2jzgte swap info/pricing
2900$ a good price for this? Would the be everythign i need to swap into my 95SC300?
Used Imported JDM 2JZ-GTE Twin Turbo Toyota Supra 94+ Auto Tranny, Wiring Harness & ECU
Your Swap Includes The Following:
Block, Twin Turbo, Intake Manifold , Complete Head, Sensors, exhaust Manifold, Fuel Rail, Injectors, Throttle Body, Power Steering Pump, Wiring Harness, ECU & Auto Tranny
The engine has been imported directly from Japan and the mileage on the engine is between 20 to 35 thousand miles.
The engine comes with a 100% full start-up warranty on Block only!
theres also this one which is 1900$ not sure if that includes everything??
DIRECTLY IMPORTED FROM JAPAN W/30K-60K MILES AVERAGE.
JDM TOYOTA SUPRA ENGINE ( 3.0 TWIN TURBO ) / AUTO MATIC TRANSMISSION / ECU ( AUTO ) - 2JZGTE (PLEASE USE OUR LONG BLOCK ONLY)
30 DAYS WARRANTY ON USED LONG BLOCK. NO WARRANTY ON SENSORS/TURBO/LABOR/EXPENSES/SHIPPING.
Originally Posted by speedaddic
not bad, I paid 5k for a complete longblock (everything including turbos), harness, ecu, 6 spd Getrag tranny, rear end, sway bars front and rear, front calipers, performance exhaust...Oh, and mine is US spec so its smog legal...stock
Moving SC Threads
Originally Posted by TeamDX
As others will be replying with, that is a deal of a lifetime. That same setup is value'd at over 7500 Easily. What you got is NOT the norm.
Din, make sure these places are reputible & can back it up if theres a problem.
theres a lot of jdm importers now-a-days, check out their sites. you can tell the good from the bad.
I got mine from www.osakajdmmotors.com. I got the longblock and the complete swap for 1850$ shipped from Canada. It came with a broken rear turbocharger though, and Osaka and the shipping company aren't claiming none of them broke the turbo. So the process of getting the turbo replaced is taking 2 months and counting. I end up buying used twins from someone else to complete my project for a buddy.
If they can get their customer service taken care of, they would be in more business.
It was for the comlete swap. It included the motor, auto tranny, wiring harness, ecu, turbos, and all sensor on long block for 1850$ shipped. It came out of an Aristo.
It started out orignal price was like 2200$ shipped,and i kept on calling and everytime i called, someone else answered and gives me a lower price. It seems like the more i called, the lower the price got, until it stopped at 1850$, and then i made the order
Try it out
Try it out
Try it out
Try it out
Cheers,
I have pretty much all the USDM conversion parts and ive spend around $1800-3000. Im not quite sure.. They are fairly cheap by themselves, but when you add them up its scary.
I bascially have everything except the motor.
