Cooling fan problem
Old Dec 23, 2002 | 02:00 PM
M-lex's Avatar
M-lex
Question Cooling fan problem
I have a problem with my 98' GS300. when I turn the key the fans start running immediately even if the car has even been driven. I shut-off the car because I do not want to burn out the motors. Does anyone have any idea what this could be?
Old Dec 23, 2002 | 02:58 PM
PHML's Avatar
PHML
Master Thread Closer!!
Take it to your mechanic and have it checked out.
Old Dec 23, 2002 | 03:16 PM
rominl's Avatar
rominl
exclusive matchup
umm.... not sure if i understand what you saying. if i put my key in, put it in stage 2 (there are 3 stages, where stage 3 you will turn on the engine) and the a/c will start working and blowing air?
Old Dec 23, 2002 | 04:15 PM
M-lex's Avatar
M-lex
The fans come on even when the key is in stage two. I probably will end up carrying it in to the dealer.
Old Dec 24, 2002 | 08:19 AM
tinygs's Avatar
tinygs
Default Re: Cooling fan problem
Ive been waiting to hear someone besides myself complain of this.... Ive had this issue for about 4 months. The funny part is that while the car is running the fan cycles on and off with temperature fluctuation just as it should. When I turn the key to the accessory position, even before starting the car, the fans are already on. I believe it is a sensor. I though at first maybe fan relay, but, if I pull either fan relay the fans stop just as they should.... Someone PLEASE give us the remedy if you have it.......
Old Dec 24, 2002 | 12:47 PM
mcgong's Avatar
mcgong
Try checking you temperture sensor or check you main engine relays. There is usually a relay that controls the fans. I had a similar problem with one my Toyotas and it ended up being the relay.
Old May 28, 2004 | 12:15 PM
KevinLe's Avatar
KevinLe
i having a same problem with my 2000 gs4 cooling fans, both of them start running when i turned the key to 2 stage, i know its not normal but just dont know what happened, i already check all the relays even that main engine relay where close with the battery but i still couldnt fine any problem with it, i will check the temp sensor later but i dount it cus...... when i unplug the sensor cornecter the fans still running, unless its just how is it,
if anyone have this problem b4 and been fixed so please let me know
thanx alot
kevinle
Old Jun 3, 2004 | 11:57 AM
whitegs3's Avatar
whitegs3
I have seen this happen a few times. On Toyotas( and Lexus) cars the fans will come on with the key if the fan temp sensor switch is bad or not connected.You can always check the temp sensor with a multimeter and some warm water .If the sensors circuit is open all the time that is your problem.This way if the sensor is bad it keeps the car from over heating and blowing your head gaskets.
Old Jun 3, 2004 | 05:50 PM
VVT-i's Avatar
VVT-i
I think the temp. sensor at bottom of your radiatio is disconnected,. I've seen a few of this problems when the customer went for an oil change at some quick lube shop. First thing they do is disconnect the temp. sensor, turn the key on and now your fan is running all the time to cool down the engine and make it easier to get to the oil filter without burning their arms.
pjarvis
Jun 30, 2016 12:25 PM
Kiddjdm
Apr 13, 2014 07:49 PM
mbaker7
Mar 9, 2012 10:15 PM
mleads
Sep 1, 2010 08:56 AM
doule
Dec 9, 2004 06:15 PM
