DIY $30 Adjustable Boost Cut Eliminator
I tried searching and I apologize if this is a duplicate post.
I take no credit for this, but I thought I'd spread the word. I built the circuit from the link below and it works great. I'm running 20 PSI on the GTE ECU and the AFR's are great and driveability is awesome. If you want to build and sell them, it only costs an additional $10 for each one because you have to buy a minimum of 10 quantity for some parts. No, I won't build you one.
Build your own FCD
To hook it up TAP into 12v and 5v cut the map signal wire.
Here's the list of parts I bought from jameco.com to do it:
Here's the guts of the project:
Build your own FCD
Yeah I think I had seen a version of it before but I think I am finally motivated to do it and max out these injectors and see what they can do. I like the clamping and it wouldn't be the first time I have arranged some op amps so it might even be fun. thinking about making more than 1 in fact cause you have to order so many parts.
found a DIY speed cut since the JDM ecu's have a problem with that also.
http://www.alltrac.net/phpBB2/viewtopic.php?t=34001
It looks like the soarer guys are clamping at 4.3V or a bit less, which is good info for the 1JZ guys like me.
http://www.soarerworld.com/forum/sho...6-Homemade-FCD
