View Full Version : Maintenance
- gas gauge not working in sc300
- dump valve location
- toyota fuel filter for sc300
- Trouble starting SC400
- headlamps dim
- voltage regulator
- RX 300 Oil Change
- Trouble with oem stereo
- PS pump
- What size socket do I need for Lexus wheels?
- 2001 ES 300 PCV Valve???
- Transmission, Differential, Transfer Fluids
- ES 300 Trans & Diff Fluid Change
- cooling system stop leaking liquid products?
- Brake Booster install
- Free Synthetic Oil
- Spoiler LED Brake Light - Replacement Source
- Tire Rotation
- Toyota Camry Rotor Change
- Scraping on turns
- Squeaking clutch
- windshield wiper problem
- How much to replace rear main seal?
- Seatbelts not retracting ? Solutions !!!
- gs400 spark plug gap question on ik20's
- switching to synthetic...
- 120k service
- 45,000 Mile Service Question
- Sheared off screw-how to remove
- Hi guys. What's the "chock oil leak"?
- A/C leak :( suggestions and comments welcome
- Ignition greasing/lighting/cover replacement ?
- check engine light on?
- Disc Brake Material
- Need advice on oil for my new SC430
- Advice On Oil ?
- Pound R12?
- 60k Service at Longo
- Chasis Lubrication
- Gas Smell in Garage.....
- brake warning light when cornering
- leaky exhaust manifold
- EGR filter clogging quickly
- How to recharge A/C?
- I Had Fun Installing New Timing Belt This Weekend
- After hard acceleration...
- Oh Man, Lexus Delivered Me A Dud
- Oil Light Comes on from Time to Time
- How to perform "induction service"?
- Intermittant stop and tail light
- need to remove bolt from frame
- Possible M1 replacement for the 90915-20004?
- quick question about bleeding brake.
- mobil one 75w-90 gear oil
- Things to be done on a 120k sc300
- Is a brake flush neccesary..
- Power steering fluid change--incremental method
- gaskets
- Steering wheel problems
- GS400 Oil Filter
- what is the best Differential oil to use for GS430?
- 1 question bout lemon law
- turn signals will not work on 96 sc400. HELP !!
- rough starting...
- Mail Order / Internet Lexus Car Parts
- Synthetic oil comparisons?
- 90k service (any good independent shops)
- Differential Problems ???
- How long can my GS300 sit for?
- Oil change in SFBA
- Adding Coolant
- Lexus Shop/Repair/Service Manual
- Water in my GS
- Help! Smog Check Time!
- OBDII Readiness and Drive Cycle
- air conditioning (r12-r134 conversion Qs)
- Rust on wheels
- 1998 LS400 oil filter location
- Some one pls help running rough LEXUS DeaLeR is NO help...timing?
- ABS question
- Battery/Starter/Genius Lexus Dealer
- Passender Side Window won't work
- Want to know your Oil Filter Review?
- resurface pads when changing rotors?
- Rough Idle Fix Write up (How to clean engine)
- Heater blows cold at low rpm
- How to change the fuel filter sc300
- LS 400 (94) Won't Start (Or do anything else)
- 92 SC Wont start =(
- Air condition
- Keyless entry remote battery replacement - what type of battery?
- QUICK HELP! Thermostat Location on 92 ES 300
- What grade gasoline do you use in ~your~ Lexus?
- Timing Belt Replacement Problems
- Cap and rotor replacement on 1991 1UZ-FE
- navigation system and rattle in front dashboard
- Hood struts not holding up
- laser alignment at lexus dealerships?
- Intake problem anyone?
- ignition box experts
- Oil Filter for 1MZFE V6 engine
- Oil change at 10.5K analysis
- Transmission Behavior
- 10,000 mile maintenence Cost
- Replacing a Stripped Nut
- Maintenance Schedule
- I got the last case of 2000-4 oil filters
- Time for 50k tune up
- adjusting SCxxx headlights
- Driver's side seat power
- battery problem - change it or charge it?
- sc problem
- The Lexus Dealer changed my oil..and put in regular**Not Full Synthetic!
- independent service shop for KC area
- Brake rotor replacement LX 470
- Moonroof Rubber Seal Maintenance
- Auxillary Fan Relay Switch
- GS400 90,000 mile timing belt question
- Brakes - 96LS
- which brand of coolant??
- cleaning the undercarrage?
- My Dash Lights Won't Go Out When I Turn The Car Off
- Lexus Extended Warranty. Beware!!
- Toyota Oil Filter Part Number Change???
- A/c recharge for ls400
- cabin filter - which way?!
