- 93 SC400 Idle problems (idle rises/drops/rises/drops)
- Idling very high on SC300
- JZA70 Supra 1JZGTE clip work for soarer swap?
- Car Dies
- How long does a 2JZ-GE engine last?
- Just joined the 1JZGTE club
- R154 Tranny swap
- Crank bolt removed with clothesline?
- Help with 5 speed shifting issue
- tensioner bearing?
- v8 turbo
- driveshaft bushing?
- Supra radiator driect bolt-in?
- Oem Ram Air, cost $0
- NA-T question
- sc300 a/t to manual 1jz Q's?
- help! engine shuttering
- How many "cranks" does it take to start the SC400 engine-reluctant starter?
- Anyone here fix their coolant reservior?
- supra TT 6 spd for SC300 AT
- Fuel System
- Where can i find motor mounts?
- 1and2JZGTE guys website
- HELP! SC400 Air Flow / Engine Smell
- Finally got car fixed....
- Tuned the car on pump gas last night...
- Clutch pedal squeeking
- 2jzgte with 5 speed or 6 speed supra tranny?
- ecu issues
- First time at the track in the 1jz SC300 (56k beware)
- Hello. former Honda owner turned Lexus owner here w/ some ?s
- Heater Problem Pleez help
- Where do i put the transmission cooler
- SC300 Auto to 2JZ-GTE Swap
- Raising the rev limit on SC400
- ? about installing a 5 speed
- engine & tranny swap?
- Has anyone every heard of this or have this happen to you
- Tranny Options
- Exhaust Pics
- Trouble starting
- turbonetics dyno?
- radiators
- Question about SC300 shifter knob
- another exhaust thread
- Exhaust, brakes, and car oh my
- throttle respond **PROBLEM**
- So what actually breaks in our 5 spds?
- auto to manual 1jz swap
- My car stalled???
- Brought the car to Dyno - Video
- 1500$ and not an idea
- tranny or clutch? please help!
- 7m gte turbo, intake & exhaust manifolds
- Question about replacement SC300 shifter knob
- Whirring Noise
- Interesting 1jz timing belt info
- Old shifter design on newer SC300?
- car cranks and fires up but the engine doesn't hold idle
- aftermarket pulleys
- another sc300 na/t
- Problem w/ auto gear shifter
- $500 performance gain?
- Magnaflow Exhaust Tips
- Smog Results. Barely Passed???
- Can't get the shifter out of P
- Buzzing sound
- HELP! Need advice on TC for my SC4
- 1jz swap
- 92 sc300 stalling
- head gasket for V8
- Radiator Removal for SC400?
- Clutch Petal Adjustment
- who's running nitrous?
- clutch or flywheel?
- SC300 Automatic Transmission Shifting Hard
- Injectors? what kind are these?
- MSD for SC 400
- Cat or Resonator?
- $4500 for a manual 5speed SC or $2500 and convert it? (doing 1JZ swap, too)
- 2jzgte In Sc3
- Coolant Hose Break
- 1jzgte Wiring Info!!!!!!!!
- Finally I Got My SC300. Opinions?
- GUY NEED HELP w/TC AND LSD SETUP!
- help getting egr pipe out of intake
- step by step clutch replacement?
- Auto Shift Knob Interchable?
- JDM Dual Exhaust Video..
- Buying a cheap 5speed SC... using current tranny for Supra swap? Labor questions...
- MSD Install
- My NA-T In a Video :-D
- Is this a Deafening Almost Dead Differential?
- Swap 1jz Into Sc400
- 1UZFE Raised Redline? Anyone above OEM?
- why tranny so damn hot???
- Exhaust video
- 1JZGTE swap
- Who is using MAP-ECU mapecu?
- Running EXTREMELY hot
- My NA-T 1/4 Miles
- Valve Spring Question
- No Pictures Here ;)
- Soarer Automatic Transmission
- Spark plugs?????
- Dreaded Check engine light is on.
- Tornado
- 1jz single turbo manifold
- Calling all NA-T Sc300's!!!
- cylinder #6 trouble
- Shifter Trouble
- transmission question .. need some help
- Water and water wetter only.
- Head gasket replacement..
- Nitrous and the SC300
- Ls400 AFM Flange
- 1jz gte timing belt and cams
- Air Ciondition heater Blower not coming on
- Spark Plug Gap
- BFI Opinions
- Resonator Exhaust Question 97 SC400
- 1JZ power
- Opinions on this 1JZ intake manifold, and 90mm throttle body
- my overdrive doesnt work..
