- All black thread (no two-tone) 95-97 LS400 body styles
- 2013 avalon wheels
- 1993 LS400 - Trying to wire my double din.
- transmission
- 1995 LS400 weird idling problems.
- 93 ls400 turbo or s/charge
- Help me ........ Please !!!!!!!!
- 96 ls400 wiring diagram for nakamichi ... ive been looking for an accurate diagram
- What is this part called which broke?
- UCF11 JDM corners Vs. Usdm corners
- cats or no cats 94 ls400
- 94 LS400 with codes 41 & 55.
- I should've known better..
- Heading to the grave
- radio has power but no sound?
- Dash Panal Lights, other questions
- Intake manifold swap?
- New '91 LS 400, a couple quick inquiries
- First Lexus Ever!
- 1990 ls400 clock spring question.
- tell me why this will not work in my 94
- Black Jade Pearl Touch up paint?
- Bilstein question for 97 LS400
- Is the Nakamichi Sound & Navigation Package combinable on the LS400?
- new 94 ls400 lots of ?s
- 2000 LS400 issues Help!
- 96 with 98 front end?
- 99LS ... I need to change my bank 2 Cat, what OEM Brand/Supplier Can I trust?
- 1992 LS400 ABS issues (or not!)
- LS400 with fault code 31 and erratic idle. AlreadyTested MAF (good) ECU (good)
- Climate Control Wiring Diagram
- Failed Wheel Bearings....
- ucf10/11 transmission compatibility.
- LS400 with Lamborghini doors sound familiar?
- DIY: No Horn? QR Set Up for Horn Relocation
- Performance Air Filter replacement on LS 400 1992
- fog light out
- new member - intro
- anyone on saleen reps?
- 92 Sticker Pin Stripe Removal
- Please Help - dash lights out
- Quick Release Horn Button
- BWD Coolant Temperature Sensor
- 20 years of carbon build up
- Serpentine belt tension
- 94 ls400 still doesnt run
- Thoughts on buying a 98+ LS??
- LS400 coolant resevoir tank crack question
- the light next to the headlight
- heater control valve open or close?
- Radiator bushing problem
- Blower Motor/Integrated Phone Issue
- 1999 LS400 Problem with code po125
- LS400 Lack of power during acceleration?
- Unknown button??
- Factory Air Suspension Cheater on 98 LS400
- Cannot get serpantine belt tensioner pulley to come off
- new to 95 LS400
- Ls400 with the vcs plague!! Halp!!!
- TRAC issue?
- Straighten Steering Wheel?
- pinging problem
- How much would you pay for this LS400 ?
- Aftermarket steering wheel thread!
- car stalled after slamming on the brakes
- heater/ac fans not blowing.....???
- Engine block heater in my '93
- oil light on but oil pressure ok and oil pressure sensor replaced
- Strut Rod Replacement (1998)
- Max spacer on factory studs?
- Driver Seat dashboard button
- Door Chime Every Time I Hit a Bump
- Seatbelt Issue
- want to upgrade my wheels suddgestions anyone?
- cold air intake hmmmm
- Issue w/ key rolling up and down windows
- 96 front wheel spacing help???!!!
- HELP!!! ls400 speedometer needle
- BC Coilover install this weekend
- Engine vibration factors?
- Brake pad warning light on??
- Vibration
- Locked radio
- New Lexus Owner!
- OEM vs aftermarket
- New "JDM" style tail lights installed, lights not working properly
- Ls400 ride like floating
- my first lexus
- Fans come on so as I turn the key.
- new to cl
- new to cl
- Ls400 DHP WHEELS
- Transmission mount replaced! Motor mounts next
- Car Won't Start!! - Weird Feeling in Brake Pedal
- New '96 LS400, with some problems
- 1992 ls400 engine computer in a 1993 ls400
- 90 ls 400 over heating Help
- New; From Vancouver!
- Before you replace your 1st Gen brake lines..
- 99' lexus ls400 auxiliary input, how to?
- No Leaking or Sick Caps in my ECU
- Rear sway bar bushing kit??
- 92 steering wheel need some help
- Loose Door Panel/Seals, Part #'s
- I think i might have found my LS
- new tires, need opinions
- 1994 LS400 - Replaced Battery, Won't Start
- New owner of a 1993, new to CL, questions.
- Strut Mounts Cushion
- Need help replacing brake light on 1997 LS400
- UCF10 Sputtering/surging & low power
- Question on My Lexus Service History
- Replacing Parking Brake Shoes
- 1991 LS400 Throttle Issue
- Vibration At Cold Start Up Smoothes Out When Warm
- My New LS!
- UCF21 Headlight Removal
- My 99 LS turned over 230000 today
- Just bought your LS check your in cabin filter!!
- low uneven idle and stalling problem
- 92 MAF Sensor Cleaning???
- why wont my lexus rev over 2000 rpm
- 98 Ls400 Won't turn over Help Please ASAP Anyone!!
- Doors Unlock by themselves.
- Need Rim Advice For My LS400!!
