SC300 - ldle Problem & coolant bubbling back into overflow reservoir
Recently I changed my HG to the 2jzgte one and ARP head studs. After putting my 2jzge back to together, I started having idle problems and coolant started bubbling back in the overflow reservoir after driving for about 20 mins. I have been all over the forums looking to see if anyone has had this problem.
1JZ Single SC400
Try and rebleed the system. Jack up the front as high as possible and put heater control on floor and in the high position for fan. Let it bleed for at least 20-30 minutes and see if the problem still persists.
Idle problems make it sound like something went wrong on the install. Why did you do this gasket swap in the first place? I've seen cases where people detorqued the head in the wrong manner when doing something like this and warping it without knowing and having this problem when putting it back together.
