- Great MPG!
- 3is conversion
- Very worried about dealer response to steering failure
- Need help. Only one front amber light working
- Wife's car is worse than I thought - 4 codes now
- 09 IS250 M/T Noise
- Lexus IS250 Aftermarket GPS/DVD System
- Ouch... Did I damage anything??
- Considering a IS what do I need to look for?
- 2007 Is350 - Transmission Question - "MINOR" jerk / quite clunk
- New to Lexus...
- DIY HID KIT install on Ebay Headlight (version 2)
- Spoiler install
- Lower engine cover
- Everything is leaking!
- Thinking About Buying 06 Lexus IS 350 for $9500 With 143k Miles *Good or Bad Idea*
- Window tint replacement
- switched steering wheel
- Nicked my bumper.
- Mix and match tail lights
- Freshly Bagged AWD is250
- Tires...225/45r18
- Do we need relays on HID fogs?
- Lost Key fob for my 07 is250
- What the... Dealership wiring harness fix?
- Shifting kills engine
- Do I need hubcentric ring?
- Headlights Cutting Off
- FSport Intake on 2006 IS350, SMOG Check question/issue
- Where on Earth can I get these plaid floor mats?!
- JDM yellow fogs
- Trans Problem
- Please help identifying this mysterious part
- USB interface problem...
- Stealth/Chrome bulbs
- V8 power
- 2010 lexus is250 awd trany oil
- would dealer take your car in for trade if missing TPMS?
- am I getting a good deal 10k with 140k 06 is 350
- Questions about Wheels and rims
- Engine and Traction light
- So I hit a flying piece of rubber the other day...
- 2007 IS250 Electrical Nightmare
- 2006 is250 has starting problem
- Osram CBI bulbs
- my2007 is250 change 2011 led headlight installation how to ?
- Looking for RIMS
- Audiophiles here?
- 2007 is350 help
- Center rear view mirror
- Just raced a srt8 300c
- Blown engine - Direct engine swap possible?
- Looking into IS250 awd, any changes amongst years?
- Faster shifts in manual mode ?
- Power surge?
- Wife's IS350 showing engine code P0017 - Cam Positioning Sensor - Help
- Where are the ISF conversion bumpers for 2007
- Just got my Legacy Plates, what do you think?
- Looking to buy: 06 is250 awd rr cv axle
- Is it ever OK to NOT do the safety recalls?
- Just purchased MY 06 IS350
- What happened to Nigel Jdm?
- Need help identifying part...
- CEL & Traction Control Light on.HELP
- Winter tire size variations
- Body kit input
- Any input on Emusa Coilovers?
- 2011 IS350 Car Won't Turn Over
- Alternator failure...discovered new issue..
- Lowering Help
- New to the game/Green Pea-looking for any advice.
- Is350 Engine Sound - Serpentine Belt?
- Help me out please...already searched. Rumbling in reverse after lowering.
- anyone know where to buy this? [rear side splitter]
- Smoke coming from and smells like electrical burning
- Latest and future plans
- Why? Just...why?!?!
- Warning lights, oil cap, and coolant level
- "Check VSC"
- Starter is very loud compared to newer IS
- Opinion on Air suspension Brands
- Clicking
- Spooky Halloween trick of windows mysteriously opening themselves?
- Flat bottom steering wheel
- Hood hinge swap
- Cr 1632
- Popping noise?
- Direct Aftermarket Replacement Speakers for ML
- Strange noise when I put it in reverse today...
- Partially frozen nav system
- ISF vs IS350 Rev Battle
- 2007 Lexus IS250 AWD TPMS light question
- Brake replacement opinions needed
- 08 IS350 transmission code P0761 and P02714.
- 2nd gen is350 tire size question
- IS350 19" rear wheels 265/30 or 255/35 ??
- What is the difference between 2006-2009 headlight and 2010-2013
- 2011 IS250 F sport non Nav to OEM Nav swap
- Is350 straight pipe question...
- Need help finding this car
- Coilovers for 2013 IS350AWD
- 2006 IS350 Nav Failure
- Loud rotational clanking noise, possibly differential from staggerd wheel set up
- Tapping noise from driver side seatbelt
- The Official 2IS's with Custom Bumper threads
- Oil Pressure Drop during high speed driving
- buying a 2009 is250 tom.
- Navigation, AC, Clock Completely Dead
- Hi Guys...new to Lexus (:
- Differential Replacement 2006 AWD IS250
- Battery Parasitic Drain MPX-B
- 2010 GFX Front Lip
- 07 with 14 front bumper
- New Member + Plus Question
- Noise when turning - Only in the morning
- For those of you who are boosted, where did you tap into for boost gauge?
- Input from guys with Air Suspension please!!!
- Rolling rear fenders question
- Blue tooth feature
- Low Oil Light Question
- How To Add A Subwoofer To Your Existing Car Stereo
- New member = New IS250
- Other headunit options (for non nav)
- 135,000km service
- 2007 IS350 modified factory rear bumper
- Plastic Side Piece Removal Near Trunk and Tailight
- Help with amp settings (reinstalled)
- Racing seats or ISF seats in a 350 ?
