View Full Version : Suspension and Brakes
- 19's sevas star with big brake?
- recommended BAY AREA shop?
- few quick shots (redid my retrofit + tein cs)
- Advice Needed: What to replace to freshen up the front suspension???
- Spacer with lug extender?
- Tein CS dampening?
- Tein Ss Coilover
- Replace caliper seals or replace entire caliper?
- Finally..Pics of Tein CS on Donz Columbos in Gallery
- How much are they?
- Diy **Air Runner** air suspension questions
- New 2002 GS430 owner - more suspension stuff
- HOw to take off rotors?
- Need a shop to paint my brk calipers
- vibration help
- big brake help
- cleaning grime off teins before install...
- Advise on DIY L-Tuned - Tein CS Install
- SoCal (LA preferred) shop rec needed
- Rear Brakes?
- Lowering with Tein CS's
- Yet another STEERING wheel vibration thread, questions...
- Keep TRD LCB or TOM`s LCB
- brake bleeding on a gs400
- Questions for those with Daizen swaybars
- Rattles, Vibrations, and Grinding
- Rotora Slotted Rotors fitment
- Tein CS ?
- Supra TT brakes on Donz Columbo... pic in Gallery
- owners of rmm bbk, brake pads
- Confused...Chrome or polished RMM STB
- TOM`s LCB install - a mess!
- Caliper Stickers
- Clear up: Sportline Springs are made by eibach
- spring selection
- Supra TT Front Brake Install.. Thanks lexforlife
- Whats the difference with the various S/S ?
- advice on strut mounts
- Would you trust a Toyota Master tech to install Coilovers on GS?
- Picked up TOM`s rear LCB
- my new BIG BIG brake setup
- Which STB?
- Pot holes.....SUCK!!
- front end making a "woowoowoowoo" sound
- EDFC Wiring problems
- TSB - steering wheel flutter
- Uneven drop with L-tuned suspension
- Any regrets installing 18,19 or 20 in wheels
- Alignment
- bumpstops
- Ordered Parts
- L Tuned steering ECU
- what color calipers?
- TEIN CS last batch...hurry!!!
- L-Tuned camber specs
- Supra TT calipers
- need help what could it be (bad vibration in the front wheels at about 50 to 65)
- Update on Teins CS...
- Possible suspension damages?
- Where can I purchase L-tuned bump guard?
- effects on steering?
- need help on l-tuned suspension
- Christmas in July
- Picked up TOM`s 6 piece..hehe
- Poll: Camber issue for lowered rides
- TRD STB Install
- Break pads and discs
- what kind of drop is this
- If i can't get Tein CS? Whats my other option for comfort?
- Supra Brakes & OEM 18" G-Spider Wheels
- Which Coilovers???????????????
- L-tuned suspension warranty?
- L-Tuned Steering ECU
- Ball joints and tie rods replaced - WOW
- Torque on lug nuts
- possible problem with H&R Coilovers
- bare supra calipers..what do i need?
- 'Coilovers' at stock height
- Need some opinions on J.I.C. coilovers?
- Tein Super Street
- brake mod
- are IS brakes the same as the GS?
- Rotor Removal
- Squeak sounds from front..
- Help: Need stock brake information/part
- EDFC question
- How rough do the drop kits ride?
- Porterfield Brake Pads
- Is Tein supposed to be making a STB that fits the 430?
- 1st mod...TRD LCB
- Brakes/Rotor suggestions
- I installed TEIN CS today.....good but quick question.
- Best prices for Tein CS?
- help with brake noise
- lowering question for GS w/ 20'''s
- Need Info On Camber Kit
- Installed L-Tuned: hearing clunking noise
- What are my Braking Options...
- need advise on trd stb
- Rolling GS400
- noise form tein flex!
- Need Lexus Caliper Stickers....
- L tuned Bump Stops
- Ls brakes on gs
- ball joint go clunk
- gs430 Brake Pads
- Ball joint question
- TEIN CS are here!!!!
- New Rotors and Pads on the way
- How to check shocks
- I was warned..GS float
- Anyone use Tein SS??
- BBK caliper color
- L-Tuned Shocks/Springs Bump Rubber
- Tein CS Height adjustment?
- Suspension Question..
- tanabe springs installed
- Has anyone gone for a smaller steering wheel??
- front suspension vibrates
- Comments after installing L-tuned s/s yesterday.
- 10 days after I purchased my GS
- Tein EDFC operating problem - calling all Tein EDFC users
- squeek in car
- who can make custom caliper decals?
- Does dropped cars have more tire noise?
- Did I Get Suckered Or Was He A Pro
- is L-tuned still availiable?
