- 1JZ VVTI: HKS FCD vs. Greddy BCC
- weird battery problem
- vacuum lines question please help!!!
- 1jz pushing a to4 turbo 1.0 a/r too laggy?
- primary wire to pasenger coil NO Voltage..help
- Need help rewiring a parking light
- 92 SC400 just purchased
- ? On trd diff
- Transmission problem (Urgent please)
- 2J/SC400 auto trans prob
- marlin crawler vss or other options for speed sensor?
- Sasha runs again!!! Now for the update and things to come....
- Another USA legal swap engine possibility: GM/Pontiac 2.0L Turbo Ecotec 4cyl?
- Novice Q: must manual transmission be filled with oil on workbench to test shift?
- Needs some help with my coolant explosion :(
- 95 SC300 5 speed swap, which clutch pedal??
- Sc300 na-t stutter at 5k rpm
- NA-T SC300 Where to get IAT sensor! HELP?
- NEED AEM V1 NA-t MASTERS
- SC400 1jz swap or supercharger??
- Type of A/C in 1995 SC300?
- need assistance
- driftmotion turbo kit
- Exhaust!
- Question about SC300 Ignitor - HOT
- SC400 with W58 Swap with T-56 bearing..which clutchline size?
- Another sc300 slave/master cylinder sticking thread
- singled aristo swap tuning help
- Lean in boost now.
- help no acceleration....
- going 1jz to 2jz sc300
- Repair Advice Requested: Head Gasket and Water Pump
- Sc300 1jz conversion help
- 2jzge na-t with dyno sheet need help with COP conversion
- Fuel pump poll.
- SC freaked out.. died.. then was fine? looked everywhere
- Swapping the Head for the 1UZ... crazy idea.
- AC compressor Pulley eating serpentine belt
- apexi avcr help?
- what turbo parts needed: 94 sc300 with 8.5:1 comp block
- 1JZ-GTE Toyota Soarer No Start
- Side mount IC with Front mount IC
- AEM EMS 30-1101 Confusion
- 1JZ Throttle Issue.
- A/c issue
- SC300 Timing - Misfire vs. Engine Stall!!
- SC400 has no power. Need help!
- Hydraulic Throwout Bearing on R154
- Engine swap
- R154 Swap JZX90 92-96 Chaser
- soarer r154
- Help Identifying AC Part!
- Drive Shaft Diameter
- AC Hardline replacement
- aluminum radiator ac not as cool
- Time to overcome this: PS leaks only after being driven
- Help! Rear axles no good
- Sc300 vs Sc400 swap efficiency
- 99 uz into a 97 sc400
- Tuning question anyone?
- 97+ supra engine mounts.
- Opinion from those with V160 and TRD mount
- Tru Boost Pinout
- I'm hitting boostcut @3500 rpm with my boost completely turn off
- Staggered Cams On a 2JZGE??
- Foam in coolant resivor
- Put new platinum NGK spark plugs in runs worst now
- turbo build throttle body
- Timing Belt Slipped?
- 93' Sc400 Transmission Problems HELP
- JZA70 1jzgte in 1992 sc300.. please help
- 400 is misfiring
- Oil leak from distributor, HELP PLEASE!
- Take a look at my spark plug and let me know what you think.
- 92 SC4 problems please help
- 93 sc300 speedo problems
- Wtf!
- sc 300 clunky transmission
- Weird noise from middle console when going high speeds like a grinding noise NEED HEL
- Idleing problem saga continues!
- sc300 1jz Project Car
- Upgrading from Dual Walbro 255's
- TPS Throttle Stop Screw Location w picture
- e85?
- Bleeding the Traction Control
- NA-T 389rwhp 445ft-lbs need help with ignition
- cold air intake & exhaust?
- parts
- should I rebuild or repair my 96 sc300 engine
- ebay timing belt kit
- Aftermarket Parts and HP
- O2 Sensor
- No power to Ecu or fuel pump.
- Hayden 677 Transmission Cooler Installed
- what turbo is this?
- power steering question w/pic
- Na-t tt ecu single turbo a/f's
- Anyone running ACL bearings?
- SC300 - Will not run - Please Help
- 1993 SC400 Turns over a few times and fails... then starts 4th or 5th try
- Should I be able to pass emissions?
- New to forum! My SC...need some help!
- Grinding sound from shifter, also transmission flush?
- Mysterious green light on dash board?
- Distributor plug locations numbers
- Clutch disc melted to flywheel??? Southbend/R154
- 95 alternator issue
- washed my engine, now guess what........
- mk3 supra w58 swap clutch help
- SC300 differential backlash
- Need some recommendations for turbo
- ignition problems
- R154 Trans / 1UZ V8 ? compatible flywheel?
- At a complete loss
- opinions on 1jz or 1.5jz
- alternator wiring help
- Soarer R154 question
- Quick crank pulley question
- Automatic SC400 dying
- GE-GTE compatible parts?
- 99' SC300 5-Speed Swap Question
- weird no idleing run like poop question
- Lextreme stage one cylinder head
- 93 sc300 AC problems
- Does a sc400 iacv fit on the sc300???
