Air temp from vent............
Old Dec 25, 2002 | 07:24 PM
D.K.'s Avatar
D.K.
Default Air temp from vent............
In my 90 LS400 when I select vent only(No air cond.) and adjust the temp to 65* the air seems nice and cool. Or it seems to be at whatever the outside air temp. is at that point in time. This time of year in San Diego it is great as I don't need to turn on the AC.
Now in our 93 LS400 when I do the same thing(in this case there is no 65* reading it say's max cold instead) the air temp coming out of the vents is not AS cool as in my 1990. It's as if the heater is SLIGHTLY on, warming up the air to a slight degree. Mind you, it's not hot air by any means, it's just not AS cool as in my 1990.
It is a little annoying as I sometimes have to turn on the AC if I want to drive with the windows up.
D.K.
Old Dec 26, 2002 | 08:12 AM
VVT-i's Avatar
VVT-i
Check the freon level on the 93 or you may have a small leak in your A/C system.
Old Dec 26, 2002 | 08:39 PM
D.K.'s Avatar
D.K.
Would a small leak in my AC system have any effect over the air temp coming out of the vents when I'm on "vent only"(non AC mode)?
D.K.
Old Dec 26, 2002 | 09:19 PM
VVT-i's Avatar
VVT-i
If the A/C system turn off and the fan off, then you'll only have the fresh air coming from the vent. The vent temp. will be a little bit warmer than the outside temp. One more thing to look for on the 93 LS, the A/C filter behind the glove comparment. If the the A/C filter is clogged up then the fresh air will not flow properly. You can look this up in the owner manual on how to remove it.
Old Dec 26, 2002 | 10:50 PM
D.K.'s Avatar
D.K.
Good point........I'll take a look at that. Thx.
wise2k
Jun 27, 2013 07:17 AM
sdshaddox
Jul 26, 2011 07:46 PM
teefbee
Jul 4, 2011 11:40 AM
acnup00tl
Mar 8, 2009 03:21 PM
LVLarry
GX - 1st Gen (2003-2009)
15
Feb 19, 2008 04:37 PM
