- California Emissions Warranty Enhancement
- Exhaust setting on the climate control for the GS
- odd headlight cleaning experience + tip
- The ignition switch gone bad??
- Bad experience: Ebay and Lexus of Orland
- Compustar 2 way alarm/remote starter?
- Where is the starter and solenoid on-
- Where to buy lifters?
- Oil filters
- Questions about Certified Pre-Owned warrantee.
- Need help changing rear brake pads and getting rotors off...
- 1 last question on timing
- Timing adjustment
- Please help-timing
- After market warranty? Suggestions
- Lexus Engine Number
- Woodfield Lexus has a very nice service department...
- A/C, hot in one vent cold in another
- Need help with diagnosis!
- tan leather seats turning green
- Spoiler help
- My Experience: Don't ever use Dexcool
- The JDM/Jspec trend
- Tires rotation
- Low beam replacement on a 92 ES
- The cost of 15K service for GS300
- GS400 98 Spark Plug Change
- Attn: All those waiting for CL/LOM discount cards..
- Cold Lexus Automatic Transmissions?!?
- How can I tell if my TPS is bad?
- Longo Lexus
- CD changer
- Alternator Replacement
- low low gas mileage
- Where to get washer nozzle?
- PS Return Hose ?
- Correct ft/lbs for oil drain plug?
- SC430 Creaking noise
- what kind of oil for gs400?
- RX300 drive shaft flange bolts
- new engine needed help please
- Oil Additives
- weird rattle
- Shifter problem...
- Silencing/Preventing Creaks
- Transmission shifter problem
- Clogged wiper fluid nozzle
- Air temp from vent............
- 95,000 mile Maintence
- 20004 Oil Filters for Cheap
- Coolant Leak- casting plugs
- trac light/check engine light/o2 sensors
- Cooling fan problem
- Power Steering Pump Seal Kit
- Replacing motor mounts
- Oil Question
- No heat in my car. Please help, it's cold in WI
- Center vent fan makes noise... help Lexus Techs?
- Oil filter lowdown 20004 vs YZZB5
- Newbie here with a dumb question... (long)
- lx470 suspension problems
- How do you jack up a lowered car?
- PCV Valve Cleanout
- how do i change the spark plugs in a 1999 gs 300
- Valve Tightening of VTT-I Engines
- what parts do i need?
- GS300 Brake Job
- Oil Consumption with Synthetic Oil
- OBD-2 Scan Tools and Lexus Extended Parameters
- Timing Belt Question
- Changing the o2 sensor?
- Good non-dealership mechanic Northern Virginia/DC
- CD based Service Manuals for 98+ GS
- jack stand support
- Dealer Maintenance History Printout
- Great TC writeup / info
- r134a upgrade
- overdrive light
- RADIATOR fluid..MISSING?
- Difficulty starting this morning
- Battery advice please
- ES-300 Timing Belt Change?
- 40k km service
- Paint behind both rear tires
- I ripped my rubber...
- '99 GS400 Fuel Cut-Off
- Hardwire a Valentine radar unit
- Code 71
- Dead AC outlet
- Heat direction to feet is not working
- My 98 GS400 won't start...
- What would you have done in a tune up?
- Climate Control Indicators fail when its cold
- Can you use Dexcool in our Lexi???
- Diagnostic Fee for Service at Dealership
- Service in Atlanta
- My GS fell apart last night!!!
- Lexus Maintenance Recommended Schedule
- "Re-torque Drive Shaft Bolts??"
- 2002 IS300 Alignment Specs
- Replacing xenon bulb on SC
- Trouble Code P1346
- 60k Service??
- Timing Belt change price quote
- Car Dealer suddenly Turns On ME!
- Where's the fuel filter?
- Redline Fuel System Cleaner
- cooling fan on 93 sc400
- Scheduled Maintenance?!?!?!
- '97 ES300 Timing Belt questions...
- Battery Question
- Spark Plug Issues
- Just changed my differential fluid..but i only used 1 1/2 quarts..
- Anyone doing oil analysis
- Clip for weak hood struts?
- Re-torque drive shaft flange bolts on RX 300?
- 60000 mile service on 2002 LX470
- Fuel Injector Cleaner
- Maintenance needed at 1000 miles?!!
- Oil
- Anyone changed mounts by themselves?
- Valve Tapping ?
- Uneven Treadwear, What's it mean?