- bad pumpkin
- Sticky gas peddle fix!
- The SC is sounding like a go-kart.
- 430 engine/transmission swap any info?
- Post your 1jz swap issues
- Few Issues With The Engine Maybe Cat?
- Question about Dave H kit
- Misfiring
- mteele's 1JZ swap pics (56K take a nap)
- SC getting turbo
- Sc300 Lsd?
- Thinking About Exhaust
- Some pics of my new exhaust
- Differences between Soarers
- supra auto TT rear is not a direct bolt in!!!!!
- Custom DIY
- So i got some $$ to spend....
- re-use head gasket
- Need cheap clutch
- Pictures of my exhaust
- Finished fabricating my frount mount piping
- Injen intake
- Idle Surge
- Question about snorkel
- Blitz Nur-Spec Exhaust
- Who has/had a 2JZGTE on the SC 5spd tranny
- How to Flush the Transmission
- v8 or TT 91-94
- Does 95 sc300 stick come with LSD?
- Need new radiator for sc4
- Building Drift Sc300 With 2jz Need Help
- 1JZ auto to 5 speed SC
- Problem with speedo and tranny
- cat back dual exhaust test
- Oil Leak Help
- Motor mounts search
- O2 Sensor Choice (Already Searched)
- Interesting 1jz vs 1jz w/ VVTI question
- Turbo 1UZ Dyno result, 389 HP, 509 trq. 12.4 PSI. Wow
- My 92 5spd will not start! Help!
- Drive Belt Problem
- Power steering pipe leak
- question involving 2jz-gte swap and TRAC
- stalling on start up
- Fixing a warm start problem
- A Few Questions for the 1JZ-GTE Owners
- Cruise Control
- GOD i hope this fixes my stalling problem.
- 8 extra injectors-pics-TT sc400
- Vid or Sound clip of 1JZGTE??
- sc300nat 6-speed
- sc300 diff?
- funny noises leading to car breaking down
- Toyota Motor Ignition Overview
- SC400 Exhaust Decision
- Power steering replaced
- ISC valve maitenance on old V8 motor
- expensive repairs
- fan shroud
- electrical problem.
- Help needed w/ cooling lines SC400
- CEL after timing change
- 1jz-gte SHES ALIVE!!!
- ebay brakes and clutch kits?
- Where to find USDM/JDM 2JZ-GTE
- Where to get an engine
- CEL is on
- torque converter
- Max Performance
- 3uzfe
- Which Forced Induction to Go With
- clumping sound
- 3s-gte
- Greddy exhaust for SC300 and GS300
- LOW IDLE, Help
- Hi, Everyone!
- My auto tranny seems to be dying...couple of Qs..
- SC400 unplugged MAF
- car wont start after tensioner install
- List of necessary items for BFI
- New performance cam and pulleys
- So, the countdown begins....
- Quick Answer needed regarding stock O2 sensor studs
- 93 sc300 5speed clutch/gears
- Concerning '95-up SC300 intakes
- SC 400 Nitrous
- When Running Single Exhaust, How Do You Fill in the Other Hole in the Bumper?
- squeaky A/C compressor
- Max hp from 2jzge motor
- something's up with my crank pulley
- basic timing
- Pumpkins
- Ran into problem while cleaning TB and changing spark plugs
- Occasional problem starting the car
- SC400 supercharger!
- 1jz question?
- soarer 5-speed
- 2JZ-GE/1JZGTE Decision HELP NEEDED.
- Anyone Have a Pic of a JIC ONE Exhuast on an SC?
- Magnet oil drain plugs
- best turbo for a 1jz
- PowerSteering and ElectricFan
- Timing belt question
- WRX 98' Turbo will it work on lexus with a lilo mod?
- SC400 electric fans
- look, flat torque curve on a 1JZ. What a coinsidence
- Changing spark plugs, cap/rotor, wires today
- 1jz 2.5 tt how hard is it ?????
- air noise (not what you think)
- 98 Supra Tranny in a 97 SC300?
- wrecked Sc fixing
- 2500rpm transmission noise
- 1jz w/5speed
- 1jz 5-speed
- which companies for custom top feed fuel rail?
- in need a R154 5-speed
- 8 extra injectors setup-pics..
- Broke Trans Input Shaft..
- diagnostic code 12 - no rpm signal
- Coolant Leak - Pics of source of the problem
- Some questions on the 2jz-gte/ge and 1jz swaps...
- 1JZ-GTE swap almost done
- greddy t78 or T60-1
- New alternator hot
- Help AUTO. stalling out and dieing!!!
