- Hestiataion
- Anyone try Hyper voltage system?
- Has anyone tried out the cams?
- Distributorless 96 Sc300
- 1jz swap started
- dont know what to go with?
- SC400 transmision code..?!?!
- Anyone extending the wiring harness?
- w58 mated to 1jzgte??
- Chaser 1JZ GTE FOR SC300?
- A/T to M/T Swap Questions
- 1jz Gte Vvti = Twin Or Single Turbo?
- Dragon lextreme?
- I can't believe I am having this "oh so common problem" with my car after resetting..
- Which mufflers?
- Help choosing grounding kit
- Oil filter for 1JZGTE?
- 99 sc 400
- my SC is ready for Kevorkian
- Question about 1JZ swap
- Air Intake Boot
- Turbo Calculator and Turbo Deals
- Engine won't rev past 2000 rpm!!!
- which sc300 intake recommended?
- Easy way to check between engine and tranny mounts or bad center bearing
- clutch?
- My WTF is going wrong thread LEXUS GURUS CHECK IT OUT
- Supra Auto TT LSD Install in sc300 pumpkin?
- I searched, But I need help For 1JZ!
- The best Cold Air Intake system
- sticky shifter
- tranny price
- Slowly but surely
- wtb::1jz parts..
- Auto Transmission... need HELP.
- How do i disable the Stock 1JZ OBV.
- 1jz question...
- 2 projects now...my sc300 1jzgte swap pics!!!!!!!!
- whos sc300tt is this?
- What companys import 1jz-gte's?
- power steering
- sc/supra compatibility question
- Flex A Lite FAN Conversion Sc 400
- Little update (new turbo/header pics)
- question 2jz conversion
- anyone in colorado?
- torque converter question
- Tired of searching..... NEED LSD help!
- Door won't open - From Inside or Outside
- Tranny swap?
- Greddy 23R FMIC Q's
- 98-00 sc4 motor in a pre-98??
- Man I REALLY killed my ALT this time.
- cleaning out power steering reservoir
- Differences in Eaton M90's
- Help Please Transmission swap ????
- 1jz diffuculty starting up.. I need HELP
- BFI and passing tech..
- Large Pictures of Different Exhaust on Z30 Soarers
- how can i find out what year my motor is?
- Cant Get Turbo Timer Hooked Up NEED HELP
- Please help me out on this turbo timer problem
- clutch pedal in sc300
- Weapon-R / Unichip ECU Help!
- JDM SC300 (2JZGE) question
- Need A New Radiator
- My car has a little over 200k on it...can i put..Nitrous (NOS)?!
- Power Steering Noise
- Who can figure out why my SC400 is idling at 1,500 RPM?
- Installing a wideband?
- 2 JZ's
- Almost Done with the Car
- Sc400 trans fluid and Throttle body?
- Timing Belt Change (Question)
- Misfiring help
- Shopping 4 a turbo kit 99 SC300
- Cant Start SC with clutch!
- Converting 2JZGE 5spd to 1JZGTE w/ Auto? Anyone?
- anyone spray stock sc300?
- fuel question
- Need 99 SC300 turbo help
- Automatic Info
- Almost there...
- What is a clip
- Need both rear tires to spin.......
- Need help from the experienced...sc400 problem
- Power Steering Pump Replacement
- engine
- tranny ?
- Help with 1jz wiring
- quick answer for turbo exhaust system
- Need Radiator Help on my sc400
- Starting Problem... No power to starter Solenoid
- new user help about swap
- Throttle Body Spacer for SC4?
- Newest SC300 GE-T / 700 rwhp +
- Apexi S-AFC II
- would the parts i have work with the r154 swap?
- Which one looks better? Hks HiPower or Carbon TI
- free mods????
- 1JZ-GTE Twin Upgrade
- 97 or 98 sc300
- california emission ecu
- Bad Head Gasket
- car dieing =/
- Clicking Thingy and no idle. Help
- sc300 shifter removal HELP!!!
- Trans mount, binding brakes, toyota parts
- Will the rear end off a 92 SC400 fit my 96 sc300??
- Will IS300 catback fit SC3
- Smog check time
- 1JZ Swap List Parts Buy
- Oil Light Blinkin
- SAFCII din mount. **pic** will it fit?
- SC300 engine stall...Please help.
- bone stock sc300 dyno
- my exhaust is bigger than yours!
- Need some SCerious exhuast help?!!
- Transmission (auto) growl/whine on deceleration
- Some semi recent pics of my Soarer
- DIY - How To: Transmission Mount Change SC300/SC400 5spd or Auto
- SC400 Hydraulic Fan Conversion
- Tranny question
- I got something nobody else in the world has for their SC......
- car dieing on me need help please.
- Any quick NA sc300?
- Location of fuel pump ecu?
