LX470 Oil Change
Old Nov 5, 2002 | 11:57 PM
LX470FAn's Avatar
LX470FAn
Default LX470 Oil Change
Quick question, I am interested in changing my own oil in the 470 but am not able to locate the oil filter nor the drain pan bolt.
Are they hidden behind a protective covering under the vehicle?
Thanks and sorry for the naive question.
LX470FAN
Old Nov 6, 2002 | 10:35 AM
DevilDog's Avatar
DevilDog
The oil filter is, you will see a small cover that can be removed to access the filter. It's held with two 8mm bolts. The oil drain is simply mounted to the bottom of the pan.
Old Nov 10, 2002 | 09:55 PM
LX470FAn's Avatar
LX470FAn
Default Thanks...
Thanks for the advce, I found both items. The thing that confused me was the drain bolt was also behind a shield.
ExtrmeLex
Oct 19, 2013 07:40 PM
yasu
May 18, 2010 06:49 AM
edbro
RX - 1st Gen (1999-2003)
Jun 3, 2007 04:13 PM
toy4two
20
Nov 26, 2003 03:20 PM
LX470FAn
Nov 10, 2002 10:45 PM
