electric fans low budget setup???
Old Sep 23, 2004 | 09:03 PM
prjctSC300's Avatar
prjctSC300
Default electric fans low budget setup???
i want to do an electric fan conversion on my 92 sc300, my fan shroud is broken and i might as well spend that money on an electric fan conversion. been thinking about doing this for some time now. but i was wondering if i can use a stock oem fan of some other cars, instead of dishing out the big bucks for a FAL one??? any wiring diagrams?? dual or single setup?? which one to go with?? push or pull type??thanks for any help
Old Sep 24, 2004 | 07:50 PM
prjctSC300's Avatar
prjctSC300
nobody has any ideas??
Old Sep 25, 2004 | 04:50 PM
samill2's Avatar
samill2
Intellexual covers this in their FAQ. They recommend the Flex-a-lite 210 but a friend of mine has a MKIV Supra. He bought two 12" E. fans from the local auto parts store and wired them into the aux. AC fan wiring. I plan to do the same but haven't had a chance to dig into it yet so that's all I can give you for now.
Old Sep 27, 2004 | 08:44 AM
kaotiq's Avatar
kaotiq
Im using electric fans on my koyo radiator. The setup is a dual fan that is connected to a relay which is connected to my "ACC" position to the ignition. The fans are VERY LOUD, just thought that i'd warn you first. However, i would not trade the electric fans in for the stock ones. I love this setup.
Old Sep 27, 2004 | 09:31 AM
gadgetSC's Avatar
gadgetSC
Kaotiq is right about the fans being loud. I have the flexalite 210's and they take some getting used to.
gadgetSC-t
Old Sep 28, 2004 | 07:21 AM
samill2's Avatar
samill2
Question
Do you guys actually feel a difference on the butt-dyno with the electrics?
Old Sep 28, 2004 | 09:05 AM
kaotiq's Avatar
kaotiq
Well i cant speak for others, but it is different for me because i had my motor swapped.
Old Sep 28, 2004 | 06:18 PM
prjctSC300's Avatar
prjctSC300
what type of fans do you guys use?? pull or push type?? dual or single??
Old Sep 28, 2004 | 06:25 PM
SupraCoup3's Avatar
SupraCoup3
the 210s are dual pull types IIRC
Old Sep 29, 2004 | 08:31 AM
kaotiq's Avatar
kaotiq
i believe thats what i have too.
Old Sep 30, 2004 | 10:17 AM
qtb33's Avatar
qtb33
Pull types are far superior, a push type should only be used as a last resort.
Old Sep 30, 2004 | 08:40 PM
prjctSC300's Avatar
prjctSC300
is it really necssary to have dual fans or can i just run a single fan setup??
Old Oct 1, 2004 | 06:57 AM
kaotiq's Avatar
kaotiq
It isn't necessary, but our radiators are large and require a dual set-up for maximum cooling efficiency. Our cars do not hold civic sized radiators. If you are planning on running your car to the max, I would have to say "yes, it is necessary."
JohnnyB822
Sep 8, 2010 12:18 PM
LouLex400
Mar 10, 2009 05:04 AM
BBriBro
Jan 7, 2009 07:15 PM
VJ RC51
Sep 21, 2005 12:14 AM
