- please help me with sc400 slow on take off
- Start Me UP
- GT30 With 2jzgte ????????????
- Supra TT LSD...
- ~ 1JZGTE in a SC3 ~
- Sc400 2jswap need help!!!!!!!
- Sc400 Tranny Conversion
- power steering noise
- Nitrous Kit Help Please!
- My car keeps dying, any advice?
- GS exhaust fit in SC?
- Can i reuse the IACV gasket when cleaning it?
- 1jz or Na-T
- PS pump rebuild kit
- Bad gas - now the car has intermittent sputtering.
- Greddy SP2 exhaust for Supra TT...anyone have it?
- R154
- Burnt clutch, replacing it, what do i need?
- SC300 with a TT Head and TT Auto Questioins???
- WTB: Turbo Kit for my Sc300
- sc300 ecu same as gs300?
- Ignition Control Modules??? Opinions welcomed!!
- Mishimoto electric fans.
- driving with no maf sensor
- 1992 SC400 Car is bucking at 35-50mph!!!
- NOOB needs help and opinions!!!
- Supra USDM TT Harness Info - Need it
- Something bad happened
- Quick HKS FCD question
- Sluggish
- My NA-T project... for all you picture *****s(56k... doubt it)
- 1JZ-GTE running hella rich, S-AFC 2 help!!!
- battery light coming on after 3k rpms?
- my next muffler setup
- New 1992 SC400 troubleshooting, won't start... pissing me off!!
- Made lots of changes, ignition woes ensue
- 1jz swap problem...
- I need to make a decission; Best option for my bottom end
- tech meter help
- What is this plug on the Rack Pinion
- Camshaft question
- So if I cannot get my Blitz Nur Specs... which mufflers?
- LSD DIFF question?
- CEL + Cooling Problem
- weird clutch pedal operation? help me please.
- Engine covers?
- A/C Line Repair???
- Fuel Problem?
- help me choose
- Battery jumped backwards!!!Please Help me!
- OEM sc motor mounts vs Supra mounts
- sc400's....maybe cheaper headers.....
- New Help onFan blade.
- How to remove AC clutch? (diy request)
- not my sc but pics of my set up....
- PLEASE help me matchup these last wires
- Who has replaced a sc400 radiator???
- 1UZFE power loss: What's the real Culprit?
- WTB Air Intake For sale?
- what drive shaft???
- Newb with 1jz question
- Can someone identify this part?
- My 93 SC400 is dying, please help me diagnost the prob
- JZX100 VVTI 1JZ to SC300... Who has done it?
- wifes car acting very strange wont start
- middle of working:Need help fast
- Another 2jz-gte swap thread...
- Will a turbo Manifold from a NA 2JZ fit on a NA VVt-i 2JZ
- wondering!
- Differential flanges for new driveshaft
- DIY: Alternator Plug Repair Harness
- Driveshaft and Flywheel aluminum vs steel
- A/C condenser fan (electric)
- Drag wheel/tire fitment pics
- after car warms up , starter will not kick in
- Do... Bigger Injectors = Bigger Power ????????
- radiator
- thinking of going single exit..pro's/con's?
- Change filter now wont start
- What are the plugs!!! PLEASE HELP! Off main harness
- Intake Manifold w/ 2 fuel rails?
- Is the cams in time or am I one tooth off?
- How to NOT lose low end torque with this exhaust? Help!
- How much am I looking to spend on a turbo for an SC300?
- Good place to buy HKS 18 pound wastegate spring?
- Which Cometic head gasket? and what cc injectors?
- Turbo confusion
- SC400 Exhaust Questions
- would supra upper fit SC300 lower manifold?
- speedometer sensor for 1992 sc300 auto
- 92-96 Koyo High Peformance Radiator...cheap
- Big Dilemma...(Repairs ???)
- definitive difference in 92-97 vs 98-00 exhaust
- White smoke (tranny?) after driving car hard
- Mega Squirt 2
- Sc300 Exhaust
- SC400 Overheating Problems??
- clutch slipping a little in second?
- Overheating....I think.
- Code 71
- ??? about o2 sensor install
- Differential Fluid
- car won't start
- Cold start up!
- The nightmare: Aristo Wiring Conversion
- JUst curious.....
- How to drain gas tank?
- drive shaft joint angle? (soarer)
- car is dieing on me....
- Name this harness connector
- 1998 sc300 auto, thinking of motor swap? opinions?
- Need to replace lifters. (help?)
- Hesitation,black smoke,overheating ohh God help me!!!
- Need help quick, EMS for less than 6-700 hp?
- Crank Pulley/Damper Weight- HELP ??? 1 or 2UZfe
- Turtle crossing (sc400 sluggish)
- 1997 SC 400 weird problems after engine install
- Tremec TKO to 1UZ-FE kit, wonder if they can make a 2jz one
- 98 SC4 Diff = what LSD? 2jz-gte/th400 swap
- Custom tuning need info?
