Clunk when turning (video)
Old Jun 16, 2015 | 09:27 AM
GISguy's Avatar
GISguy
Unhappy Clunk when turning (video)
Any ideas? 3 different angles.
I could be mistaken as to where it's coming from, but it sounds like a control arm bushing or tie-rod joint.
Old Jun 16, 2015 | 03:00 PM
Kris9884's Avatar
Kris9884
Hmm I used to get a big CLUNK while going forward to reverse and it was a control arm bushing but your example isn't so profound as mine was. Have you tried making sure all nuts/bolts were tight? I would still assume a tie rod since its specific to the wheel turning?? Not positive.
Old Jun 16, 2015 | 07:19 PM
TokinSC400's Avatar
TokinSC400
From your video I see a little movement in the engine cradle. Check all of the engine cradle bolts. If they are all good and tight. Have some one get in the car and turn the wheel while you Stick a screwdriver to different components while sticking your ear to the handle and listen. Hope any of this helps.
Old Jun 17, 2015 | 07:30 AM
SC400slide's Avatar
SC400slide
In Recovery Mode
CL Folding 25,000
^^The engine cradle bolts will almost always be loose on SC's after a long while of not being tightened. Believe it or not, tightening those cradle bolts are considered "maintenance" in the SC service manual.
Old Jun 17, 2015 | 12:06 PM
Blkexcoupe's Avatar
Blkexcoupe
I would check the subframe bolts like others have suggested.
Old Jun 18, 2015 | 12:17 PM
Essie95's Avatar
Essie95
take a look at your power steering rack? mine did that the day I got it and the bushings were GONE. apparently, its a pretty popular thing that happens with SC's.
Old Jul 4, 2015 | 11:58 AM
GISguy's Avatar
GISguy
PROBLEM: Steering rack was moving due to mis-torqued bolts and bushings. Pivot joint was moving upon steering column rotation, causing aforementioned sound.
SOLUTION: Tightening all bolts/bushings to ~60ft/lbs eliminated movement on pivot joint and lateral movement on rack, silencing any noises and fixing an earlier issue with a "moving center point" in steering.
upsman1
RX - 3rd Gen (2010-2015)
Jun 23, 2019 02:48 PM
05RollaXRS
Feb 23, 2018 03:49 PM
ChuH
RC F (2015-present)
22
Aug 13, 2014 03:37 PM
Vegas
Suspension and Brakes
Nov 17, 2011 03:24 PM
O. L. T.
Feb 21, 2004 11:49 AM
