More 1jz help
Old Jun 18, 2015 | 11:13 AM
Dtaylor3's Avatar
Dtaylor3
Default More 1jz help
Been working on a swap for awhile now and I'm still not getting a spark. I have done tons of research and checked cam sensors, crank angle sensors ignitor wiring and a few other things. I've had the engine in for a month now with the same problem... Any help would be appreciated
Old Jun 18, 2015 | 11:18 AM
99SC42's Avatar
99SC42
That's really Vague..
Do you have power at the coils, power at the ignitor?
Did you check for continuity from the coils to Ignitor? From ignitor to ecu?
What wiring are you using?
Any modification done to the harness??
Old Jun 18, 2015 | 12:35 PM
estomax's Avatar
estomax
do you have an FSM ? Gotta start tracing wires on the power circuits and checking with a multimeter.
Old Jun 19, 2015 | 02:01 PM
Dtaylor3's Avatar
Dtaylor3
I've got power at the coils.
How do i check for continuity?
Im using the stock 1jz harness.
Old Jun 19, 2015 | 02:02 PM
Dtaylor3's Avatar
Dtaylor3
Man that sounds awful... At this point i kinda have no choice tho
Old Jun 19, 2015 | 02:14 PM
estomax's Avatar
estomax
gotta go back to old carburetted muscle cars if you don't want to deal with wiring
continuity is checked with a multimeter... go wikipedia it.. you got a lot of learning to do if you want to get this swap to run on your own!
cheers,
Marko
Old Jun 21, 2015 | 07:07 PM
Dtaylor3's Avatar
Dtaylor3
Is there a way to troubleshoot your igniter and ecu besides trying on anther car and taking the ecu apart?
Old Jun 23, 2015 | 09:27 PM
Vrank's Avatar
Vrank
Who did the wiring? Is it done properly? Does the cel come on at key on? What did the 1jz come out of?
Old Jun 24, 2015 | 11:08 AM
Dtaylor3's Avatar
Dtaylor3
Stock harness. I extended the body plugs. Cel does not come on. I'm decent at wiring so I'm confident it's right. Soarer swap... Is there a way top test a igniter? Or an ECU?
Old Jun 25, 2015 | 07:32 AM
Vrank's Avatar
Vrank
Soarer swaps aren't exactly plug and play even though they plug in. There's more stuff to be done if that's all you did. If you still have the stock harness from your car and you are in fact good at wiring, you can figure out what needs to be done with a multimeter using continuity, a jzz30/jzx90 pinout, and an aristo pinout for the small plug of the stock ecu as the SC plug has all the igsw/mrel/+b/w/batt **** in the same place
Old Jun 27, 2015 | 09:42 AM
Lettut's Avatar
Lettut
What year model is your car? I guess it's a twin turbo/non vvti motor you're Swapping in? I did like you and just extended the body plugs and it worked (besides the mods for tach and temp). My car is a -94. It didn't start at first, because I had forgotten to connect the groundwire that goes from the backside of the block to the firewall. Have you checked that you have good contact on that one?
Old Jun 28, 2015 | 02:07 PM
Dtaylor3's Avatar
Dtaylor3
Car is a 95. Non vvti swap from a soarer... I'll check that next.
Old Jun 29, 2015 | 11:22 AM
Vrank's Avatar
Vrank
Lettut, there is 100% zero way that the ground from the back of the cylinder head to the firewall will prevent this from firing on his car, and it didn't fix yours either. That's a wild goose chase you're sending him on. The only important grounds are the ones that go to the intake from the engine harness, two of them for a 1jz. And one for battery to chassis. Car will run fine. Having another from battery to block is helpful, but isn't technically required. I've fired one of these up on the ground, as have many people, and there's zero firewall to bolt a ground strap to.
Have you verified your fuel pump is working? Have you done the 12v mod behind the driver's side interior panel? That's first place Id look.
If that's good, Id confirm key on has 12v at injectors, coils, igniter, iacv, o2.
If that checks out Id pull a set of coils, put spare spark plugs in em, and set em on the cam cover or something so I can watch for spark as I crank over.
From there, if spark is good, Id be looking at cam/crank sensors, timing off, or bad ecu.
Have you done any of this?
Old Jun 29, 2015 | 12:18 PM
Lettut's Avatar
Lettut
My apologies. Just trying to be helpful. The blind leading the blind
Old Jun 29, 2015 | 02:40 PM
Dtaylor3's Avatar
Dtaylor3
12v mod is done and the pump is on.
I have 12v at the injectors, coils and igniter i kno, not sure on the iacv. The o2 sensors was cut, so i know it has no power, didnt think that would cause it to not spark tho.
ppayne1201
Nov 17, 2013 02:35 PM
1JZjackson
IS - 1st Gen (2001-2005)
Jul 12, 2012 03:17 PM
T70Soarer
Feb 5, 2007 08:34 PM
JJG2005
Jul 16, 2005 04:35 AM
Kaiser
Jun 29, 2005 11:26 AM