- Radiator Cooling Fan stays on?
- My SC400 dies out while driving
- After not starting, tried something...
- 2jz Soarer Goals
- ls1 engine swap
- Sc300 BFI build & Waterpump/timing belt change
- Indicator light?
- 2JZGTE into SC400 with MK3 R154....driveshaft query
- Clutch question
- A little help on a vpc for my boosted sc3
- 93 SC 300 Engine will not run after Tune UP (Help)
- please help me:clutch problem
- is there any other lexus diffs i can use in my car?
- 98+ SC300 transmission = A341E or A343E?
- 1JZ swap question.
- just swapped a 2jzgte motor and the climate control unit doesnt work!!! i searched
- I went 1/8th mile racing to test the car...then lost the bonnet!
- coolant line bypass free horsepower?
- Injectors
- Blown Differential
- Water pump/Timing belt
- Santa brought a present for my SC a little early. (Headers)
- Car overheated, steam, etc. now heater not working
- Need a little knowledge on a PS problem
- Help Aristo downpipe
- 2jzgte....swap/prep...........progress!
- CEL and vibration
- Oil Pan Question
- Greddy exhaust (for Supra) on SC300????
- mass air sensor
- Recent tune 740WHP (video)
- Will these IS300 parts fit?
- Rear click noise when put in gear
- Weird Shaking/Power Issues
- peg leg
- Official Cx Racing Stuff Ic and more:
- TC Replacement??
- heater problem 93 SC400
- new clutch!
- 02 sensor
- 2jzgte w/ R154 swap question and concerns
- Mysterious coolant leak.
- Help with Heat!
- best intercooler for the money?
- struggle upon accel
- SC400 V8 Biggest Problem
- front cat delete, will it burn the rear cat?
- electrical gremlin help
- Wont start
- What oil do you use in winter?
- Well an AEM FIC be enough?
- need information on engine swap
- soarer swap missing plugs on sc body
- Aristo Trans - Manual Mode
- Car overheats only at high speeds
- sc400 not running smooth
- HUGE loss of power
- GTE swap time; some elec setup questions for gurus
- Speedometer quits working above 30..
- Please Help Identify This Hose On Power Steering Pump
- My SC 400 rearend went out
- the difference
- Should I flush my high mileage transmission?
- Na-t OBDII O2 sensors... advice?
- misfire at 6300-6500 rpms
- spark plug wires
- So my speedo broke today...
- Nosie when gasing it help
- Auto SC shifts hard into gear
- tranny issues....
- JDM Wiring for a 2JZGTE swap
- Egr
- Power Steering
- Anyone use a Greddy E-manage Ultimate on the V8?
- Mphs dont work on cluster!!!
- Wastegate spring
- DIY changing spark plugs SC400... I know, I know!
- need help (Trans Fluid Leaking)
- IS300 hedder on 1992 sc300
- SC300 1G to 2G alternator swap
- egr
- Why are all car shops shady?
- How much boost can stock 4.0 v8's handle?
- sc300 na-t help please
- heating problem
- Another Aristo swap
- transmission whine? or something else
- 2jz Ge Vvti From Is300 On A Sc400 ?
- 96 sc300 M/T Transmission mount questions
- Question for you Fuel/Engine Experts
- Which Ebay China turbo manifold to use?
- Piping Size
- JVTR aluminum radiator
- aluminum radiator explantaion
- singel turbo manifold problem???
- 92 SC400 Crossed Jumper cables - Battery Light?
- Is this My heater Control Valve
- tach and speedo incorrect
- Magnaflow 3" Dual Mandrel-Bent Exhaust w/ pics!
- How do i fix my temp gauge?
- 99 GS300 ijectors in SC300? need confirmation
- idle problem
- Hey! Wtf happen?!?!
- Little closer to the r154, few questions..
- Transmission Swap on 95 sc300
- Making a Mods List guide "need input" rearrange these and/ or add!~!
- ECU compatibility
- Please help= catalytic convs.
- Rattle rattle!!!
- What options does a SC400 have?
- LS400 headers ???
- Fernando's SC300 2JZGTE 6spd build
- trouble shifting when cold
- Polished Intake Manifold for a 1J
- How is this TurboEast Kit?
- idling rough when cold???
- K&N FIPK for is300 fit a 93 sc300??
- Help with deciding what clutch to put
- Need help guys sc300 is driving me insane!!!
- which flange on oil pan?
- no intake system for 97+ sc300? +turbonator
- Tune-up advice needed
- leaking power steering hose???
- 94 SC4 a/c
- 1jz on the way
- What Motor Oil to Use With 2jzgte?
- experiencing acceleration problems hope the experts had some insight
- serious maintanence question
- block off plate question
- Major Oil Leaks please help me!