- Radio intermittent
- Transmission hose leak?
- UCF 20 SS Brake lines
- how to get to shift lock solenoid ????
- loss of power and sputters around 2200 rpm
- BC Racing BR Coilovers
- Engine issues - newbie help required
- Idling issue
- 1997 LS400 won't start, possible immobilizer issue?
- Someone please help me find this part
- Where to buy ac vent *blades*
- Swapped my tranny mount - Got rid of a lot, no just have high speed shake at like 70+
- Steering reach
- Trunk emblems off and shaved!
- Need help!!! Doesn't start after throttle body cleaning
- After timing belt job, 91 LS400 is not starting
- Anyone drive with the PWR/ECT on all time?
- Just picked up ls400, help me mod this thing.
- Possible rack and pinion problems
- need some suggestions
- replaced alternator, no sound from radio
- Help identifying a hose 92 LS400
- 300.00 good for a timing belt kit
- 92 LS Distributor Cap/Rotor Change and Clean TB???
- Dash Lights Stay On
- Resurface rotors or not?
- Looking for LS front strut bumpers
- 99LS ... Whats the best way to clean the gas tank?
- 1uz in my 4runner, need help with a wiring question
- 98 LS400 Will Turnover, Won't Start no CEL
- 99LS ... What's the going price for Tune-Up and Timing belt at a local Mechanic ?
- 99LS ... How can I check if my timing belt needs to be changed?
- How badly did I mess up my car?
- 1992 ls 400 losing brake fluid
- lsx turbon swapped ls400
- Megan Coilovers on a UCF10
- Tail-lights not turning off
- clear tails?
- ECU removal/replacement procedure
- Key rolls down all windows
- 1998 LS400 snow-worthy?
- Is this a red flag on buying this '99 LS400?
- I cleaned my headlights with toothpaste.
- Code 13: Help!
- move along.
- Does this sound like a bad starter?
- The center bolt for the rotors
- Content removed
- this isn't the classifieds.
- A/C repair costs
- Coolant Leak? What is this tube?
- 00 LS400 -premium audio - upgrade time - beatsonic vs full upgrade???
- 1995 LS400 Starting Issue
- Benefit to Air Box Mod???
- High-level advice on water pump, timing components
- 1990 LS400 Exhaust = HP???
- new lexus owner with question about suspension
- What is this?
- Another Tranny Mount Question
- I just bought me another 1999 LS400
- whos ad is this?
- double din question
- New Member
- Fuel consumption, sputtering and hard shifting on a 98 LS
- Anyone put a Mushroom Intake?
- Transmission mount issue
- ls400 Speedometer issue - PLEASE HELP!
- 98 Ls400, engine runs fine, but no power to the wheels
- Looking to buy 95-97 UCF20
- just bought a 91 ls 400
- 98+ window switch question
- Any vender selling complete interior LED and license plate conversion kit.
- Repeat Power Steering Failure - 98LS
- Ls400 wont run help please
- Changing Power Steering Pump on 92 LS 400 Need some Info
- 92 ls400 failed CA smog test
- 1996 LS400 recent purchase
- ignition wont turn
- Timing belt change, cracked camshaft-sensor.
- DIY Auto Zone chrome grill poor-boy mod
- SLIP INDICATOR problem
- Please help - Stuttering engine
- Spudder when cold
- 1 & 2-LS suspension compatibility
- Stripped Coolant Inlet Bolt
- Intro: TaffyK20si (over due)
- Dangerous Brake Performance
- need help 92 ls400
- 1998 LS400 Highway MPG: 75mph vs 65mph
- ls400 EZ Coilovers what Damper ??
- New to forum and Lexus
- 1995 ls400 jerks,clunks when easing off gas
- How NOT to change your idler bearing
- transmissikn fluid leak butt from where..
- need repair manuel 93 ls 400
- Will Lexus ES 300 wheels fit on my 92 LS400?
- Newbie down under... any Aussies here?
- Tilt works but limited range, already did washer fix
- knock sensor pigtails
- 90 LS 400 Junction Box 2 Fuse Sparks on insert
- Another transmission thread...
- Post your aftermarket seats.
- power steering very hard on my 1992 LS 400 after these repairs
- Trunk Lid Latch Actuator
- Valve stem seals
- Buying New Rims. Need Help With Specs
- Cross threaded nut on wheel stud
- Factory Radio problems 1990 LS400
- need your HELP please - engine surging
- When I grow up I want to be an LS
- New Member
- Hissing sound from headlamp
- 1YUZFE's 1994 LS400 Restoration thread
- Is there a Current Lip for the 95 ls400 ??
- Late introduction to myself and my LS400
- Anyone tried dropping the steering rack to do the engine mounts?
- no wtb here please
- o2 sensors replacements
- first gen strut rod bushings....
- '96 LS400 - shock replacement
- '96 LS400 - What are those electronics in the right wheel well under the carpet?
- My Ride ..
- oil in the bellow boots
- 1-LS: need help with wheel & tire fitment
- will 2006 oem ls430 wheels fit an 2000 ls400?
