- Thinking about buying this 2008 IS250
- Cost of adding parking assistant (I got parts)
- Car Question IS250
- Money saved and ready to order, but please help with specs!
- License Plate Lights
- Rear tires rubbing rear fenders bad
- Labour Day 2012 PhotoShoot
- Is F sport intake vs k&n typhoon
- blitz drop in filter
- Blown out OEM ballast? Please help...
- Vibrating Rear View Mirror Issue?
- What's the stupidest mistake you've ever done on your IS?
- F-Sport 2011 Bumper upgrade from Sewell
- steering feels tighter?
- Serious fuel comsumption issue
- Need help with wiring!!!!!!!!!=[
- Amazing! Dropping Rain Drops!!!!!!!
- HID bulbs....d4s or d4r
- How much are 2009 IS250 AWD OEM wheels worth?
- New Member From Miami
- Should I lease then buy?
- very thin hub centric rings 4mm
- New to the forum - Just bought a 2006 IS250
- Aux Port update under CPO??
- iphone contacts wont transfer
- Anyone see this Led reflector ?
- Ichiba V1 Spacers
- good ole hurricane(pics)
- need help on headlight/daytime lights
- HeyArms' KSport Pro Plus Air Suspension Review
- crazy is350
- Ride Quality going from OEM 18's to Aftermarket 19's?
- Anyone running 45 series tires
- 60K done recently! Damn plugs are expensive
- Features You May Not Know About On Your IS;-)
- Strange BlueTooth Problem-Goes to direct to VM?
- Anyone know the cause of the squeeking from my engine?
- Garage Door – Home Link Issue
- Transmission Swap
- Steering wheel question?
- My new Carbon Fiber Window panels!!
- New IS250 owner, Synthetic question
- 07 IS350 Replacement HID bulbs
- XM NavWeather randomly activates
- F sport exhaust cost
- Which winter rims to choose. :-)
- Tire size help
- Nav touchscreen failure + no sound = coincidence?
- fuel questions
- Is this also a RoadRover unit?
- shady dealership
- Reg gas question
- HID going out
- NEWB question: Screen keeps switching to maps from audio..?
- It's been fun
- Front Fenders Liners
- 2012 headlight conversion
- Full in-depth review, unboxing, & Q&A of ANDROID VAISTECH UNIT (video inside)
- Tire Pressure Dash Light
- FYI, post-warranty repairs
- Was this the right decision....
- Just stopping by to say hi and thank you!
- My new IS350 !:)
- Sharpie/Graffiti Lexus - The Last Phase
- Shady Dealer = no Is250 :(
- Just Hit 130,000 miles!!
- 06 IS350 A/C problem
- Variable Tints + Auto Roll up windows?
- Manuals
- Bubbles in seat leather
- needs Tires!!
- New Guy here
- How far have you gone....
- Tire Rack closeout special on 255/40/18 Dunlop Sport Maxx GTs
- Scratches
- Nokian Tires
- 2010 is350 shocks, springs, and sway bars
- Help with Mark Levinson on 08 ISF!
- One of my fogs are brighter than the other!
- I trying to figure out what is my IS250 worth
- Paint Work lowering value?
- DIY turning off seatbelt alarm
- Sunroof delete questions
- I wish my IS350 would shift at 7k + RPM!!
- Get Headers or Replace Cat?
- DRL cree?
- sup guys
- Have a few wheel questions..
- Question about service records
- Intermittent "error 6 on radio display with iPhone?
- lower grille
- Puddle lights
- In need of a DashCam
- Dashboard edge CHIPPED
- shocks replacement
- Just had Seibon Carbon Fiber pieces installed
- Do you need a rear camber kit to go negative camber?
- 2011 Lexus IS 250 F-Sport Package with High Miles!! Need Opinion
- Myride Rear Diffuser On!!!
- Ken Block Event [September 4th] Need vote for my car!
- Wants to run taller tires
- anyone purchased these HID Fogs?
- Returning to Lexus (IS 250 C ) after 6 year hiatus with BMW 325 CiC
- Sport Pedal Question
- Help!! Engine Swap possible? 350 engine into 250.
- Diagnostic tool
- Thought for my passengers..
- Advice on carbon fiber lip kit
- Wow so my TPMS with 3 piece wheels as turned my car into a disaster
- Off a roll?
- Vendor for black is250 headlight eyelids?
- Warranty about to expire in 2008 IS350
- newbie with mods fever...
- I'll be back in a few.....
- Extended warranty worth it?
- Need help with a decision!!!!
- Dented Oil Pan
- NON LX-MODE Chrome Door Handles
- Why are Shocks Super hard to find for 2009+ IS250's??
- Buying an IS350 what should I know before buying it from Carmaxx
- car locked n cant be opened
- 06 is350 transmission shifts hard
- Need a quick help!!