- will mkIII w58 fit in 92-94 sc300?
- Supra W58 vs. SC300 W58
- how can you test a motor's condition?
- Short revving vid
- Pearl White '97 Sc400
- the new guy......kinda
- Apexi WS or Tanabe Tuner Racing?
- Short Shifter Brands?
- Battery terminals installed backwards?
- Sc400 V12 engine swap...
- Alternator, PWS Pump, Battery, & Anti Theft Device Problems
- clutch master cylinder?
- anyone know inside diameter or resonators?
- Well.....there goes my bodykit & wheels...........
- oil pump (2jzge and 2jzgte = same?)
- SC300 (N/A) exhasut sounds
- Why is the pre-VVTi motor so loud?
- Anybody have a stock dyno?
- Auto to Manuel Tranny require new differentials?
- tranny fluid change?
- car died while driving
- My project plans
- Car stuttering in random rpm ranges, question about MAF
- 1JZ Auto Swap Into 5-Speed - Wiring Issues?
- Help ! Noise when letting off gas
- Cat. Clogged?
- engine stand bolt size for 2jz??
- intake or no intake?
- turbonetics sc300 dyno results
- LTW fllywheel and ebay 6 puck installed
- Question about the TT swap into SC300 (temp gauge)
- ECT switch not working help please.
- Gs300 Vvti Engine For 92 Sc300?
- having trouble pulling cel code
- Report: Diff Fitment Issues Supra and SC
- 4.27 Gear in '99 GS3
- Aem Ems Users!
- Help Temp. Fluctuating
- funky comp test #'s...
- Auto Tranny Engage
- O2 sims?
- sc3 or sc4?!?
- toys came in lol
- Where to buy supercharger kit for my sc400?!
- Turbo surge
- 6 speed torsen in sc400?
- SAFC2 Wiring Question
- How much did it cost you?
- Coolant dissap.=problems..
- Anyone solved CE Code 25 ? 92-94 SC4
- Over heating
- Going rate for a leak down test?
- na-t's with stock maf
- AC Problems....(yes I searched already)..HELP!
- save on gas/extra pep for sc300
- Putting on my Magnaflow 14829 mufflers with all new piping.....
- Easiest/Best tranny for 2jz-gte swap
- Headlights dim when I hit the brakes
- what LSD fits SC300 5spd?
- JDM 2jz-gte into US spec?
- whats this about the sc400 can be 5spd ?
- Whats wrong with my baby?
- Flywheel install - does it matter how it is installed?
- Leaking Oil Pan Gasket
- engine mounts - steering rack
- quad tip dual muffler setups WANTED!
- Master Cylinder and Clutch Pedal Assembly
- mods to increase gas mileage
- how much do front clip usually run for these days?
- need turbo on sc 400
- my trac light is on
- Hks Vpc ?
- Where does this tube from the Charcoal Canister connect to?
- Soarer LSD?
- Driveshaft Center Support Bearing?
- My new toy for my SC
- IS250 shift knob fits SC300 5sp?
- SC300 Stumbling on Full Throttle or Idle??
- Help NEED TRANNY FOR 92 SC400
- ABS unit compatability
- Which manifolds fit the 2jzge?
- 1jz-gte mpg?
- Auto to manual near complete, one minor problem
- Having boost issues with my 1JZ SC300.
- Motor Teardown
- manual gear box problem
- 400 hp 1jz or 2jz.. cheaper?
- 1jz v v t i swap info a 97-2000 sc 300
- MK3 1JZ injector compatability
- Lights dimm and car seems to turn off and back on?
- Motor Mount Upgrade
- Injector question
- 2jz-Gte into an Sc400... I know it has been covered before...
- Spark Plug Heat Range?
- 2jz info
- Budget Cold Air Intake 2 - Total Spent $53.79
- looking for sound clip
- Fuel Filter for my sc300
- stock flywheel weight VS supra flywheel?
- FYI GS400 ECU learns and compensates you may be lean
- Motor is out - finally...
- Swapping Spark Plugs Tomorrow
- so-cal 2jz-gte transplant looking for a shop
- If compression test checks out well, is a leakdown necessary?
- 2jzgte swap info/pricing
- Anyone with bad heater valves and a free 'fix'
- CEL for: 02 heater & TPS
- TRAC OFF blinks after installing new tires
- Remanufactured Starter - OK????
- New SC Owner & CEL Problem
- The fun begins tomorrow... wish me luck!
- sc air filters
- BFI Question
- Turbo Project...
- Turbo Kit Install - Day One
- Project V8 enroute
- which turbo route?
- Help me pick out which mufflers I want.
- supra NA ECU same as SC300 5 sp ECU?
- how much oil does your engine eat up?
- Sc300 and Gs300 engine compatibility?
- Replacing stock Cats with new high flow cats?