- will aftermarket Air Mass Sensor increase performance?
- Wrinkling seat cushion...
- 1998 GS400 Rear Rotor
- Changing rear axle CV boots
- Engine Code 1133
- Changing A/T in '99 ES 300
- well... the gs4 just left me stranded..
- Is some coolant loss normal? Should I use distilled H2O? What AF type should I use?
- Safe to drive without power steering ECU connected?
- Pedal position sensor problem?
- ITG Air Filters
- Japan made Air Filter for LS400??
- Smelling Gas :( in '95 SC400
- True or False? Lexus doesn't make new alternators
- 2000 ES300 HID leveling system help
- Radiator hoses bad = don't drive long distances?
- OEM or Bendix brakes?
- Replacing Window Regulator
- will a tranny flush fix engine shake?
- hrs engine shake and rough idle gone! OEM plugs back in
- heating and cooling system
- Lexus Valve Adusting Tool
- Removing inner front door panel
- EPT Sealer?
- Skipping LS400
- Inner Tail Lenses (Trunk) ?
- Headrest removal
- How to remedy knocking in a '99 RX300
- 1990 LS400 dyno results!
- Will you void Transmission warranty if you dont get the fuid exchange?
- Power steering making AWFUL oise when cold..
- I was at McGarth Lexus in Chicago :(
- bought motor mmounts off ebay-do they look new to you?
- Lost Horsepower ?? Question....
- Stevens Creek Lexus or Magnussen’s of Fremont?
- 93 ES300: Cold Air or Short Ram Intake???
- LX470 Oil Change
- GS Sideview mirror controls
- Bizarre Steering Problem Solved
- Lexus service at Toyota?
- How to clean Power Steering filters?
- How often do you really change your plugs?
- 94 ES Seat Heaters not working
- Wiper blades...
- Hunting for the elusive radiator drain plug
- brake question in LS form
- ES300 Vibrating Question...please help
- 75K maintenance
- Bay Ridge Lexus
- Lexus Service costs: Getting Worse?
- catylic converters?
- sc400 trunk shocks failing - aftermarket source?
- Winter oil time!
- Leak detection dye?
- SC400 Timing Belt
- Radio master/security code?
- buying a new lexus !! changing keys ??
- oil
- Where to go for KYB shock?
- center consul button illumination
- Engine Braking
- whistling sound at 40-50mph
- Changing Transmission Fluid
- Wanna Swap
- Brake light on dash goes on and off... (00 GS4)
- 90k Svc on LS
- oil change
- wiper blades
- tranny filter
- Lexus in michigan
- 2nd gen. wiper blade size???
- Garage Floor Protectors
- Which repair manuals to get from dealer for 93 GS3
- Oil Changes are now $11 (!) at Firestone dealers.....
- 60K mile Service
- Fumoto Oil Valve
- Rear brake pad replacement on '97LS
- Help locating Power Transistor 93 SC4
- Changing the gas filter?
- suspension
- best service for Lexus in Las Vegas, NV
- check engine light
- Is the '93 GS service manual sold on ebay any good?
- Brake problems
- Bad smell from AC
- brake pad's
- Tilt Steering doesn't work well.
- rumbling, rolling, vibration
- How much brake/power steering fluid do I need?
- Where is a good place for service in NYC?
- NavTech database errors
- Quick help from a Tech..
- Changing fog light bulbs on 93 GS 300
- My high mileage oil experiences
- Oil filters comparison for your lexus
- storing vehicle...
- 1st GEN GS300 rotors
- hesitation???
- jack stands
- lx470 shocks
- How to Break-In Your New Car
- Winter Storage
- Oil Filter Clarification V8
- yellowing of door trim
- Timing Belt Change Frequency: Need or ?
- Coolant drain plug locations SC400
- Synthetic Oil starting at 86,000 Miles
- Questions for DIY oil changers
- Door lock not working?
- HELP HELP- what can it be
- Tire Rotation
- Changing a brake light in 93 SC400
- funny story about my alternator
- My 99 GS has bad radio display
- Healthiest/Unhealthiest American Cities
- TCS warning light
- ever had your GS serviced by Longo?
- Anybody's GS400 emitting LASER that sets off their radar dectors?
- Tail light on 99 GS 300
- Brake Job
- Over Heating
- Interior lights don't always turn on when door opened
- Swapping brake pads
- Drivetrain rumble/vibration sc400-basics done
