headlamps dim
Old May 28, 2004 | 05:28 AM
norm1949j's Avatar
norm1949j
Default headlamps dim
My 1995 SC400 works great, but often when I hit the breaks or turn on the turn signal, the headlamp dim.
Any ideas?
Old May 28, 2004 | 05:31 AM
jeremyp111's Avatar
jeremyp111
Yeah, take apart your battery terminals and clean them up. It should be good to go. Pretty common on the SC. If that doesn't fix it then you may want to check the voltage of the battery. Sometimes it's the ground calbe itself that's corroded so check that too. let us know how you make out.
J
Old May 31, 2004 | 08:53 PM
cuttingedg's Avatar
cuttingedg
Wink
you definately have a voltage problem.the cables and cable ends are a good start.i have replaced a few that have a voltage drop that can cause this situation.if you can't figure it out i have a repair shop in lancaster,tx. and we specialize in Lexus and Toyota.
ImmortalR
Jan 24, 2012 12:32 PM
chnk
Dec 23, 2010 03:07 AM
89MA70
Mar 20, 2010 07:56 PM
mk4r34
Sep 16, 2009 09:29 AM
x3goldz
Apr 26, 2001 06:21 AM