- 09 IS 250 p0430 code
- door edge guards
- Leather Pulling away
- Carbon <3
- What Size Wheels Should I Get For My IS250
- Michael Jackson Before & After WARNING PICTURE OVERLOAD
- 2006 aftermarket HID bulb problem
- Question about purchasing a CPO
- Is it possible to program only one TPMS sensor?
- 06 is250 drivers headlight not turning on "auto"
- added a little awd touch
- Opinion Thread: Powercoating my CCW LM faces
- How much are you paying for tabs?
- Replacing Vanity light
- pics of my IS250 on road magnet springs
- Help, nav unit is showing just black screen with white vertical lines
- Radio Not Working after removing signal processor
- Chrome Shiftgate replacement?
- F-sport badge location measurement.
- is350 convertion headlights & Taillights
- A/C intake while on recirculate
- Changing puddle lights
- 2006 IS350 oem front lip
- Powdercoat wheels like isf wheel?
- Paint protection
- ?? about Black spots on Rearview Mirror
- Wow so my sensor shattered and I almost lost my front wheel
- BG 44k?
- Any1 else recieve used 2012 headlight from Sewell?
- Which IS250 is the best?
- Check VSC light on...
- Is 220d injector replacement
- Question for guys who use mobile 1 synthetic oil
- Cigarette lighter problem
- Getting closer! 09 INGS refitted+more!
- How do i view the time until Oil Change??
- Vossen Customer Service!
- Power Window passenger side sound weird
- Cam Gears Making Noises EVEN AFTER getting the TSIB Done
- Car battery?
- My isf kit for my is350
- Tried Searching [center console charging port]
- tomorrows the day!!!
- Where is the 2009+ IS350 Luv?
- 2008 IS 250-Help me identify model
- how to install S4Play Diffuser
- 08 a/c vents same as 07 a/c vents?
- 08 vs 07 IS350?
- 18" rear tires?
- Finally got the car back from Exotics
- 2012 F sport wheels/tires rubbing
- Anyone know of a good diy manual?
- will this lugs fit?
- TPMS battery died. Any way to salvage the car?
- IS250 Wheels....Impact Wrench help
- XenonDepot - Customer Service is second to none.
- Navigation Screen is Deader than a Door Nail.
- 2IS's on Instagram
- need HID bulb replacement recommendation
- Might be time to part ways...
- Wheels Similar to CV7?
- Searching for a Used Is350 Resources?
- Brake Light?
- Finally - Aimgain for IS 250/350
- New IS350 owner welcomed!
- ML System slowly dying?
- Show me Your Rear Lip~~~
- '11 IS250 Non-Nav iPod rant
- Help Removing Rear Tray/speaker Deck
- New IS350 Owner
- What's a good price for a 2008 CPO IS350 in Seattle area?
- New Friendly Post--Owners and theirs Dogs
- Please be very careful when driving in so cal!
- ***My car was featured!!!***
- having a problem with my is350
- Weapon in Lexus
- Anyone wanna give me some input on this IS250
- Has anyone tried the as seen on tv 'Pet Rider' seat cover?
- broke something changing my spark plugs???
- The Rare IS350
- Any info on G37 rims on a is250
- The wait was worth it!
- Is it possible to.....
- Modding and Warranty
- Headliner removal
- 19x10" all around on is350 RWD, s it bad?
- Faster on a full tank of gas?
- 30 y/o guy would rather have an ES 350
- Oil Maintenance Req
- Anyone got SSR or any 3 piece wheel that have out TPMS sensor in it?
- A Lexus Trifecta
- Lowering a 06 is250
- HID bulb
- How do you remove the trunk liner?
- XMNav in the system not acurrate?
- installing my 2012 headlights...
- A/C Recirculate mode not switching
- Finally a IS350 owner!
- 2009 IS250 grill/bumper question
- IS250 & GS300 piston replacement warranty policy rumor
- new to CL and have a few questions
- What is safe to clean engine
- Sorry for the Newbie Question
- Wheel Guru's
- overhead lights not working...
- My 2012 IS350
- Low Engine Oil
- need help on is350 spark plug change
- My situation. What would you do?
- HELP!! Check VSC code
- IS250 2012 Headlights from Sewell discount question
- my car really stinks....
- OEM Mid Pipe....Worth Anything At Scrap Yard?
- Weirdest thing you've seen on your car...
- IS250 exhaust smells bad when WOT
- Help: Oem cd player not working
- eBay Backup Camera For Fly Audio Unit
- How to check for hid headlights
- Differences between 2011 and 2012 IS 250
- drl lights dont work anymore?
- need bulb ideas for my fogs.... opinions?
- IS250 helps me save money
- 2011 f-sport bumper inserts
- HID Projector Fog (2011+)
- 2013 IS Info Released from Lexus News Room
- Lexus IS250 Integrated with iPhone 4 + Nintendo Games (Legend of Zelda / Super Mario)
- wheel offset question on F-Sport suspension