- Newbie here with questions.
- KIRKLAND BATTERY fit 2007 Lexus is250
- All FS & WTB go in Classifieds Section Only
- IS350 Low idle?
- 2009 IS250 Front Bumper
- carbon buildup and walnut blasting question
- Certified vs Original Owner
- Thinking about a gen 2
- Eng light on after gutting cats. Help
- Is250 awd
- LED Headlight Bulbs on ebay
- 2009 HID Headlight
- Need help identifying part on engine block
- Lost fuel line washer
- 07 IS250 - Oil Maintenance Req light
- Remote starter
- New Guy Here!!
- 07 is250 vs is350 cons pros
- Anyone switch to 0w30 for winter?
- Spec stage 1 clutch and Fidanza flywheel
- Stereo Dilemma - '07 IS250
- Swapping steering wheel controls
- 2008 Lexus is250 brake problems
- Where to buy upper control arm bolts (not the arms itself)
- 08 is250 Oil Leak after Carbon Build Up Repair?
- RPM's Fluctuating - Opinions Appreciated
- Alignment adjustment help
- IS350 79k miles: To Buy or Not To Buy? Help!
- IS350 79k miles
- DIY: How To Tuesday: add STI lip in your car!
- DIY: How To Tuesday: Black door handles
- Starter change help
- Emblem color change
- High milage 2008 IS 250
- Question regarding transmission and warranty
- will my battery die?
- Is250 backup camera trajectory issue
- 2009 to 2011/2012 F-Sport bumper conversion with PCS grille?
- Lexus is350 2006 [connected battery backwards]
- Joe z intake/exhuast
- F sport frame on non f sport?
- Car won't start seems like it's system is locked
- alignment after fsport sway bar install ??
- Should a respray hold up as good as factory?
- Another TPMS problem
- 2010 Lexus IS F {VS} 2010 Lexus IS350 with F Sport
- Is350 turns on and accelerate massively then shuts off
- loss Power Steering, car wont start.
- 2010 IS250 AWD - Automatic Transmission Problem?
- Picked up another IS350!
- update on my car
- Rear view mirror camera
- Suspension fitmen Question
- 2008 IS 350 bumper pricing
- NavTool Beta Testers Wanted
- Aftermarket Audio
- Cam Gear Rattle
- Tire Pressure Question
- How do you change door lock settings back to standard?
- Fidelity Warranty Services Extended Warranty - Anyone Have Experience?
- Lexus is250 sat nav unit
- Clicking noise when starting the car
- IS250 parts
- no rca input for backup cam
- Commute IS250 vs. IS350
- 2013 front dome light cover
- Ventilated Seats - constantly running
- P/S Locked
- navigation system touchscreen is not responding...
- Help on OEM Center Cap Size
- Is/gs exhaust compatibility
- Grinding sound when start the engine
- Scion Cold Air Intake for IS250?
- Thinking about getting an IS300... but I already have an IS250!
- Has anyone installed larger piping for exhaust?
- New body kit from black - pearl complete
- Opinions Needed!!
- Flyaudio Bluetooth
- Trunk Safe/Gun Safe IS250
- Bridgestone Blizzak???
- Problem with dirty windows
- radio & a/c no longer work (07 IS250 no nav)
- grinding noise when switching gears
- Buying a used IS350, got a few ?'s
- New Here Concerned about buying at 90K mile
- Is250 dash recall, any updates?
- CRC MAF cleaner to clean 2006 IS350?
- Small hole on Fujita Intake
- Front tire blew!
- Vertex front lip underlip splitter?
- Nokya arctic white 9005 DRL's
- missed shift oops suggestions
- AUX port replacement?
- F sport intake tube
- Replace or try to fix transmission
- 3is bumper conversion-the greek way!
- 2010 is250
- Winter tires height for front: 225/55/r16?
- 2006 IS350 HID Headlight & housing Replacement, OEM or aftermarket?
- Headlights in oven.
- How-To Tuesday: Make Your Lexus Smile With a Sweet New Grille
- 2008 IS350 Before/After Picture.
- Check Headlight System after Air Instillation
- Poor mpg on 2008 Is250
- 350 Engine Replacement
- Help with exhaust setup
- New wheel setup
- 2012 oem led headlights problem
- Cell Phone Poll
- catalytic converter is 250 warranty anyone?
- Headlamp repair due to condensation
- is carbon fiber trunk
- Headlight issue
- How do i turn off airbag
- Replaced Battery - Still Dead, Electrical Smell?
- Scratches on driver and passenger's windows
- 2012 IS250 F Sport with Factory Tokico??
- DIY Lexus Headlight Ballast Replacement - Re Wiring - No Headlight Disassembly!
- Car not starting after pumping
- Carbon Issue After...
- GS400 Wheels
