Ls brakes on gs
Ls brakes on gs
Would the Lexus LS brakes fit on a gs-300? Is there any modification needed? Ps the brakes are of a 2004 LS.
exclusive matchup
Originally Posted by vicestan
Where can I get the brackets? I can get the front calipers with brake line, pads, disks and sensors for around 350. Is that a good deal?
anyway, i am not sure about the price, but if you talk about the overall deal (with custom brackets etc... which i don't think anyone has so far), i think it's cheaper to get supra tt setup. or you can get the ls400 setup if you want. you just have to shave off one suspension bolt at the bottom
Originally Posted by rominl
sensor what sensor?
and you forgot that both Jon and me have the LS430 calipers on our cars
But you cannot just get brackets, you also need to machine the calipers.
Master Thread Closer!!
what does the bradke pad sensor do?? i ask coz' if it's just specific to the ls430, then i dont' think the gs can take advantage of it?
while some cars will warn drivers with dashboard lights (and brake pad sensors), our lowly GS will require us to listen carefully to the brake squeeks and/or check the pads manually ...
Btw ... often high performance pads do not come with brake sensors ... and i cut off the sensors from my set of pads
exclusive matchup
then there is no point in putting that "sensor" on anyway?
