- 1JZ stainless "y" pipe + manifold
- NA-T Auto
- Speedometer barely registers
- Brainstorming a better system ...
- Adjustable Fuel Regulator Install W/ pictures – 1JZGTE
- question about belt squeal
- Buying sc400 pumpkin, how can I tell it's legit?
- valve stem seals!!
- passenger window issue
- SC300 build brought to you by the fist pump state
- What are these 2 coolers for sc400?
- HELP!!!!!!!!!!!!!!Coolant Lines From Block?
- Gas smell on start up and bad gas mileage
- safc pressure sensor in/out
- IAC on Greddy style plenum
- 1JZGTE VVTI wiring question...Body plug re pining
- 98 SC400 Short Block Swap 4.7 L ???
- Leaking R154.... Help diagnose please!
- DIY $30 Adjustable Boost Cut Eliminator
- Hx35 Turbo Drain Routing Help?
- [Q]OBD2 SC300 5 Speed TT swap w/working OBD2 Port
- 1jz gt35r downpipe??
- Aftermarket Air intake system question
- 2000 SC300 2jz-ge vvti W58. What clutch kit?
- Can't Get Boost Down with Blitz Dual SBC Spec R...
- 97SC plz hlp
- Power Steering Pump
- 93 sc400
- photogenic turbos
- AZ 2JZGE Cams in a 1JZGTE
- Trans And Diff ID
- Car failing to start after Idle Control Unit replacement. [Video Inside]
- lexus sc400 problems
- 1992 Lexus SC400 wont rev past 4K????
- Learned value aka vf apply to sc'???
- SC400 dies on me in the drivethru...
- Lexus SC400 (1994): Summary of 2012
- 1grfe sc400?
- 1UZ Oil Filter relocation?
- For manual builds, why is the 6 cyl (T) more popular than the 1UZFE?
- BIG QUESTION about swapping trannys!!! Need your SC knowledge
- Avg. Cost of a 2JZ-GTE swap?
- setup is done. aiming for 450hp using a safc . bcc needed for my tune?
- 24, 25, 31 CEL codes out of nowhere! Help.
- SC400 5 Speed Swap Questions
- Fuel Upgrading Time
- Starter, engine wire removal?
- Is this fine or am I worrying too much?
- Engine lag, electrical smell, low idle and jerky shifting.
- 350z/2jz parts list
- 1Uz Flywheel choice
- hesitation at startup, roads and on inclines
- SC300 - ldle Problem & coolant bubbling back into overflow reservoir
- MTC Engine Mounts
- Trrple charged! Turbo + supercharged sc
- 1jzgte swap
- Need Help!!! Sc 400
- 1995 sc300 build at a stand still
- W58 or r154?
- SOARER r154 or MC Rebuilt MK3 R154?
- bucking, squeeking, squealing and chirping... smh at the sc please help...
- CEL-Code 25 lean.Ideas? 93' 138xxx miles
- Help big Oil leak SC400
- fuel rail install kit help 1jz
- SC400 Power steering
- Where is this oil leaking from?
- AC Delete! It's time...
- 350z tranny????
- Torque specs for 2jzge with arp studs
- 88 7mgte resistor pack / ignitor
- Can any one help me identify if this harness is from a 1jz soarer or a supra
- 6-speed Getrag swap need 6-speed rear-end?
- 1uz-fe with sr20 tranny
- blown head gasket?
- single turbo 1jz questions twins out
- 97-2000 LED Tails Fabricated "A" Right Way
- Need advice on rear diff...
- Electric Cutout vs Aftermarket ?
- can I use a m/t ecu on an auto car 93 sc400 getting an auto 1jz swap
- SC430 rear driver spindle for sc300?
- Quick question thread!!!
- Ecu modded
- Car won't boost
- SC400 - 1UZ pulled out, 2JZ swapped in, wont start?
- 1997 SC400 2 Alternator burned
- e85 injector size NA-T
- Lack of power in first?
- A Precautionary Tale
- code 25?
- trac light problem
- 1jz fuel injector removal!!
- 92 SC300 not idling
- Dyno videos e85 sc300 day. Weak numbers?
- 1JZGTE block with 2JZGE Head
- 1jz single downpipe [ebay]
- AEM Fuel Pump?
- SC400 Twin Turbo
- start problem
- 1997 and 1996 sc300 Ecu pinout help
- E85 conversion for NA/T (Parts Needed?)
- Alternate ECM option
- sc300 custom exhaust
- Marlin Crawler shifter socket/bushing q's
- sc300 w58 tranny (adding fluid)
- switching into overdrive by itself and idling jumping
- SC400 Nitrous Guide : Everything you need to know from A-Z
- NA-T Cam Opinions
- What thread pitch is the fuel feed ine (female) w/pic
- lots of blow by
- Cam Sensor
- Will is300 radiator hoses work on sc300
- 1999 sc400 white smoke when shifting?
- 1JZ with 2JZ GForce ECU....next step/help running rich
- Driftmotion single turbo kit Dump tube
- Camshaft Pulley Removal SC400
- What kind of whp are you guys seeing in 440's and a single?
- Limp mode
- How to save $1738.50
- Can Only Close The Windows When Revs Are Up
- Odd passenger window issue
- Any place to buy 1jz intake mani gaskets only?
- Car turns on and dies after need help!
- Cleaned IACV now my SC400 won't start
- sc3 n/a FFIM performance?