- sc400 stops accelerating & accelerates again
- headers/aftermarket exhaust for SC400
- r154 vibration / shaking issue.....
- 1992 sc 400 won't stay running
- Injector not getting a ground
- Something weird happened..
- swapping my 1uz
- IACV Question
- strange tachometer
- How easily should a driveshaft insert into the rear of the transmission?
- Air Conditioning Issue
- Should I get a 1JZ or should I just mate a manual gearbox into my SC400?
- rebuilding auto tranny for 600 hp?
- bc 264 install in 1jz
- Electric fan conversion
- Is my gearing messed up? (1JZ W58 Low Speeds, High RPMS! - 5speed SC owners plz come)
- Power steering noise
- quick question; bad waterpump? AND or BHG?
- Just installed my R154 and having problems
- spark plugs
- WOAH! (Three questions in one thread. Clutch Jerk/Drivetrain/AC Leak ECU)
- 1uz egr tube remove ?
- Sc300 fuel system
- Help in Denver
- Time to start over, or can I fix it?
- Anyone running any sort of upgraded cams on their GE?
- High idle & transmission mis shifting?
- CEL and Trac Off lights on.
- 92 sc400 temp gauge pegged at hot
- Smaller turbo installed now boosting higher
- 1JZ twin turbo replacement w/ twins.
- Heads up tip : air conditioning leak
- please help with electrical issue on my sc
- new mufflers
- undercoating
- 1.5jz build parts needed
- engine build opinions
- replace front turn signal bulb on 1995 SC300
- 1jz problems help !!!!
- SC400 A/C Compressor Revolution Sensor
- 1jz vvti water pump, where to buy?
- brake lights not working
- Working on my 95 sc400 ignition
- transmission mounts help!
- driveshaft length?
- Help!!! faulty MAF sensor not sure
- Bought the wrong water pump have a question
- vvti vs non vvti parts.
- No overdrive / cruise control
- Quick favor from the 98-00 SC400 guys
- Can anyone recommend a good aftermarket 1JZ-R154 flywheel?
- GTE knock sensors while rebuilding the block
- 1999 sc300 comes with LSD stock?
- Head Replacement
- Auto TT trans
- vortech help
- Need some help figuring out what could be the issue with my SC
- Grinding fenders for larger tires
- SC300 Not Getting Spark; Aristo 2JZ-GTE
- Charging Voltage Mod for $.50
- clutch problem?
- 99 sc300 body plug diagram
- High RPM lockout, southbend/soarer r154
- Blowing smoke under boost
- Is this the ABS sensor on my MKIII R154?
- u-joint
- SC400 won't start?
- Is this good enough for fuel management?
- Exhaust Manifold flange warped??
- Power steering OVER assisted, Too light, twitchy after overfill/drain extra
- Low Fuel Pressure??
- Stripped nut on fan clutch need some ideas.
- ems choices and help
- 1JZ Sticky Idle symptoms?
- Need Help with my Loss of Power
- Window regulator killing me. See pic need HELP
- What was the story behind the Dave H orphan turbo kit?
- What mount and crossmember for R154 into SC300? (have searched)
- Need help w window regulator!!!
- W58 Clutch and Flywheel
- So my SC is overheating and I'm still deployed..Awesome.
- just bought my first lexus
- Window motor really starting to aggravate me.
- 1jzgte swap into 93 sc300
- Neutral Safety Switch
- Are these bad caps???
- Garrett t04e BB 60-1
- Can anyone help explain this: low AFR under boost and no Fuel Cut??
- Need help, maybe ecu related
- SC 300 Failed Emmisions Test, Replaced 02 Sensor...Still Not Passing
- lost.... im new to the lexus scene and need a lil help please :)
- lost on what axles to run help needed.
- 1UZ-FE Or VVTI 1UZ????? S13 swap
- sc400 cranks but wont fire up.
- My new custom exhaust SC300
- 1jz vvti intake cam seal?
- Trac light on...
- R154 manual swap needs clutch ??
- '93 fuel filter and rear seat back
- Please help! SC400 won't start!
- Installing new -6 AN braided fuel line/Aeromotive filter. Will these parts work?
- Club NA-T KIT
- 1uz Injector Rail Torque Specs??
- 1JZGTE Single Turbo Boosting SLOOWWWW HELP
- MAS performance sc300 runs a 9.8!!
- OBDI vs OBDII engine harness
- 2jzge obd1 code 14 please help
- is clutch pedal spring supposed to be super stiff?
- Walk through for installing BOV
- low idle and no ac, 1jz vvti
- Who Can HELP Me
- Need to verify exact length difference for factory R154 Soarer shift extension vs MK3
- 93, poor low end power. solutions?
- KA24DE Trans on SC400?
- startup hiccups sometimes
- Why want SC300 turnover?????
- Driveshaft deminsions
- Pulling out all my hair!!
- K&N Intake from a GS400 on my SC400, finally its been done with a pic!
- Help a noob out.. A341E trans swap A LOT of Questions!
- Na-t vvti do I use a tt head gasket?
- O2 Oxygen Sensor LIES for the 1JZ... 4 wire to 3 wire conversion?
- NA auto shift kit?
- Titan Motorsports: Aeromotion Wing
