen (1993-1997)
Mar 28, 2007 07:02 PM
