SC- 1st Gen (1992-2000)
Help. i want to install resistors for airbags in my sc400
Old 05-27-15, 11:53 AM
MishaV
MishaV's Avatar
Default Help. i want to install resistors for airbags in my sc400
I need help .
My 00 sc400 has been in an accident.
I had the damage rapaired but want to install resistors for the steering wheel and passenger airbags.
The problem is that i cannot find the right ones because i do not know how many ohmes the are?
I life in the netherlands and i am the only one with a 00 sc400.
I really hope someone can help me out here.
regards. Misha
Old 05-28-15, 01:55 PM
salimshah
Forum Moderator
salimshah's Avatar
Received 1,099 Likes on 989 Posts
Sorry I dont have the answer, but wanted to add that you may be interested in finding few more things then just the resistance in Ohms.
Wattage ... this will ensure the resistance can handle the current.
Type. Some are wire wound and some are thin-film.
The above factors seem trivial but since we are talking about personal safety, I would look into those too.
Salim
Old 05-28-15, 02:18 PM
Ali SC3
Ali SC3's Avatar
its most likely easier and safer to remove the cluster and remove the airbag light if you plan on running like that.
Old 05-29-15, 06:37 AM
MishaV
MishaV's Avatar
Thank you guys for ansering .
The problem is that I want to get te car registered for Dutch roads. There for the airbag system has to work. (Lighting when you turn the key has to go on and off) the date is set for june 30th . I just have to figer something out because I just cannot get a nother airbag unit on it in time.
Old 05-29-15, 04:02 PM
maynanator
maynanator's Avatar
Ask for an extension due to mechanical failure.
Meunvmost
08-27-11 03:36 PM
Carfreak70
Performance & Maintenance
11-10-08 10:31 PM
Big Pookie
05-19-06 06:01 PM
sonyman
05-26-05 03:44 PM
Quick Reply: Help. i want to install resistors for airbags in my sc400