- I smell exhaust fumes inside my SC300; loss of power and 1JZ idles really rough
- Inner timing belt "cover" necessary?
- driveshaft carrier bearing
- steering column won't move
- 1JZGTE Single Turbo. DIY HEAD REMOVAL??
- 2jzgte guru please chime in
- 90mm throttle body Godspeed?
- Identify module under dash
- Help!!!! Car won't start! Not your average problem
- 92 SC300 Doesn't Shift into High Gear
- Power Steering Pump Leaking Issues After Swap
- Starting and Headlight up issues...
- Which a/c lines need changed when gte in a sc400?
- 1992 Lexus SC300 Cranks/No-Start - help
- Tail Lights out - First checks?
- best bolt on turbo kit for 2jz-ge?
- Help ID Cut Wire
- 92-01 tails??
- 98 AD or BC?
- Shifter Bushing questions?
- Just purchased a 5-speed SC with welded diff. Was that a mistake for a normal driver?
- Driver side mirror
- Highest gear ratio?
- Warning light keeps appearing... Help?
- timing belt scooting itself off
- Wet Nitrous Fuel Tap (Photos Included)
- engine rebuild
- 1jz single turbo feed plug
- extra muffler for drone?
- My Headache for the last 2 weeks!
- I hate my car
- Just got back from the dyno
- Timing Belt Lasted 200,000 Miles Tensioner Fell Off
- Center console removal
- Searching for the right sound for my 400
- Flash tune/ data logs
- Arp head studs. Which one under cut or regular
- 2jz 5speed owner
- 98-00 SC300s looking for a 2JZ-GTE writeup
- Setting TPS to spec. Only reads "4.74 ohms" Help?
- SC400 1jz-gte or 2jz-gte swap
- 1jzgte Exhaust manifold gasket/ Turbo oil outlet
- Questions about 1JZ Hose Routing
- Sc400 shutting off issue
- Clean Throttle Body with BG 44K or Sea Foam?
- Quick Q: Strong gas smell at all times-EGR M hose?
- Recomedation for clutch 92 SC300
- check engine light issues
- Help with 93 sc300
- Heat not working in 98sc400
- Excessive Blowby?
- Important - SC300/400/GS/MKIV diff drain and fill plug bit type
- Cluster Repair!! HELP
- 2JZGE vs GTE
- Factory Fuel Filter
- Virtual Tuning?
- 1jz Upgrade
- Engine noise only when in gear
- Anyone ever ran a TT auto trans from...
- 98 Sc400 shakes and trac light flashes and check engine light is on now
- 1998 Lexus sc400 engine light and trac light flashes
- 1992 sc400 HELP PLEASE CATALYTIC CONVERTER
- Bushings replaced or entire rack and pinion?
- Custom Alarm Sounds Possible?
- Speedometer broken, Odometer and all other work fine
- Help me identify this squealing noise in engine
- TPS (Throttle Position Sensor) Non-VVTI 5-speed
- Super low clutch
- Auto pulling in second
- Precision Gt 4202 or BW s372 turbo..... Any advice?
- 2jzgte vvti what standalone ?????
- Hks vs jun 264, which one!!!!
- twin scroll turbo on single scroll manifold... ?
- 93 SC300 145K need help DTC code 25 and code 26
- OReilly Global Auto Trans Fluid??
- 2000 SC300 GTE Swap
- anyone have Pics on Dual Pump setup for in-tank?
- 2000 lexus sc300 intake ?????Help
- Lets talk power steering
- Squeal Upon Engine Start
- Any one here running a supra tt cruise cable on a gte swap?
- SRT intake for sc400
- Help running rough and dying! :(
- Transmission shavings?
- SES Light help please
- Urgent help
- SC300 fuel tank
- 2jzgte and 1jzgte wiring harness question?
- Stalling/dying issue on a 1992 SC300
- Chaser? 1j in sc
- Which al radiator best bang for the buck if you have 2jzgte swap?
- Puzzled on Tach Connection on 1UZ for Idle Check
- 95 SC300 won't idle
- Sc400 with 2jzgte which motor mount to use?
- 12 cm holset hx35 housing
- Car won't start!! Disconnected iacv??
- 98-2000 vvti SC400 Intake options
- valve stem caps used as shims
- Recently finished W58 + 1JZ swap into SC. Shifting/tranny issues.
- Resonator Delete SC 400
- Question about the A340 transmission
- intake manifold gasket install ?
- more sc power
- Would the timing belt be replaced over 100,000 miles?
- Lsd options for a street SC?
- my sc300 has a random misfire need help
- Sc300 has power, battery is good, but will not start
- What do I do with the stock IAT sensor??
- Automatic Headlight Question
- 1uz twin turbo build
- VSV Bypassing...Heating blows cold...
- Composite 2jz headgasket
- Tank fuel filter?
- R154 pricing question guys
- 7m-gte exhaust manifold vs 2jz-gte
- HELP! No Start after tune up
- Aristo swap in my 93 sc300 Wont start. fuel and spark are good!
- SC400 "pops" at idle and "shakes" from 40-50 mph
- can anyone here identity my exhaust
- 1JZ, stock SC400 rear end noise!
- Custom fab parts
- HELP with blower motor
- 1JZ overheating a little
- Whats your number??
- Reverse Camera Connector Layout
- Free Toyota Pre-OBD Datalogger Found!!
