Rear tires rubbing rear fenders bad
I have 2007 is 250 with a aggressive setup 20x10.5 +25 with 245x35/20 tires and megan ez coilovers After searching the forum I thought I would be ok with a roll and minor pull. But I was wrong the tire is rubbing the rear fender every time I hit a bump to the point it took off paint and caved in the fender some. I am low but not that low. It has also ripped up the tire. The question is what can I do. Will getting a camber kit fix it? do I need more pull? I am at work but will post pictures when I get home. There is not a shop around here that has a awnser I am hoping I can get help from the forum. Thanks guys.
Go lower. It will camber the wheel in more. I have a 265/30 on 19x10.5 +24 and have no rubbing. I rolled flat (no pull) and cut the rear bumper tab away, but I'm also almost tucking a 19" rim in the rear. Another thing is to make sure your alignment is right. Toe in or out can cause rubbing. My rear toe is 0.08 (very close to neutral).
I've got the same problem =\ Running 20x10+30 on 255/30 with shaved fenders and i've already cracked the paint on one fender and have torn up one of the tires and I was running a 1.5 finger gap. People have suggested a smaller tire for me but I know it can be done w/o that. I may try dropping it really low but i've drive on really bad freeways so really low + offset + nasty bumps and dips I think i'm going to destroy it more. Still looking for a good solution myself.
^ What he said. Megan camber arms and run them in. I am not on 20's but am running a 10.5 +22 with -3.5 degrees of camber. I only rub slightly on dips and that is on the rear tab area.
definitely get camber arms, camber it more and you will be all good. you wont have that problem anymore, i was in the same situation. in the meantime, i suggest you raise up the car a little bit to save your tires.
sojah
06-24-10 01:45 PM
