Na-t vvti do I use a tt head gasket?
tt headgasket mounts the same as oem vvti headgasket .. oil port for vvti is fed from drivers side of block on the actual side of it ..
use the tt headgasket and arp studs and you can make 400rwhp safely provided its tuned right . anything past that mark , ringlands become a real issue then the rods .. vvti oem bottomend is not very forgiving ..
Ok good to hear I figured this is what people were doing kind of like the 2j gasket on a 1j which works just not all of the holes line up but it has proven it self over and over again, This is my 1st na-t project so I was unsure but thanks for confirming this
suprakidxx
Performance & Maintenance
01-23-14 09:59 AM