- Auxillary Fan wont shutdown
- 98 LEXUS GS300 Windshield
- whining noise - HELP!!
- SC400 Spark Plug wires
- Changin Spark plugs
- squishy/squeaking noise from rear-left wheel
- Bought Car With Dead Door Locks
- Oil Filter
- hitting the 100k zone what should i do???
- SERVICE EXPERIENE AT McGRATH?
- Brake Pad Signal
- Mitchell repair times for sc300 wheel bearing
- Coolant Question
- check engine codes
- SC wont start....help
- 95 SC400 1-7 code what does it mean?
- ? on repair costs for a sc400
- How long should I go on these??
- how to change auto. tranny fluid?
- Windshield replacements
- Flooded engine
- Busted Radiator, 7 hours from home....
- Individual side view mirror part?
- spark plugs for 99 gs300
- Brake problem out of the blue.
- Suggestions anybody?
- Changing the Oil filter on 96 sc400
- spark plug for 99 gs300
- engine vibration
- Tires wearing like mad
- Basic tools/supplies for roadside repairs
- question for all you lex experts ....
- 92 sc400 stalled and now wont start
- rear cupholder removal?
- Oil Filter
- Another article on Fram Oil Filters.
- Now entering the independent repair shop Twilight Zone.
- service at magnussen's lexus rocks
- Oil Filter Anti-Drain Back Valve Test - Post your results here
- Failed inspection ... high HC levels
- What differential fluid are you using?
- Called Lexus, ATF Questions.
- SC300 and GS300 same exhaust?
- Metal Bar on Driver Side Windshield Wiper
- WT-i: I need some help!
- cant start car....?
- my car won't start
- Oem Battery
- Toyota type IV fluid??
- How much is too much ?
- VF1, VF2 diagnostic connector signals
- Oxygen Sensor 2000 LX 470
- What Order to Bleed?
- Over heating 92 es300
- RX300 front suspension sounds...
- Sick of searching - For real what should I do ?
- what kind of battery are you using?
- Failed emission test, please please help!
- Having some issues starting an RX300
- Oil Filter Question
- No start after changing the starter
- Our old beloved 20004 oil filter versus this new YZZD3 filter. Anyone know anything?
- Oh, NO!! Where'd my 20004 go??
- 93 LS400 Code 25 , (check engine light)
- air bags
- EGR Pipe Replacement
- ABS warn light ON and TRAC OFF blinking
- Please help...total frustration w/ Lexus Service...SC430 and ES300
- Rear axle shaft leak
- Dash "BRAKE" light on
- Door Lock Acuator
- Need a good repair shop in San Diego
- i see the recent discussions about 60K service
- valve adjustment
- Non dealer Mechanic in Houston
- Setting Engine Valves?
- 00 es300 turn light problem
- oilpan reseal
- NGK Vs Denso
- Accident Picture, Should keep or total loss?
- few minor things starting to become apparent
- Use of Jack Stands
- Transmission Fluid Change?
- Cost of 60k service
- Still having problems...CLIFF NOTES
- Difference between Nippon and Denso oil filters
- sc400 engine NG???
- Craking sound on steering wheel turn
- Where to put jack stands on GS...
- Strange oil leak on my new SC430 (comments welcome).
- 97 ES300 Spark Plug Replacement
- HELP! 2004 IS300 DIY "Maint Reqd" light reset for oil change
- Spark plug replacement recommendation on all Lexus models.
- OH NO! Oil Leak on pass. side engine...
- HELP: Where to find a parts list for an SC430?
- Exclamation
- how can i completly clean the master cylinder resivoir?
- seeking 98 gs400 AC compressor
- If/when you go to the dealership for an oil change....
- 90K Service advice please
- Torque specs needed on Transmission pan bolts. GS400
- How cheap can you get ????
- After Market Repair Manual
- using middle gas grade for LS430
- Which service sked should I follow?
- Shift Knob
- SC 400 Shift Knob
- Electrical System Problem
- disable telescopic steering 98gs400?
- How much rust?
- Anyone own an AC Floor Jack DK20 or DK13
- What to do with used coolant/antifreeze?
- Alternatives to the yellow grease used in the tilt steering worm drive?
- Key programing
- 98ES milage went down
- Power Steering Leak?
- help, water in engine
- ES trans acts different in cold weather
- Is LS430 oil change easy to do at home?
- How much does are the dealers charging for a 90K service on the SC in your area?
- Fuel Filter
- Engine oil: 5W-30 and 10W-30 fuel economy
- Interesting - Oil Filters are the Same...
- Battery Removal