- Did Stoptech stop producing the 4 wheel BBK kit for the GS?
- Brake Pads
- clicking noises in gs300 while braking
- Rotora 355mm BBK Upgrade (Finally)...
- Tein CS in stock!
- Anyone have pics of lowered GS??
- stupid Question about the steering ECU
- whistle sounds from brake...
- Water on Lower Suspension Arm
- has anyone tried the intrax sway bars?
- Well Going To Cost Me $360 For S/S Install
- Supra TT upgrade Q's
- Midpipe GS300 + Daizen swaybar bushings
- Problem with rear callipers, please help!!
- torque specs for daizen sway bars
- Brake pads..Lexus says change, Toyota says no.
- New Struts and Alignment
- Tein HA Owners
- Cusco 2.0 LSD installation - need help!
- TRD sway bar installation - need help
- Bilstein HD Installation Question
- Unstable feel when turning and accelerating...
- Updated pics w/ kit and coilovers
- L-tuned Springs/ Shocks
- When is the best time to replace the OEM suspension items?
- GS300 lower springs w/o new shocks?
- Rims/Suspension
- BBK swap
- turning brake rotors
- A good thing, but too much information for a novice like myself
- H & R springs w/ 20" wheels
- Daizen Control Arm Bushing Kit
- eibach lowering springs for 98 gs with 20" wheels
- Does anyone have the Tien HA spring drop with KYB or Bilstien..Pics pls if any
- Brake pad question
- H&R springs and Bilstein sport combo
- Spring installation problem
- question for all edfc owners
- Bad experience with Tein CS today.
- Best price for bilstein shocks
- Eibachs !!! ( stock shocks what will this setup do for handling height and ride )
- Anyone have pics of Brembo slotted on GS?
- DIY ball joints
- The Life Of Springs
- EDFC install.
- URGENT: Help Needed - Brake Noise.
- Want new Brakes!!!
- Installing lower control arm
- Need help with finding struts for 99 GS400... have searched
- Problem pressing stock springs out?
- Trd Stb
- Help please odd brake noise...
- Room Bar and Floor Bar
- cant undo setscrew on collar of coilover..
- 19's L tuned S/S
- Weird loose cracking sound and feel in the steering whel when i go over certain bumps
- trd strut bar install
- poll: on BBK
- click click click!
- any one running l-sportline springs with bilstein sp shocks
- Tein CS on back order for 2-3 months. HELP!
- EDFC error after installation..
- Trying to decide on springs
- Daizen Sways Problems
- Tein CS Clank
- i need two.......please
- The Best - Dust Less Brakes Pads for Stock Rotors
- Help! L-Tuned suspension install question
- camber kit..
- Grinding a few mm off the calipers to fit some rims.
- Wheels, Tires, and Suspension?!
- ALignment and Balancing GS
- Installing L-Tuned Shocks
- just installed new akebono brake pads
- Three lights after suspension work
- Daizen Control Arm Kit
- What is a good size tires with 20's
- RMM strut bar
- Problem with Tein CS, need help
- LS Brakes= to TT brakes?
- Brake Upgrades
- Before & After: LTuned to Tein CS pics...
- Tein CS vs Flex
- Squeck from TEIN CS?
- ? for GS owners with Tein CS...
- Question about adjusting Teins HA
- GS430 L-Tuned Suspension Install
- Intrax/RMM Front and Rear Stabilizers? Compared to Daizan?
- Anyone have the DSR STB?
- Heat and steering wheel noise
- Castor and camber plates??
- Just returned from alignment and..
- What Model EDFC to Get?
- Tanabe Sustec Pro S-OS
- RMM Polished Strut Tower Brace GS400
- Tein CS Question....
- performance fricition
- Help on Drop rate of Lsportline Springs!
- exchange calipers
- RMM STB for 99 gs 400
- Turbo front strut bar
- Anyone fit stock 17's with Supra Brakes?
- Suspension Mods on gs 400
- DSR STB Question
- Carson Toyota STB
- air ?
- GS Prototype Strut Bar Installed! Lots of pics
- RMM BBK for gs 400
- Camber Kit for GS
- air ride my gs?
- Thoughts on Brembo Sport Drilled Rotors
- Suspension on a budget
- So I installed new ball joints and Tie rods yesterday. . .
- Wild Steering on FWY!!
- Rotora 355mm 4 Corner Big Brake Upgrade. (56k non-safe)
- H.Tech Tein Springs
- Dealer wants $800+ for new rotors/pads
- Advice on BBK purchase
- tein h-tech springs
- Tom's braces rusting
- Cusco Zero-2e Coilover system
- Torsen LSD or Clutch LSD
