NGK Vs Denso
Old Feb 15, 2004 | 08:58 PM
HotBoy's Avatar
HotBoy
Default NGK Vs Denso
OK so I was going to clean my throttle body today and change the plugs.
How are the NGK iridium plugs as compared to the denso's I know the majority here have denso's.
The price difference is $5 per plug. Just wondering what the difference in 2 iridium spark plugs could be.
Old Feb 16, 2004 | 10:44 AM
persian451's Avatar
persian451
ngk is pretty close to denso. I have ngk double platinum in my LS, it works great no hesitation or rough idling. save the money and go wth ngk, unless you want to piece of mind of having oem plugs
Old Feb 16, 2004 | 01:10 PM
CarBlog's Avatar
CarBlog
Personally I use NGK V-Power in all of my vehicles. It's only about $2 per plug at most, and though it's not a 100,000 mile plug like platinums are, out of all the tests I've seen regarding performance and combustion, it seems to be one of the better plugs. They're available in several different temperature ratings, and I usually search for the 7 rating (colder plug) as it tends to perform better under higher compression vs. say a 5 rating plug. OEM is not necessarily a concern of mine, so long as the plug does what it's intended to do, and does it well.
Old Feb 16, 2004 | 01:44 PM
Richie's Avatar
Richie
I have always used NGK plugs in all my cars.
Never had a problem.
Old Feb 16, 2004 | 08:12 PM
claus44's Avatar
claus44
running NGK Iridium IX, no problems nor hesitations
Old Feb 16, 2004 | 10:00 PM
bishop977's Avatar
bishop977
what about the toque master plugs? are they ne better than the ngk
http://www.torquemaster.com
gapxguy
May 22, 2022 09:52 PM
Rock-a-Lex
Performance
Aug 17, 2011 08:46 AM
scdroptop
Apr 6, 2011 06:29 PM
sc_lang
Jun 24, 2007 09:01 PM
indypwr
GS - 1st Gen (1993-1997)
Oct 2, 2002 07:45 PM
