SC400 5 Speed Swap Questions
Hey guys heres my situation. I'm buying a w58 trans to do a manual swap on my sc but idk if its just too late right now or I'm just slow. The trans im buying comes with a 2j bellhousing because it is meant for an sc300. But is the 2j housing removable? Once I take that off could I just throw the 1UZ adapter plate on and bolt it up to the 1uz? I think they do or how else would people be able to put the w58 onto the 1uz without the bellhousing coming off since the w58 doesnt normally come with a 1uz
yea you have to un bolt the W58 bellhousing and install the adaptor and and u will have to do a little bit of grinding on the Auto bell housing due to the bolt heads that bolt he adapoter down then you have to drill 2 holes on the top of the bellhousing to run the clutch lines for the Quatermaster throwout bearing.
Ok cool the following is the ad for what I am looking at tomorrow. -
Hi I have a w58 with the tripod shifter along with bell housing and front drive shaft light weight flywheel and clutch to make your automatic Sc300 or 400 a 5 speed and yes it does have the bellhousing for a 2jz. Stage 2 clutch also does come with it
Since I am getting it for a steal of a price I will probably just sell the 2j bell housing and buy the adapter plate. I do not know what the trans is out of nor how used the clutch is. I read that the MKIV w58's do not match up properly for sc300s. is it true for 400's as well?
YotaSC400
Performance & Maintenance
09-01-16 02:48 PM
